Results 1 to 3 of 3
    Reputation: Inquisitor's Avatar
    May 2010
    Shimano rear hub compatibility
    Are the hub shells on Shimano's FH-M525 and FH-M525-A rear hubs identical? I know there are differences in the other parts (freehub body, seals, etc.) but I'm only interested in the hub shell.
    I ask because the my current rear hub (M525) is on its way out (cups, cones, and bearings are all shot), so I bought a replacement with the intention of removing everything short of the shell and swapping it over to the current hub. But when the new hub turned up, it turned out to be an M525-A instead...
    The tech docs detail most of the parts, but don't actually say anything about the hub shell itself:
    https://www.paul-lange.de/support/sh...525-A-3287.pdf
    https://www.bike-components.de/bedie...re/fh-m525.pdf
    Can I assume this means they're the same? I'm reluctant to find out by dismantling it in case I have to return it!
    Frt Range, CO
    Reputation: pursuiter's Avatar
    I have used both hub versions, I think the only difference is the cones, it's easier to adjust the bearings on the A version.
    May 2010
    Thanks, persuiter.
    I took the hub apart and it's pretty much identical, with one exception: the brake-side opening on the newer M525-A is counterbored out to 30mm to allow the seal to fit in (with a 29.3mm bore for the cup). The older M525 just has a 29.3mm plain bore for the bearing cup.
    So, annoyingly, I'm going to have to try and trim the seal down so that it'll fit...
    Some photos:
    http://i.imgur.com/5Akl8MA.jpg
    http://i.imgur.com/CzAYmsV.jpg
  1. Shimano Altus SL-M310 Rear Shifter 7sp compatibility
    By roykeidar in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-26-2015, 02:34 PM
  2. Shimano XTR RD M980 Shifter & Shimano M980/M981/M985/M986 RD Compatibility?
    By Elbastardo in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-27-2014, 12:16 PM
  3. Shimano XT crank requires Shimano Chain? SRAM rear compatibility
    By LookerBob in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-07-2013, 02:05 PM
  4. Shimano shoe and shimano pedal compatibility issue
    By Christopher Robin in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-02-2012, 06:00 AM
  5. Shimano XTR / XT rear drlr cage compatibility
    By vmix in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-07-2011, 01:00 PM
Can't find it? Just search our site!
