• 01-21-2013
    Bill-E-BoB
    So SLOW now!! Recommendations?
    Hey guys, having some trouble picking the right tires apparently...I thought I had researched it all to perfection & landed on the perfect set...but I didn't. I'm on a 26" Giant Anthem2, and for the past 2 seasons I had been riding a set of Michelin Dry x2 2.0" tires front & rear. My biggest complaint with 'em was grip, they'd wash out in corners, slip on roots & rocks, and if there was any mud, fugettaboutit! I had to air 'em down to 24 & 26 psi to get decent traction, but then kept getting pinch flats.
    So, I decided its time to convert to tubeless & get a new set of tires that won't slip so bad. Bugged entirely too many riders on local trails, read entirely too many reviews, and thought I had picked the perfect tires. decided on a Maxxis Ignitor UST 2.35 in front & 2.10 in back. Converted to Stan's with relative ease for a first timer & anxiously hit the trail.
    I was AMAZED at how grippy they were. First ride was on a particularly muddy day & I had control like it was bone dry, loved it! But I couldn't keep up with my buddies. Figured it was just lazy winter legs & a trail I don't ride as often. Since then I've been to my more regular trails a couple times solo & I'm working harder to get moving, people are catching up to me, and I find myself on the middle chain ring for stretches I always used to go big & I'm still gasping for it. This is not conditioning...the bike is slow now! I love the grip, but come on...I can't slow down to achieve it. They're noticeably heavier than the michelin's were...maybe this is the tire itself, maybe it's the stan's, I dunno, but my bet is the tire is the culprit.
    What do you guys suggest? I'm thinking I keep the 2.35 Ignitor on the front for its awesome grip, but put something faster on the rear? Small block 8? Crossmark? Nevegal? I hear people suggest lots of tires, my goal originally was as much grip as possible, I guess I should've been shopping for a balance of grip & speed.
  • 01-22-2013
    Mr.P
    The Michelin Dry you were running before is one of the fastest rolling tires available, so moving to a different tire will most likely be a slow down.
    Perhaps look to a Michelin Race'r in their single compound (not Advanced). They are a replacement for the Dry tires and cornering is pretty amazing. They suffer a bit in techy climbs, loose braking and greasy mud.
    P
  • 01-22-2013
    Vespasianus
    P
    Why not the Advanced version?
  • 01-22-2013
    Millfox
    Agreed. Go advancer or else you'll have a bit of a problem on wet wood.
  • 01-22-2013
    Mr.P
    Advanced use a softer rubber cap over the harder rubber. So they roll a touch slower, and on the rear wear out faster. I got 3 months out of a Race'r 2.25 UST Advanced - it wore quick on the rear. The softer rubber = higher grip tho, notably in conditions like Millfox point out.
    P
  • 01-22-2013
    Bill-E-BoB
    I've never mixed & matched tires before, but lots of people seem to do that, would it make sense to try the Race'r or something similar on the rear & keep the Ignitor up front for grip, or does the front tire slow you down a lot too when it's too knobby?
    So many people locally have talked about the nevagal & smallblock 8...anybody know how they stack up against the Dry I had before for speed & the Ignitor I have now for grip?
  • 01-22-2013
    Mr.P
    Nevegal is sloooooow. But very grippy. SB8 is slower than the Michelin tires but it also grips way beyond it's looks. I've run both the Dry2 and SB8.
    P
  • 01-22-2013
    Vespasianus
    P
    Gotcha. Thanks.
  • 01-22-2013
    fsrxc
    A grippy/slow rear tire will slow you down more than a grippy/slow front tire. In fact, a fast/less grippy front tire can make you slower in the twisty stuff.
  • 01-22-2013
    RollingWanderer
    I agree the Nevegal is a slow rolling tire!
    I just switched to Conti X-Kings, but only have 1 ride in on them...so far I'm happy, they roll nice, corner well and have good traction. I have not tested them in the mud yet.
    -RW
  • 01-22-2013
    One Pivot
    The 2.1 ignitor isnt a slow tire though. If you're feeling serious drag with that setup, something else might be wrong.
  • 01-23-2013
    Sideknob
    Try a 2.1 Monorail. I tried the 2.1 Ignitor as a rear and it was nothing special in any respect - and the volume was small for a 2.1
    I like Maxxis tyres but I'm not a fan of the Ignitor.
