Results 1 to 15 of 15
Thread: which spokes?
    Nov 2012
    which spokes?
    I'm re-building my wheels, Crest rims are too flexy for my 190lb butt, so I bought a set of lightly used Arch rims to swap in. I used straight gauge spokes the first time, I didn't want to have an expensive mis-measurement. (length was spot-on btw...).
    I'm want to use double-butted spokes, but which? I was looking at Sapim here:
    Sapim Spokes and Nipples
    I'm looking at the Race and Laser, 14/15/14 ga or 14/17/14ga.
    Laser would be a bit lighter, Race a bit cheaper (but not enough to be THE deciding factor). Which would be better a better choice, and why? other brands a significantly better choice?
    From the Sapim website:
    Only experienced wheel builders should mount up wheels with this spoke.
    I've built my current wheels, and re-laced 3 sets of kids bike wheels onto new hubs, I've got the hang of it, and very mechanically inclined, would that be enough experience to cover this warning?
    Me: 190lbs, fairly smooth rider, Western North Carolina riding - roots/rocks & long steep climbs, 1-3 foot drops. Never taco'd a wheel, even cheap ones (knock on wood.....), I don't bash my way through things.
    Bike, '10 Turner 5-spot, 27lbs, 140mm rear travel. 150mm RS Revelation. Chris King ISO hubs + Stans Arch rims.
    My bike MCA kinda climbs like a billy-goat. WOO WOO!
    Reputation: Burt4x4's Avatar
    Feb 2013
    I am useing Sapim Force and so far so good with my build.. they are 2.3mm/1.8mm/2mm
    I bought 14g in black.
    Ride MORE = Live Longer
    Love Dirt / Hate Pavement
    turtles make me hot
    Reputation: NYrr496's Avatar
    I've built tons of wheels with DT Swiss Comps. They've been trouble free.
    I like turtles
    mtbpete
    Reputation: changingleaf's Avatar
    The Sapim Race spokes are about 100g heavier than the Laser for a qty of 64, but they build much easier because the do not wind-up as easily when bringing up the tension. The laser spokes are much more finicky and harder to true, but the shorter spokes on a 26in wheel makes them more manageable than building with them on a 29er wheel.
    Nov 2012
    other than being more finicky to build, is there any reason I should NOT use the laser? will the thinner mid section cause problems at my weight?
    Chris Bling
    Reputation: dustyduke22's Avatar
    Quote Originally Posted by shupack View Post
    If you are new to wheelbuilding, the Lasers might give you fits.
    As far as your weight goes, you would be fine...
    The obsession of wheels fused with the passion of cycling
    Affordable Custom Wheels
    Nov 2012
    Quote Originally Posted by dustyduke22 View Post
    awesome, maybe I'll buy one wheels worth and see how it goes.
    Nov 2012
    except for this:
    http://www.sapim.be/sites/default/files/checklist.pdf
    "do not use Sapim Laser in wheels with disc brakes"
    Quote Originally Posted by Burt4x4 View Post
    Hey Burt, where did you get your Sapim Force spokes?
    Quote Originally Posted by ridelikeafatkid
    "MOMMY, I WANT TO RIDE LIKE THAT FAT KID!" true story.
    Nov 2012
    at the bottom, photo is wrong though...
    Reputation: cannondave's Avatar
    Mar 2014
    I've just built up wtb KOM's with sapim D-light spokes and can agree "wind up" can be a problem for new builders
    I do try..!!
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    except for this:
    bad info.
    1. the CX Ray has the same amount of steel in the cross section, yet they recommend it for mtbs with disc brakes... for *cough* 3x the price *cough*
    2. people (including myself) have been building disc-braked mtb wheels for many years with these spokes, including for clydes, without issue.
    If it still bothers you, buy DT Swiss Revolutions, which have the same dimensions, weight, etc., but not the antiquated warning about disc brakes.
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
    Re: which spokes?
    Use Sapim's aluminum nipples, and mark one side of the spoke just above the nipple. They don't wind up nearly as bad as you might think, and if you're even somewhat competent as a builder, it's absolutely no issue.
    Nov 2012
    cool, lasers it is. Thanks for the input guys.
    turtles make me hot
    As long as you use plenty of lube when you build wheels, windup isn't a big deal.
    There's also those wrenches that hold flat spokes from spinning while you turn the nipple.
    I like turtles
  1. 32 spokes VS 36 spokes - Big Difference?
    By 4nbstd in forum Clydesdales/Tall Riders
    Last Post: 01-02-2018, 01:41 AM
  2. Replies: 1
    Last Post: 06-12-2014, 04:02 PM
  3. Replies: 9
    Last Post: 04-10-2013, 08:35 AM
  4. Replies: 6
    Last Post: 10-04-2012, 12:54 PM
  5. Titanium spokes vs stainess steel spokes
    By ayjay69 in forum Weight Weenies
    Last Post: 02-11-2012, 08:26 PM
