Results 1 to 5 of 5
    Reputation: rattinox's Avatar
    Sep 2012
    Idea! stainless steel axles & cones?
    Just wondering if there's a Company in the US that makes basically the same line of axles, cones and whatnot as Wheel Master does, but in some grade of stainless.......
    It's not superior strength I need, it's extreme corrosion resistance.
    I use my ancient RockHopper for something a bit arcane: weather spotting for the National Weather Service. In Spring and Summer, that bike is constantly soaked- along with it's rider
    I've already replaced every single nut and bolt with "hardware-store-grade" (18-8) stainless, but there are a few areas I haven't done- like axle components.
    The hub ball bearings are no worry- they're greased - but the axles, cones and axle nuts are exposed.....
    Probably Much Ado About Nothing, really. Maybe I'm just morphing into a Techno-Elf in my advancing years, eh?
    Magically Delicious
    Reputation: Cleared2land's Avatar
    How about keeping a fresh coating of a marine grade grease on them?
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
    Flappity flappity flap
    Reputation: Zowie's Avatar
    Aug 2013
    I'd hazard the guess that a good grade of stainless that can be hardened enough to serve properly as a bearing cone (if there is such a thing?) it'd be very expensive even if they could do a reasonable quantity.
    I know stainless bearings have proven to be less reliable in my anecdotal evidence...
    mtbpete
    Reputation: changingleaf's Avatar
    True, stainless bearings and races are not as hard as chromoly.
    Those hubs may not have rubber seals and the grease may easily get flushed out in wet weather. A hub upgrade with better seals may make sense.
    Delete
    whatever...
  1. Replies: 6
    Last Post: 11-20-2017, 03:21 PM
  2. Kid trailers and 12mm axles? 142x12 thru axles.
    By RobertAxle142 in forum Families and Riding with Kids
    Last Post: 08-14-2015, 06:47 AM
  3. What steel for ht cones?
    By calstar in forum Frame Building
    Last Post: 06-03-2014, 07:37 PM
  4. Stainless, Stainless, Stainles....
    By Mark42 in forum Mongoose-Schwinn
    Last Post: 08-08-2012, 12:46 AM
  5. Replies: 7
    Last Post: 10-22-2011, 04:52 PM
Members who have read this thread: 32
