I've had no issue with the tubed 27.5 Kenda Nevegal in 2.1 and 2.3, tubed 26x2.4 Conti trail king, tubeless 27.5 Schwalbe Nobby Nic and Hans Dampf in 2.25, tubed 27.5 Maxxis Ardent in 2.25, and tubeless 27.5 Maxxis High roller 2 in 2.3. The only tires that needed compressed air were the Schwalbe tires, all the others could be done with a floor pump.
 Originally Posted by trek551
Either rims is overkill for theses tires as they are more suited for width 2.3 and up and aggressive riding. I'd suggest Arch EX if you want to keep your tires. If you are over 220lbs then yes go with the Flows but buy bigger tires.
Just built some Flow EX's possibly the Arch could/should have been my choice. If i continue to use 2.1 -2.25 for a 210 rider on a 29er any adverse affect
Stans Flow EX
I just built a hardtail 29er and picked flow ex's to use (also 200 lbs), anything with less width/stiffness flexes too much for me in a 29" wheel. If it was 26 I can get by with less but the big hoops flex more and for me I need to run a stiffer/wider rim because of it.
I have the same flex issue currently running the Wtb I19. So with Flow running less than the recommended 2.3 tyre I shouldn't have any issues? I'm using a 2.25 front and 2.1 rear
@ the last three posters. How are the 29er Flows working out for you?
Planning to spec a 29er wheel set for a new bike this year and on the fence between the Arch and the Flows. I also weigh about 200 lbs.
You all still liking your Flows?
These rims are the best upgrade I've ever made to my bike since disc brakes and suspension. Running tubeless using 29er TR Nevegals and Minnon DHFs has been easy, I've only used a floor pump and even did a double tire change in the hotel parking lot at Crested Butte by myself. I use the green slime, no flats, just little green leaks where the thorns are. Dropping down the rock gardens in Moab past people fixing flats was nice too. I'm 220lbs soaking wet, riding on the CO front range, very technical. I switched from Mavic 319s, the Flows are wider, lighter and stiffer, what's not to like?
Sorry if this has been covered - I tried to study the Flow EX threads, but am still a bit confused.
Will a 26" Flow EX work well WITH TUBES and regular tubed tires? I run either a 2.35 or 2.5 single-ply non-TR Nevegal up front and would like the option of continuing to run tubes as well as tubeless.
Choice is between a Mavic EX 721 and the Flow EX. I like the wide rim width of the Flow EX as well as the option to easily go tubeless (and weight savings), but want to make sure they're compatible with my regular tubed tires before I commit. Thanks for the help.
Definitely go with the Flow EX! Yes, it can be used with tubes just fine.
I'm thinking of having Arch EX Front (Specialized Purgatory Control 2.3"), Flow EX Rear (Specialized Ground Control 2.1") on a replacement wheel rebuild.
My thinking (going from Crest x 2 Specialized Purgatory Control f&r) is that the tyre profile of a 2.1 Ground Control on the wider Flow EX rim will be similar to a 2.3" Purgatory on a narrower Arch EX rim.
With the rear 2.1" tyre being 100g lighter than the 2.3" tyre, the 100g heavier rear rim will even out, but the bonus will be a stronger rear wheel.
Is this right or am I talking bollocks???
Cheers, TV :-)
Sacked off the idea, sticking with Arch Ex.
Need Some Feedback,
I am rebuilding my Wheels and I am looking at the Stans Flow EX. I was talking to my local bike shop and the owner said he has had some problems with the Stans Flow EX blowing tires. I have read a few things on this thread about that happing with certain tires. I have Chris King Hubs and like the SCHWALBE TIRE - REAR 26X2.25 Racing Ralph SS Tubeless Ready and the SCHWALBE TIRE - FRONT 26X2.35 Hans Dampf SS Tubeless Ready.
Has anyone had experience with the SCHWALBE tires and the Stans Flow EX?
I have racings ralphs front and rear with no issues on a 27.5
Khomes7 - Thanks for the feedback. From the feedback I have recieved from othera is that the Schwable is fine with the Flew EX.
Thanks again for the feedback.
Hi everyone, I've seen various reports of tyres being too tight/too loose. Was just wondering what tyres people have experienced going on fairly easily. I've just got a pair of Flow EX ZTR rims and have failed to fit Continental Trail Kings and Schwalbe Magic Marys. There was just no way those tyres were going on the rim, it was a struggle just to get them half on and removing the half-on Magic Mary required the combined efforts of both me and my girlfriend.