    The Ikon 2.2 is another faster rolling rear with good volume.
  • 01-23-2013
    Bill-E-BoB
    I picked up a 2.1 Crossmark to try on the rear last night, looks like it'll have tons less resistance to it & I got it cheap from a local rider so its cheaper to test than buying another new tire..unfortunately it's not the UST and the sidewalls are wayyyy too soft for me to get mounted tubeless with a floor pump so I took it to a bike shop today at lunch to use their compressor & they couldn't do it either. I'm just going to try it with a tube when I get home from work & see if I even like the tire.
    Really? Cuz seriously it's like I'm dragging a parachute. What else could be wrong? All that changed was the tires...I taped the rims, put the tires on & added stans, & that's it. What could I have screwed up?
  • 01-23-2013
    Mr.P
    Some Ignitors are a fasst 70a, some are a softer & slower 60a rubber. They also have a bit spikey knobs which penetrate the ground - this can feel very slow in damp, winter, soft ground.
    P
  • 01-23-2013
    Bill-E-BoB
    Hmm, interesting. Mine are 70a, so I'm glad I didn't get the slower compound...The ground right now is definitely damp winter soft ground though...there's been so much rain lately they even closed the trails for 2 days to let it dry out a bit after last weeks rain. The first day I ran the new tires was down right sloshy mud, never would've even made it through some sections with the old dry x2's I was running. It seemed relatively dry to me the next 2 runs, though I'm sure it wasn't dry like summer time. Even so, nobody else in my group slowed down like I did.
  • 01-23-2013
    The Understater
    What rims are you running? I'm now using Easton Haven carbon rims, so no tape required, but I didn't want to suffer the weight penalty of a genuine UST tire, and in my conditions I don't need thick sidewalls. The couple of hundred grams I save by not going UST is hugely noticeable on the trail.
    I fitted a brand new Maxxis Aspen 2.25 tire front, and my used 2.1 Crossmark on the back. The new Aspen had a nice tight bead and aired up perfectly with a gas station pump. The bead on the Crossmark wasn't quite as tight after a few months riding, so I filleted 20" tube, cut out the shraeder valve and stretched it around the back rim. (ghetto styles) The UST valve fitted through the hole and sealed nicely. This allowed me to get a really nice tight fit with the back tire, and that too aired up easily and sealed immediately with minimal weight penalty.
    I do recommend the Aspen as a fast rolling tire with good volume that grips a lot better than the low knobs would lead you to expect.
  • 01-23-2013
    Jeff in Bend
    You went from a x/c race tread, 600 gram tire front and year - to a more aggressive tread 835g F / 700g R. The one place you could lose some weight is to not get UST tires. UST tires are for UST rims that don't use sealant. Most tires now are tubeless ready, which means they have a bead that is designed for tubeless applications but they require sealant. You can't have it both ways, there's always a compromise between fast rolling and grip, but you're not going anywhere fast if your on the ground or walking your bike.
  • 01-23-2013
    tailwaters
    I just picked up a set of the Michelin Racer'r tires and mounted them up tubeless last week. Of course no sooner than I mounted the new rubber and our temps dropped near 0 degs and we picked up about 6 inches of snow. So now I'll need to wait a week or so for things to warm up again back into the 30's. If you do order a set of the Michelin's be careful on the size. I ordered the 2.1 and after a couple days the now measure 2.2. Only comment I can make right now is they are very easy to track stand on.
  • 01-23-2013
    Bill-E-BoB
    I've got Mavic Crossrides, cleaned 'em & put Stan's yellow rim tape on & had no problem at all mounting the Ignitor UST's, even with a floor pump it was easy peazy. They sealed up well & didn't leak at all. For now I'm leaving the 2.35 Ignitor on the front while I sort out what to do with the rear.
    The 2.1 Crossmark I got for it has about 6 miles on it, shipped with a new Santa Cruz & the guy I got it from swapped to some other tire & didn't need it. It's not UST & I can't get both sides of the bead to sit up on the bead shelf no matter what I try...neither could the dude at the bike shop. I guess the difference in beads designed for tubeless is that when the tire is at rest it wants to pull open? This Crossmark & my Michelin's both just collapse in so the beads touch each other when not on a rim. The UST ignitors spread wide, so getting 'em to seal against the bead shelf was easy.
