Results 1 to 5 of 5
    Should changing the axle conversion plugs on my Stan's wheels be this difficult?
    Picked up a set of Stan's Arch's. They came set up for QR and came with the plugs to convert to 15 mm. Holy cow these plugs are in there. They're pretty much impossible to get out. Any suggestions?
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    What have you tried?
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
    Dec 2009
    If you don't need to save the QR plugs, test grab one with pliers or vice grip and try to wiggle it free. If one wont come free in a few seconds then try the other side. When you have one side removed come at the other one from inside with something long and thin (but a little wider than a QR skewer) and tap. A little care and the only thing that will be scratched or damaged will be the QR plugs.
    Reputation: Rhialto's Avatar
    I had the same problem. I cut a thin strip of old inner tube and wrapped it tightly around the adapter. I then clamped some vice grips on the area that I had wrapped and twisted and pulled and pop, it came off. The inner tube saved the adapter from getting mangled by the vice grips but the adapter still came away with some scratches.
    Reputation: rob1035's Avatar
    I greased the O-rings on mine once I got them out, and that made it very easy moving forward. I didn't have too much trouble getting them off initially though, using a skewer to pop them out.
  1. Trouble Drilling Rim - Stan's Conversion
    By tjc4golf in forum Wheels and Tires
    Last Post: 03-08-2014, 03:15 PM
  2. Changing travel without changing Axle to Crown height?
    By jm2e in forum Shocks and Suspension
    Last Post: 11-11-2013, 11:07 AM
  3. Stan's 3.30 thru axle conversion
    By dthomp325 in forum Wheels and Tires
    Last Post: 08-11-2013, 06:04 AM
  4. So difficult to mount Kenda Karma 29 on to Stan Crest
    By Loll in forum Wheels and Tires
    Last Post: 06-18-2012, 05:47 AM
  5. Mavic conversion plugs
    By petey49 in forum 29er Bikes
    Last Post: 10-01-2011, 06:23 PM