I'm on the verge of selling the (unused rims) because I can't be bothered with buying tyre after tyre in the hope that one will fit.
A tip for getting tires on.
When you get one side half on make sure it's in the very middle of the rim and work the other half on. I have been doing this and can get Schwalbe HD, Minion on without tire levers.
If you have the 29in size Flow EX the Tubeless tires will most likely not fit. Also several tubeless ready tires will not fit such as WTB TCS tires and Hutchinson Tubeless ready tires. Any tube-type tire will fit with the correct mountain procedure. In my experience the Schwalbe TR tires will fit with the correct technique.
1. Start opposite the valve and mount the valve area last. The valve sticks out and if you mount that area first you will have to stretch further.
2. One you get one side mounted begin mounting the second side opposite the valve. Also, push the first bead out of the center of the rim to make room for the second bead. The closer to the center of the rim the bead is the easier the opposite side of the tire will wrap around the rim.
Valve area last!
Thanks for the tips guys, will give it a go and see what happens. I'm using the 26" rims btw.
Thanks for the tips everyone. Finally managed to get the Contis on with liberal applications of soapy water, tyre lever abuse, and Changingleaf's recomended method. I don' think my hands will ever be the same again though.
One issue remain, the tyres now still don't sit properly. They are so tight that the bead doesn't fully push up against the rim edge, some of the bead stays in the middle groove of the rim. Obviously this leaves the tyre slightly misshapen when inflated.
Do beads stretch? Is it worth my riding them somewhere safe for a bit to try and stretch them out so they seat properly?
Also, I'm currently running with tubes (I don't have access to a tubeless kit and won't have for a while - tubes should be a temporary measure), are the tyres likely to fit properly without tubes?
Sorry for all the questions. I've never had to contend with these kind of tyre/wheel issues before - and I have had plenty of wheels and tyres in my time.
Thanks for all your help
Alex,
I have just fitted Maxxis High Roller 2.4 (f) and Crossmark 2.25 (r) to Flow EX rims (26 inch). It was a real struggle, which involved bad language and veins popping out of m forehead.
The beads were not seated properly, so I deflated the tyres and pumped them up to near 40 PSI with a track pump. They then seated with a bit of a pop, as the beads spread out to the rim.
I am a bit concerned that if I get a flat I will be screwed. If that happens, I will need to look at going tubeless, as I heard flats are far less common.
Re: Stans Flow EX
No problems mounting 29er Schwalbe Hans Dampf and Nobby Nic TLR on Flow EX rims
Tubeless is the way to go. It is harder to mount a tire with a tube in it on a Flow than mounting it without the tube. For easiest mounting make sure the bead is in the center channel of the rim and always mount the valve area last.
Hi Gribble,
I actually succeeded eventually in much the same way as you, and I too dread getting a flat.
I do intend to go tubeless in the future, but I don't have easy access to the materials required here and getting them mailed to me will be difficult.
I want to switch wheels and thinking about Flow EX or Arch EX. Here is my setup : 26" Ikon EXO/TR 2.2 Rear, Ardent EXO/TR 2.25 front, the tire sizes being 57-559 and 54/56-559. For these particular tire sizes and going tubeless, is the Flow EX wider rim traction better or am I best off with the Arch EX ? Thanks.
No problems with Specialized Purgatory Control & Ground Control 26".
Stans Flow EX
just got my sealant and will be setting up my flow ex/conti mtn king 2.4 tubeless... these set came with the bike and I have about 70miles on it using tubes!
hope I don't have any issues
question: I'm 150 naked, for my 26"/2.4 setup what pressure should I be looking at, riding mostly singletrack, some rocky/technical descents and jumping off of rollers a few feet high
Based on Stans web site recommendation about 21 front and 24 rear.
NoTubes Tire Pressure
FWIW my new Arch EX 26" feel noticeably heavier than the Crests, but they're noticeably stronger too.
Flow Ex in white/gray
Hi. Is there anyone running the Minion DHF 2.75 x 2.5 on Stans Flow Ex (25.5mm internal diameter)? How is the profile?
The DHF 2.5 and DHR II 2.4 are both from their "WT" (wide trail) series. I'm running the DHR II on Flow EX rims with no trouble. Probably more rounded profile than designed, but still hooks-up when you lean on it.
BenTYYC
2015 RMB Thunderbolt 790 MSL BC Edition
2017 RMB Blizzard -50º
2017 Cervelo C3
"Love the ride"
What are builders / riders seeing re: seam alignment on Stan's rims (flow, arch, ex's or any others)?
