Results 1 to 25 of 25
    Huckin' trails
    Reputation: David C's Avatar
    Stainless steel nipples ?
    Silly question, but why don't they make SS nipples so you get something stronger and more durable instead of brass ? Just wondering
    Quote Originally Posted by NicoleB28 View Post
    topless. that's what all mtb girls do. we go ride, get topless, have pillow fights in the woods, scissor, then ride home!
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by David C View Post
    Cost. Steel nipples would cost more to make.
    Strength: brass is strong enough.
    mtbtires.com
    Reputation: Tripower's Avatar
    Jan 2011
    Galling
    They would gall something fierce with the spokes.
    Huckin' trails
    Well I know it's more expensive, but is the corrosion resistance and strength really not enough to be a better durable solution to brass nipples for winter climates, like urban commuting in nasty salts and other street chemicals ? If you can afford SS spokes over steel ones on your wheel, why not SS nipples too ?
    Dec 1998
    No. See above.
    mtbtires.com
    Huckin' trails
    I had several brass nipples stuck from winter corrosion and stripped too. I'm not talking about mtb here, but real urban condition.
    And could you explain a bit more on why it would be sooo costly ? People are building up wheelsets with $3 spokes and $500 hubs, I don't see how a few more $$ would be a big no-no.
    Steel is harder to tool than brass; it's not just the cost of the nipple's material, but the total cost of production.
    That said, If you take care of the wheels, corrosion is almost a non-issue, certainly less than if you stuck two pieces of steel next to each other and didn't sufficiently insulate them (which if you did with the brass nipples, they wouldn't stick anyway).
    Huckin' trails
    Thanks.
    So I would assume the only one to have stainless steel nipples is the Man of Steel, aka SuperMan ?
    Dec 1998
    Thanks.
    Those would be tungsten.
    mtbtires.com
    Poacher
    What does Wonder Woman have?
    Huckin' trails
    I keep wondering about that.
    Quote Originally Posted by Tripower View Post
    this is the answer
    whatever...
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    because brass is more than strong enough and durable enough. stainless steel would be more expensive with no material benefit.
    stainless steel in a spoke nipple application is not likely to gall unless you've thought of something i completely missed.
    brass nipples have proven to be extremely durable, even under adverse conditions... well durable enough to outlast an aluminum rim. do you have some problem with brass nipples or is this just an exercise in mental masturbation?
    poor comparison. mild steel spokes would corrode quickly.
    Quote Originally Posted by steadite View Post
    this is the answer
    why?
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
    Now this thread is getting interesting!
    Quote Originally Posted by meltingfeather View Post
    why?
    Because self-mated austenitic stainless steel has a very low galling threshold stress, unless you're taling about one of the special grades like NItronic 60 (which we're not).
    whatever...
    Having rounded off the wrench flats on a spoke nipple, personally, I would love to see them made from higher strength materials.
    whatever...
    If you did it on a brass nipple you probably had the wrong size of spoke wrench.
    Because self-mated austenitic stainless steel has a very low galling threshold stress.
    In lubricated threads that don't move?
    Please forgive me, I accidently posted in Meltingfeather's forum...won't happen again.
    whatever...
    Reputation: Vespasianus's Avatar
    Quote Originally Posted by hoolie View Post
    Tasty...
    On MTBR, the reputation is infamous.
    Buchanan Spokes - Stainless Steel these dudes build a lot of wheels for the motorized bicycle crowd. If they exist they will be able to get them.
    "Dish is illogical." Spoke of Vulcan.
    It's a valid question in my opinion. You're obviously somewhat knowledgeable, so if there's an easy answer why not offer it? Teach me something I don't know.
    The butt hurt is pathetic.
    Quote Originally Posted by zerodish View Post
    The premium is pretty shocking.
    Dec 1998
    Dang. 10-20 times as much as a perfectly good brass nipple.
    I stand by my first reply.
    mtbtires.com
    Huckin' trails
    Thanks for the link
  1. NOS stainless steel CQP!!
    By LIVE TO RIDE in forum Vintage, Retro, Classic
    Last Post: 02-14-2013, 07:04 PM
  2. Stainless steel forks
    By searchtime in forum Frame Building
    Last Post: 05-03-2012, 07:54 PM
  3. Replies: 7
    Last Post: 10-22-2011, 04:52 PM
  4. Stainless steel chains
    By Biohazard74 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-06-2011, 06:04 PM
  5. Drilling Stainless Steel?
    By sasquatch rides a SS in forum Tooltime
    Last Post: 02-22-2011, 07:15 PM
