Results 1 to 16 of 16
Thread: Side wall tear
    Reputation: telemike's Avatar
    Side wall tear
    I took the tires off of my Cascade Peak this afternoon to finally convert them to tubeless. However, I spotted a 3/8 ths inch tear in the middle of the sidewall on the front tire. It is a WTB Scraper 27.5 x 3.
    I obviously can't go tubeless with this tire so I ordered one asap since none of the local shops had a good replacement.
    I also put a tube patch on the inside of the tire so I can ride tomorrow.
    Is there any way to patch this tire so it is reliable? I'd at least like to keep it as a spare on the camper for my trip to Utah later this month.
    By the way, my last few rides on this bike have been at ROCKville hills park on trails such as the ROCK garden trail. No mystery as to what happened!
    My mantra: Hike, Bike, Paddle, Ski
    I've sewn a couple tires with floss and patch it from the inside with a tube patch. Its not tubeless now, but it'll suffice
    Reputation: Mr Pig's Avatar
    If you ride tame trails a hard-tail (no rear suspension) will be cheaper, more reliable, faster and cheaper to maintain.
    Oct 2011
    Quote Originally Posted by the-one1 View Post
    Works great! I've even managed to keep a tire running tubeless doing this. Got about 500km on an Ardent I sewed up a 1 inch gash in before finally replacing it.
    Quote Originally Posted by Mr Pig View Post
    Mmm. I replied to a different thread and the reply has appeared in this one! Novel.
    Reputation: allthegearnoidea's Avatar
    Mar 2014
    I have had a good deal of success using motorbike tube patches over small tears and nicks in tyres before,
    I am the biketart!
    because GIANT
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    this
    or 95 paracord frankenstitch,
    then an internal long oval patch over the stitching
    "Put your seatbelt back on or get out and sit in the middle of that circle of death." - Johnny Scoot
    damned rocks...
    Reputation: Aglo's Avatar
    Dec 2014
    Did you replied through Tapatalk?
    Quote Originally Posted by Aglo View Post
    No. I don't know what that is.
    damned rocks...
    Dec 2014
    Ok, I asked because it did happened to me one time, and I was using Tapatalk.
    Tapatalk, it's an application for following forums that you used on your phone. Quiet good in my opinion.
    Poe's Law > Godwin's
    Aug 2013
    Yeah butt they're app is not very good at picking the right words.
    Reputation: dirtrider76's Avatar
    Sep 2012
    I usually patch it from the inside then use gorilla glue on the outside to bond the slice together. I've patched numerous tires this way and run them tubeless after.
    I like to fart when I'm in front of you on a climb
    No, I think there was some kind of forum work going on maybe as I kept getting 404 messages.
    Thanks for all the replies. Given the response, I washed the area around the tear with acetone and roughed it up with 220 grit sandpaper. Then, I sewed the tear with button and carpet thread. Next, I liberally worked Amazing Goop into the threads and the rubber around the tear. Lastly, I coated the inside around the tear with goop and put on a patch of denim from some old jeans, coated the other side of the patch with yet more goop, and worked it into the patch. Tomorrow will tell if it holds pressure tubeless but I suspect it will very well.
    Thanks again. This kind of advice is one of the best aspects of MTBR!
    Co Springs
    Reputation: bachman1961's Avatar
    Oct 2013
    I did something called a 'boot' patch I think.
    Found it on the internet and made a big reinforced sidewall support placing inside and against the tire wall then used some gorilla tape.
    I was running tubes and it held so good I forgot all about replacing the tire for a year or more. I kept thinking it'll crap out at some point but I finally tossed it and got some new tires.
    I imagine it's considered a Hail Mary or temporary trail side fix as there was no fancy stitching or sewing. Just quick and simple.
    In the Middle Ages, the biggest mistake was not putting on your armor because you were 'just going down to the corner.'
    I Love my Rize
    Reputation: danoalb's Avatar
    Dec 2005
    trash it, I broke my c4 and c5 due to a catastrophic sidewall failure at high speed. My mantra now is in the trash with a comprised sidewall. All I roll with now must be enduro or more casing. (1000) grams
    Early to bed early to RIZE makes a man healthy, wealthy <(scratch that) and wize.
    RIGHTY on a LEFTY
  1. Complete Tear of ACL, Minor MCL Tear
    By fooldall1 in forum Rider Down, injuries and recovery
    Last Post: 12-12-2015, 09:45 PM
  2. At what point do you replace tires when side knobs begin to tear?
    By meridebikes in forum General Discussion
    Last Post: 12-30-2014, 08:54 PM
  3. Tubeless side tear...
    By Roanoke4 in forum Wheels and Tires
    Last Post: 01-29-2013, 04:37 PM
  4. Replies: 1
    Last Post: 04-27-2011, 07:55 PM
  5. side wall strength
    By DMac1213 in forum Wheels and Tires
    Last Post: 02-18-2011, 03:33 PM
Members who have read this thread: 58