    The Aspen sounds great, took a look on Maxxis's website & they have a video with riders saying all the things I wish I could say about my tires. :)
    Help me understand the weight thing...I know these are dumb questions but it's all new territory for me. if I had a 600g tire with a tube in it, aren't tubes around 250-300g? I don't know what the yellow rim tape weighs vs what I had before but it can't be much & if stans is the same density as water, that was probably only 80g or so for the sealant...so wouldn't my total weight only be a little more than it was before? Maybe 50g or so? Is the bead of a tubeless ready tire like I described above, where it naturally wants to push outward so its easier to get over the bead shelf?
    I should mention, it *feels* heavier than before, I noticed that as i was putting the tires back on the bike for the first time, and lifting the bike into my truck...but I figured that was in my head because I'm staring at these big ol' knobby tires. Maybe that wasn't my imagination & these things really are super heavy?
  • 01-24-2013
    Jeff in Bend
    [/QUOTE]Help me understand the weight thing...I know these are dumb questions but it's all new territory for me. if I had a 600g tire with a tube in it, aren't tubes around 250-300g? I don't know what the yellow rim tape weighs vs what I had before but it can't be much & if stans is the same density as water, that was probably only 80g or so for the sealant...so wouldn't my total weight only be a little more than it was before? Maybe 50g or so? Is the bead of a tubeless ready tire like I described above, where it naturally wants to push outward so its easier to get over the bead shelf?
    I should mention, it *feels* heavier than before, I noticed that as i was putting the tires back on the bike for the first time, and lifting the bike into my truck...but I figured that was in my head because I'm staring at these big ol' knobby tires. Maybe that wasn't my imagination & these things really are super heavy?[/QUOTE]
    I don't know what a tube weighs. The bottom line is you have a slower rolling tire with much better traction. Quit over thinking it, go ride , and enjoy the traction qualities of your new tires. If you're slower climbing and can't keep up with your buddies get stronger.
  • 01-24-2013
    Bill-E-BoB
    Dude did I catch you on a bad day or something? Your last post was helpful & sounded like you had knowledge I could glean about tire weight. If responding to your post is over-thinking, what's that make your post? If you don't know how the weight of tubes plays into it, don't feel bad, you're no worse off than I was, you don't have to get defensive & start trolling. From what I see in google, yeah a standard bontrager tube is like 250g so unless I'm missing something, the weight difference is negligible...
    Keeping up with my buddies was never an issue before so I highly doubt "get stronger" is the fix. It's a simple issue. Fast tires were washing out too much in the turns, a grippy tire has cut almost 2 minutes off my time on a 7 mile loop, obviously I need to find a happy middle ground & that's why I'm here.
  • 01-24-2013
    Jeff in Bend
    I'm sorry if I came off to you in a negative way it wasn't my intention and I don't think I was being defensive or trolling.
    As I said in my first post there's always a compromise between fast, traction, durability, and cost; only you can figure out where that middle ground is based on your capabilities, trail conditions, expectations, etc. This compromise relates to everything on your bike as well.
    In your OP you said "I was AMAZED at how grippy they were, but I couldn't keep up with my buddies", so getting stronger seemed liked the logical solution.
    You said "my biggest complaint with 'em was grip, they'd wash out in corners, slip on roots & rocks, and if there was any mud, fugettaboutit", were you keeping up with your buddies when this was happening?
    I thought you were over thinking because it seems like a simple issue. A heavier more aggressive tire is going to roll slower with the added benefits of more traction and control. You seem to like these added benefits so enjoy them, pedal harder, get stronger and enjoy the best of both worlds. :)
  • 01-25-2013
    Bill-E-BoB
    Yeah, with the old tires keeping up was no concern at all. When I was slipping on turns & roots, I was catching & passing 'em on fast sections. Only time I couldn't keep up then was on a long wet uphill because I just couldn't get enough traction to make good time.
