I'm thinking of pulling the trigger on an SLX FM-M665 rear hub. Does anyone know the hub flange diameter?
I've been searching the shimano site, these forums, google, hub lists, etc. and some say 45mm and others 52.8mm. The shimano tech doc says 52.8, but it also lists the rear hub with an OLD of 100mm which is obviously wrong. http://www.shimano.com/publish/cont...rsys-0034-downloadFile.html/07) Hub Specs.pdf
