Results 1 to 5 of 5
    Dawgwalker
    Shortening Spokes
    I've been using a Hozan Spoke Cutter to shorten some spokes for a wheel build I'm doing.
    I can roll the threads using a longer spoke as a blank but cutting a clean end is giving me a problem.
    One video used an old Park cable cutter but I don't want to dull mine.
    Anyone using a good method they can share short of buying the $60 Hozan nipper?
    2015 Turner Sultan
    2012 Moots MootoXZ
    2008 Turner Sultan
    2007 Dean Colonel 29r
    2003 Titus Switchblade
    Reputation: zipzit's Avatar
    Aug 2005
    Bench grinder? Every sharpen 1/8" drill bits freehand on your bench grinder? Do that successfully first, then shortening spokes will be very easy.
    Ride da mOOn Moderator
    Reputation: NEPMTBA's Avatar
    Just keep the spoke end your grinding pointed down...
    ...if your using a bench grinder, angling it up will turn it into a mini flying spear... OUCH
    You can use a cut-off wheel and a dremel, a fine tooth file (after using dykes to cut it approximately to length), or even a course whetstone.
    Lots of options, hopefully something that you have on hand.
    No need for anything electric. use a pair of cheap side cutters, then give it a quick file with a standard metal file. Ive done quite a few that way. You just need to knock down the rough edge, a few seconds with a file is enough.
    I sold my hozan because rethreading 64 spokes is just a nightmare. Danscomp gets you exact lengths for dirt cheap.
