Results 1 to 2 of 2
    metrotuned WoS
    Reputation: illnacord's Avatar
    Caution;  Merge;  Workers Ahead! Spoke Lengths Chris King ISO / Phil ISO ERD 603mm
    Wheelbuilder experts, I'm still scarred from miscalculating spoke length on my last wheelbuild. Can you please help me with the spoke lengths or the best website to calculate the spoke lengths for the following wheel builds?
    1) Chris King ISO 15mm Large Diameter LD front to ERD 603mm rim
    2) Chris King ISO Single Speed rear to ERD 603mm rim
    3) Phil Wood ISO front to ERD 603mm rim.
    All 3x pattern on 32h, double butted 2.0-1.8-2.0 Phil spokes with brass nipples.
    I've attached the hub specs directly from manufacturer.
    Attached Thumbnails Attached Thumbnails Spoke Lengths Chris King ISO / Phil ISO ERD 603mm-wheelbuilds-2012-mtbr.jpg
    metrotuned WoS
    Oh and the nipples are 12mm. I heard in some instances e.g. DT Swiss, the ERD is calculated with 16mm nipples. Not the case here, with only 20mm deep rims, using 12mm brass nipples.
