Results 1 to 9 of 9
    Jun 2012
    Spoke problems and a dumb question
    Hey everyone,
    I need some advice/experience/knowledge.
    I purchased a Giant Rapid from a fellow rider and I've had nothing but problems with the rear wheel. Every ride I have at least one spoke come undone (as in, it just unscrews from the nipple and the nipple falls into the rim) I've put the nipples back on and taken it to be trued several times (4 in a month) The last time I took it in, the mechanic, finally noticed that the wheel was not laced properly. By properly, I mean that the drive side of the wheel (where the cassette is) is laced 3-cross pattern. The non-drive side is straight spokes. The wheel is just the basic rim, hub and spokes straight from Giant. As far as the previous owner knows, the wheel was never rebuilt and this is the way it came from the factory.
    Now my questions:
    1. What could be causing the nipples to unscrew from the spokes?
    2. Is it normal or strange that the wheel is laced 3 cross on one side and straight laced on the other?
    Please help me out if you can.
    Thank you
    Goran
    It's about showing up.
    Reputation: Berkeley Mike's Avatar
    Blue sky guess? Uneven support due to the different lacing patter on different sides causing lateral torque at the wheel plane, slowly spinning the spoke out of the nipple.
    I don't rattle.
    turtles make me hot
    Reputation: NYrr496's Avatar
    If it were me, I'd relace the wheel three cross on both sides.
    I like turtles
    Reputation: shiggy's Avatar
    Dec 1998
    Re: Spoke problems and a dumb question
    Quote Originally Posted by Goran13 View Post
    Hey everyone,
    Now my questions:
    Thank you
    Goran
    The wheel is laced as Giant intended. Not uncommon for road wheels to use radial non drive side lacing. When built/tensioned correctly it can be more durable, in addition to being lighter and more aerodynamic. Sounds like yours was not built very well and/or was somewhat abused before you got it.
    The wheel needs--at the very least--to be completely retensioned, not just trued.
    mtbtires.com
    Jun 2012
    Thank you folks for all your help. At first the shop really psyched me out when they told me that the lacing wasn't correct. I figured Giant wouldn't do something like that. I wasn't really sure what is right or wrong. Thank you again.
    I will be asking to get the wheel retensioned and trued.
    At worst, if it doesn't continue to work well after the work, I will just have it relaced.
    Dec 1998
    If you can not do the work yourself, I would look for a different shop based on their opinions of the lacing.
    mtbtires.com
    Jun 2012
    Quote Originally Posted by shiggy View Post
    Unfortunately wheels are out of my reach, I don't have the proper tools or knowhow to out it together, but I did think about taking it to a different shop and that is what I'm doing. They have more experience with road bikes, so I'm hoping their wheel man can figure it out.
    Thanks again.
    Mar 2011
    Roger Musson has a good ebook on it. Re-tensioning a wheel is not rocket science as long as you have at least 3 fingers on each hand to hold a spoke wrench and they are not glued together. Good Luck
    Wheelbuilding book for building bicycle wheels
    Thanks again.
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    ^^ this
    ^^ and this
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
  1. A dumb question from a dumb person
    By sandwich in forum Scott Sports
    Last Post: 05-23-2014, 11:21 AM
  2. Replies: 6
    Last Post: 08-24-2013, 06:12 PM
  3. DT Swiss FR600 + Hope Pro2 Evo spoke length problems/solutions
    By charging_rhinos in forum Wheels and Tires
    Last Post: 04-22-2013, 09:44 AM
  4. Question on Spoke Guage and Hub spoke eyelets
    By judd1980 in forum Wheels and Tires
    Last Post: 05-17-2011, 09:22 AM
  5. Paired Spoke wheel problems
    By cjn1014 in forum Wheels and Tires
    Last Post: 01-16-2011, 10:45 PM
