bikerbert
Stans 29" ZTR Crest Wheel and Hutchinson Pythons?
I put set of Pythons on tonight, used 4oz of sealant per wheel and heard them pop at the gas station when I filled up.
About two hours later, both were flat. Are the tires not compatible? They are UST specific.
Bad valves? Not enough sealant?
I couldn't even get the bead of a python on a crest rim with a reasonable amount of force.
Unless they loosened up the beads, I would guess the tire isn't fully seated, or you damaged the bead if it was real tight. Normally I would say shake the stan's around in there some more.
bikerbert
I will put more sealant in and give it another shot.
Gilarider. I had the same problem, it was solved by removing the tire completely and installing from the other side.
My python does not hold air that well, loses about 4-5psi over 3 days
- You may not post replies
- You may not edit your posts
Forum Rules
