Results 1 to 10 of 10
    spoke length: ZTR Flow 29er + Hope II Evo front
    dear all,
    quick question, anybody knows what spoke lenght to go for a ZTR Flow 29er (!) rim and Hope II Evo hub for front?
    Thanks a lot,
    Björn
    I would use 290 291
    If your goin flow then I would us some straight gauge wheel smith spokes or some dt comp's
    Some Dude
    Reputation: ccs1676's Avatar
    Quote Originally Posted by brettsportler View Post
    dear all,
    Thanks a lot,
    Björn
    Did you figure out what spoke length to get? I'm about to build up a flow/hope ss wheelset and still need to get my spokes. I guess I might end up using a spoke calculator...
    hi there,
    I calculated 289,7mm on the one side and 291,8mm on the other side. Hope this works, didn´t find the time to build the wheel so far...
    NoTubes.com
    We use 290mm left, and 291mm right on a regular basis for this build laced 3x.
    http://www.notubes.com/literature/hu...ke%20chart.pdf
    Please do not use the forum PM or e-mail function for business related questions. I can be contacted through our website. Thanks!
    NoTubes.com
    Reputation: Shalom's Avatar
    Nov 2008
    290 and 291 for 3x lacing.
    I built mine using Wheesmith DB14 spokes with 12 mm alu nipples.
    Best of luck on your build.
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    290/292 is a better match up front.
    290/291 is ideal out back, but 290/292 works fine too.
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
    dear all,
    thanks for your many replies. I just got info from my LBS that unfortunately the 290mm spokes that I want are not available for quite some time. would it be possible to use either 292/292mm or 288/292mm up front?
    Thanks,
    Björn
    dear all,
    Thanks,
    Björn
    I would not.
    Buy them elsewhere or wait.
    Reputation: 4slomo's Avatar
    If your LBS has a spoke cutter machine, you can have them cut longer spokes down to 290 mm and roll the threads a little longer. I frequently have that done rather than wait.
    dear all,
    Thanks,
    Björn
    Hey everybody, ride my wheels! They ride good, real good.
    I'm a wheel builder. SRLPE Wheel Works. Send me a PM.
  1. Shimano Nexus 3 speed on Flow 36H spoke length?
    By dblspeed in forum 29er Bikes
    Last Post: 09-07-2011, 11:42 AM
  2. spoke length for king hubs and flow rims
    By onegeargood in forum 29er Bikes
    Last Post: 08-26-2009, 09:07 PM
  3. hope big un spoke length
    By rize5boyuk in forum Wheels and Tires
    Last Post: 03-19-2009, 11:12 AM
  4. 150 mm hope hub spoke length
    By njhcx4xlife in forum Wheels and Tires
    Last Post: 12-15-2006, 11:54 AM
  5. Spoke length on 717 and Hope XC...
    By TOEHEAD in forum Wheels and Tires
    Last Post: 08-24-2006, 06:58 PM
