Results 1 to 6 of 6
    trainer
    Stan's Raven 700 x 35 cross tire on Flow EX rim?
    This is kind of an off the wall question but has anyone run the Raven 700 x 35 tire on Flow EX rims? I have a set of Flow EX wheels and would like to mount some cross tires for gravel road adventures but I am not sure if it will work. Any thoughts? Thanks
    Former Bike Wrench
    Haven't tried it but I've never had issues running tires that are wider than the rim they are mounted on. For instance I have run 32c tires on 28mm wide rims with no issues.
    trainer
    Thanks for your feedback! I have the tires ordered and will let you know how they work.
    Bro Mountainbiker
    Reputation: Sheepo5669's Avatar
    May 2010
    Should be fine. Im gonna have some Mud 2s on my flows for CX season on my pit bike.
    Raised in a Chicken-Coop by Chickens
    my bike gained weight
    Reputation: MrBiggs's Avatar
    Jun 2005
    Quote Originally Posted by podrunner View Post
    So how did this work? Thinking the same thing...
    trainer
    It works ok as long as I keep the pressure below 35psi. Above that they will blow off of the rims. I only ran them a couple of times on the flow rims and decided to go back to Kenda Happy Medium 700x40. They woked much better.