Only did 2 or 3 build's on some of the Flow's...switched my set's back to wtb for quite a while and their seam alignment has been slightly off...consistently, this is making me want to go back to Stan's for a bit and find whose manufacturing has the most accurate aluminum joinery process
All barks have been rendered into english...
so far i haven't seen any alignment issues in stans rims (again, so far). however, i don't like how they finish up the join as it looks like a glob of weld that's just been flattened of some sort (ugly). another thing i don't like with stans rim are the vent holes scattered around. yes i understand that by 'vent' holes this is where smoke gets out during manufacturing process, but then other rim manufacturers don't have this. these holes are sources of leaks 'if' the tape isn't wide enough to cover the well end to end. it takes a bit of care and knack to install the tape if there are vent holes not to mention the higher risk of tape becoming undone when dismounting tires. also, the fact that they are using bst, tire choice is already limited - it's explicitly stated that they can't use wtb tcs or spez 2bliss.
other than those 3 points above, stans rim does the trick when it comes to tubeless - they do work. however, if i were to build my next set of wheelset or rims, i'd stay away from stans and go for easton arc or wtb tcs for alloy or derby for carbon if you got the $$$ to burn.
I've got the same rim/tire combo except in dual compound, works great!
In keeping with the popular "mullet" theme these days (business in the front, party in the back), I'm running the DHR II 2.4 in the front, paired with an Ardent EXO 2.4 in the back.
I like the lighter weight and lower rolling resistance of the Ardent in the rear. I'm tempted to try a Minion SS on the back wheel as well...
BenTYYC
2017 Cervelo C3
"Love the ride"
Been having a hell of a time getting my Flow EX rims to hold air. Air would rocket out around the base of the stem. I tried new stems, stans "yellow" tape, recommended 3M tape, remounting everything, different kinds of stems etc.
Turns out I believe it's the above mentioned vent holes. They are quite annoying, not regularly spaced, and sometimes quite close to the rim edge where they are particularly hard to seal well. What were they thinking?
Seems very weird for a rim manufacture that prides itself on advanced tubeless technology and specifically "Bead Socket Technology (BST) for superior tubeless performance" to have such a poor design.
I'm going to try to seal mine with silicon, and if that doesn't work maybe solder or JB Weld. I think I'd hear more about this, but I suspect most rims "just work", because there's a separate chambers inside the rim. But only if the vent is too deep do you have a problem. So the air leaks beside the tape, into the rim chamber, then around the rim until it gets to the valve stem.
Use wider tape that goes up the sides and the problem will be solved.
From Stan's Website...
Which width tape should I use?
The widths of our tape are selected with our rims in mind. Generally, we recommend tape that is 1-2mm wider than the internal width of your rim to account for the drop channel.
I go wider than that. 28, 29, or 30 will all work.
I wish, if I go full width or longer it looks good, until I mount a tire and it pushes over or folds. Seems like a really stupid design, they should put the vents closer to the center line.
Got a recommended tape that works well? I tried Stan's and 3M tape without luck.
Members who have read this thread: 71
- 6foot4,
- Patch,
- tac99us,
- Dexter-01,
- erb16,
- changingleaf,
- kubikeman,
- Rngspnr,
- maclgallant,
- pwb7106,
- Jp716,
- aski,
- HuffyMan,
- WillTheGreat,
- CoyRfishing,
- slug3135,
- GMV,
- edubfromktown,
- gspice,
- OLDFATUGLY,
- Jurven240z,
- azlakerfan12,
- bull_dozer,
- rugbyred,
- spikebike,
- noapathy,
- GeorgeLuni,
- jga013,
- ridetheridge,
- Ptrick,
- BrentD,
- Flawless Cowboy,
- RonSonic,
- party_wagon,
- kenley&co,
- shredder123,
- johnD,
- One Pivot,
- wallydog,
- skeered1,
- gr8fasushi,
- fortunms,
- eshew,
- eastsiderider,
- jdaigneault,
- Graveldad,
- Streetglider08,
- yeti rider,
- db9,
- neb636,
- rpb992,
- rockhop,
- StevePodraza,
- Fastronaut,
- bubba13,
- blcman,
- mattnes17,
- elarkin42,
- Ratman,
- Jyn,
- phongvo666,
- tubby74,
- direktor,
- mazzino
- You may not post replies
- You may not edit your posts
Forum Rules
