Sidewall Repair
After tearing a sidewall putting in a new tube only to see it pop out the sidewall (tried the superglue trick didnt work). I am deciding how to prepare for it again, to avoid the long walk back. The obvious choice is to carry a spare tire and tube, but would think to find a better solution. Someone said a dollar bill between the tire and tube is the trick. other tricks for gashes? Are there any products made for this?
Park Tool sell a tire boot but it doesn't take much imagination to come up with something that's free and absolutely just as good.
I carry small patches (maybe 3x2") cut from an old leather or suede coat (purse, handbag, whatever).
A friend carries a piece of folding lawn chair webbing.
A piece of denim jeans will do fine.
Also, keep a couple of wraps of duct tape around your pump. Use a piece of this to hold your tire boot in place. Or even just the duct tape will work. Practice ripping the duct tape with your hands; I carry a tiny, cheap folding knife for the purpose.
I saved two tires for friends on one ride with my suede patch and duct tape.
i have done the third fix in this pink bike article a couple times and had really good results even with good size tears. i found the slime radial patch kit for less than $5 autoparts store for 3-4 patches. my patched tires are running tubeless no issue and i have gone on to completely wear at least one out and the patch was still perfect. just be sure the patch is bonded 100% to the tire.
Talent hits a target no one else can hit; Genius hits a target no one else can see - Arthur Schopenhauer
Sew the gap closed with non waxed dental floss and a baseball stitch. Put shoe goo on the seam and then patch on the inside with a tire boot.
Cut up old tubulars make nice boots. 320 tpi works great.
To get home, the dollar bill, gel or energy bar wrapper, duct tape...they all work.
mtbtires.com
I bought a Schwalbe RaRa with a nice 1" tear on the sidewall. It was cheap on eBay. I sewed it up with 50 pound test braided fishing line, then patched the inside. It runs perfectly fine tubeless and with the low pressures I use. I think carrying a sewing needle and fishing line would be a pretty good idea. Plus, you have a survival kit. You can add a fishing hook or make your needle a fishing hook. Who knows what could happen?
- You may not post replies
- You may not edit your posts
Forum Rules