    Not to be a smartass, but if I were enjoying the slow rolling grip machine, I wouldn't have started this thread in the first place...I'd have started one that said "Wow I love this new set of tires I got and the peace & quiet I get from not keeping up with the group anymore." I'm not going to buy every tire on the market to decide which is right for me when there are hundreds of members here with knowledge to share & help me narrow it down, that's crazy. That Aspen tire sounds great & now that I've had so much input from everybody, I even understand why I want it. :)
    I may still not understand how an 835g UST tire would be heavier than a 600g tire and 250g tube...but I do understand enough about tires now & the various rolling resistance factors and trade offs of more aggressive treads. And I know that if you think "get stronger" is the solution to run as fast on Ignitors as Dry 2s, we should all be on your exercise program because that's a hell of a feat!
  • 01-25-2013
    JeroenK
    He's trying to help you. And I am too: I agree with him you are overthinking this or at least there is too much focus on tires and too little on other aspects of bike riding.
    Next thing you know forum users (with all good intentions) start talking about the rolling resistance differences of rubber compound and stuff like that! Come on... have a look at the bigger picture.
    There is no magic do it all tire. What works best is very personal and depends on the kind of riding and terrain. Tires that are really fast have less grip and are less puncture resistance. Tires that are really grippy are heavier and roll less well.
    Find a good intermediate tire for your trail conditions. If you could ride on those Michelins, but you needed a little more grip, light, supple but allround XC tires will do. Take care they have a little more knob than a semi-slick like the Michelin that you had. That means no Aspens - those will have less grip than the Michelin's.
    Besides tires, when I read a forum question like this, I ask myself: Did he lose grip with the Michelin's because his bike handling needs improvement? Does too high tire pressure have something to do with it? Both pretty consistent with getting dropped on technical stuff and being fast on the easier, fast bits.
    It may also be the case that your mates are riding well below their limits and you are on it. You implied you were as fit as ever, but trust me... I have lots of experience with racers to know that some people just do not pick up the signs of fatigue (or not willing to). Less fitness also does not have to come from too little or too much riding too; stress at work or at home, a lingering virus infection, allergy, too little sleep, ... be honest! (Not trying to pursuade you to write all about your personal life here... That's not my business. Just be open to other factors that could have something to do with it.)
    Please think about this: No rider gets dropped because of the difference between a fast tire and a slow tire, if those tires are in the same league (so XC tires vs XC tires, not XC vs DH). There must be something else. Too much focus on the tires and block the oppertunity for yourself to learn what will improve your riding more than any tire.
    The answer may well be to work on technical skills while on more knobby, but slower tires. Save energy on the technical bits of the trail and have some left to keep up when it's fast.
    Try to find the root cause(s) of what you are experiencing and be honest about them. Chances are it's not the tires, that's what I am trying to tell you.
  • 01-25-2013
    Grinderz
    I have also found that the ignitor to be a slower rolling tyre. As a result I only run it on the front as part of a tubeless setup for the extra grip in corners, and a maxxis crossmark in the rear.
    The crossmark is by far a much quicker rolling tyre, but gets a bit squirrely if you are hooking corners in the mud.
    Currently running a 2.10 Ignitor folding on the front and 2.10 Crossmark EXO folding on the rear and loving this combination. Both are non-UST tyres. The EXO is slightly heavier than the EVO version, however offers double thickness sidewall - a big deal for me as I always seem to attract rear sidewall damage.
    Also worth noting is that the crossmark appears wider than the ignitor, even though they are apparently the same size. Will be running this combination for this years XC season. Last year I ran the RoRo/RaRa combination with great success. If you find the ignitors slow, then steer away from the Neverolls (Nevegals)
    Current setup on my Anthem:
  • 01-25-2013
    Lelandjt
    Kenda SB8 2.35" is a great balance of grip/cushion and rolling resistance/weight but if you ride in loose dirt its knobs may be too small for use in front. My XC/trail bike is on the "big" side with 5.5" travel and dropper post so I like these tires as anything less can't keep up with the rest of the bike but on most courses they can still be competitive in a Pro XC race.
    I see similar large volume, small knob tires from other companies that are probably also a nice balance. In the rear you can switch to one of these with little noticeable loss of grip in most conditions. In the front you'll notice less grip almost everywhere and in loose dirt it might be too much loss to be worth the rolling speed.
    With on-the-fly adjustable suspension, geometry, and seatposts and carbon's ability to get a very capable bike under 25lb tires are really the only compromise that remains between efficiency and handling and I don't see anything coming down the pipe that will change that.
