Results 1 to 5 of 5
    Shimano HUB Help! FHB-525 PROBLEM - Noob Needs hELp!
    I think my front hub is shot and i'm not sure about the rear. I have the Shimano 525 hubs on front and back. (My bike is a 2008 canondale rush sl 5z). I have never had the bike serviced and I decided to learn how to do it myself now.
    The front axle was a little lose so I hand tightened it up so that the axle has no play but the axle rotates really rough now. If I loosen it any more, there will be lateral play in the wheel.
    I'm wondering what my best options are.
    Do I buy a new hub and rebuild the wheel?
    Build a new wheel set? (is it worth it?)
    If I have to buy a new hub, I'll probably try finding something on craigslist or amazon. I don't really have much of a budget for this- it needs to be on the cheap but at the same time I don't want to put junk on my bike.
    Please let me now if you have any resources that you use to determine the quality of bike components. (I want to be able to know why one hub is better than the other and if its worth the extra money).
    Thanks,
    turtles make me hot
    Reputation: NYrr496's Avatar
    Are you able to lace a new hub to your existing rims and spokes? Those hubs are pretty entry level.
    Cheapest way out of this I can think of is to get a pair of Shimano M529 hubs. They should be identical to yours as far as spoke flange and width and all. Way better internals.
    Yours aren't 36 spoke, are they? The 529 only comes in 32.
    I like turtles
    Shimano's hubs, in my experience, are very difficult to completely toast. An adjustment of as little as a 16th of a turn is enough to go from binding to spinning freely.
    Ideally, you'll want a small amount of axial play with the wheel off, which disappears when the QR is clamped tight.
    Reputation: Bike Whisperer's Avatar
    First things first...6 years is a long time to not service a Shimano hub. You need to pull those things apart and see what's going on.
    Park Tool Co. » ParkTool Blog » Hub Overhaul and Adjustment
    Check those cups and cones. The bearings and cones can be replaced, the cups cannot. If everything looks good I'd still replace the bearings. They're cheap, go Grade 25, 3/16" (20) front and 1/4" (18) rear. Pack some new grease (marine style for best water resistance).
    Reputation: Ronnie's Avatar
    What "wschruba" said. Before spending money on replacing hubs read through the following help article on servicing cup and cone hubs from Park Tool:
    Park Tool Co. ParkTool Blog Hub Overhaul and Adjustment
    I'll bet at most you'll need to buy a cone, some ball bearings and some grease.
    The trouble with having an open mind is that people will insist on trying to put things in it.
  1. '13 Shimano XT shifter problem
    By Son in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-29-2013, 11:13 AM
  2. Problem with Shimano XT br-m785
    By LukeSkywalker in forum Brake Time
    Last Post: 06-08-2013, 06:33 AM
  3. Shimano XT M785 piston problem
    By davidwillis in forum Brake Time
    Last Post: 11-18-2012, 01:48 AM
  4. Shimano LX Problem
    By Prophet Julio in forum Brake Time
    Last Post: 04-22-2011, 02:24 PM
  5. Shimano LX Hydro problem
    By s0ckeyeus in forum Brake Time
    Last Post: 04-19-2011, 01:17 PM