  • 01-25-2013
    Grinderz
    Need to figure out if you want a grippy slow roller or a faster less agressive roller
  • 01-25-2013
    baymoe
    I agree with others that mentioned about compromise. What you had before would be considered by many to be a semi-slick. Ignitors are an out and out XC/Trail tire with grip to back that classification. There's no magic tire that does it all unfortunately.
    Currently running on a pair of Kenda SB8 2.1" and although fast rolling, is a compromise on ultimate grip. Have since upgraded to Continentals X-king 2.4 and 2.2 UST and felt it to be considerably slower rolling (weight being the main contributing factor). It's all about managing your expectation. You've got a great set of tires, go out and enjoy them!
  • 01-25-2013
    mattnmtns
    It all depends on what you want. Grip or fast rolling? I switched to a Ignitor on the rear and a Panaracer Rampage on the front from a crossmark on the rear an older style WTB Weirwolf 2.5 lt on the front. First couple of rides, same thing. I was getting smoked by friends I was usually in front of. At first I said to the hell with it, put the crossmark on the rear, ignitor on front. A fair amount better but I like something wider on the front.
    The the leaves fell and winter slop etc. I put the Ignitor/Rampage combo back on. I'm pretty happy with it. I might be a little slower climbing, but I'm getting used to it. Definitely slower, but the traction and grip is great for this time of the year. FWIW I am running them with tubes. I have also found they roll much better with more PSI probably run the Ignitor around 35, and the rampage around 38 unless its real sloppy then drop it around 32. Doesn't roll as well but grip is unbelievable.
    Once it dries out I'll probably put a crossmark back on the rear, and switch between that weirwolf and an ardent or the new minion depending on the trail.
  • 01-25-2013
    JeroenK
    If your trails do not contain much rock, give the Schwalbe Rocket Ron a go, at at least a 2.25" width. Amazingly grippy, allround but still fast and light tire. One of the best compromises in my book if puncture resistance is not top priority. The compound does well on wet stuff and it's true to size.
    Get some pre-2013 versions. The 2013 edition has lower knobs, which has made it a bit less allround. A good chance to get the older ones a lot cheaper too.
  • 01-25-2013
    baymoe
    I think he's looking for a ust tire.
  • 01-25-2013
    Jeff in Bend
    Aspen may or may not be a good tire for you depending on your capabilities and trails. Similar to the Ardent (which I've used and like) you have to really lay the bike over in the corners. The Aspen won't give you the climbing traction your looking for IMO. The tire will not be very durable, it doesn't come with the exo casing and has thin side walls. It's a lite X/C race tire so it will roll fast.
  • 01-26-2013
    mvdlans
    Aspen would be a good choice I think. Ardent still is quite heavy and has large knobs so a lot more resistance. Maxxis ADvantage might be a good idea as well. I cycled quite a lot on the Advantage, really fast tire. The only problem it couldn't take the rocky punishment I gave it so the knobs started to tear of (Aspen will have the same problem I guess). Changed the Advantage for a set of Fat Alberts Ust, but they were to bulky and a lot of rolling resistance, but an awfull amount of grip. Now back on the Ardents, hope that that one is a good compromise for my riding.
  • 01-28-2013
    Bill-E-BoB
    Thanks to all you guys for all the input, It's been a huge help. I spent this weekend on the Ignitor 2.35 up front & a 2.10 Crossmark in the rear & it felt MUCH more like what I was looking for. Rolls nearly as fast as I was on the Michelin's, but I've got a ton more control than before. This is a good start toward exactly the compromise I was looking for & exactly why I started this thread.
    Jeff & Jeroen, I appreciate your input, I think somehow you just wound up on a tangent that makes this seem like a much more complicated question than it was ever meant to be. I started this thread for the exact opposite purpose of over-thinking it. Debating if conditioning or skill level or type of trail or anything else had anything to do with it is a moot point...none of those variables have changed. Tires are all that changed. Sorry if my reference points confused the question. I only mentioned past experiences to give you reference to "it used to be x but now its y". One day, I do a 6 minute mile, the next day, I do a 6:30 mile. Same legs, same bike, same group, same trail, same weather, different tires. Wasn't over thinking anything, just wanted some tire advice.
