Results 1 to 2 of 2
    Master of the Universe!
    Sette Hub (20mm) and Axle Conversion Questions
    A few years ago I bought a Sette Seven DH hub from Price Point:
    Sette DH 20mm 32 Hole Hub | Sette | Brand | www.PricePoint.com
    The hub works fine when I am using my Fox36. The problem is at the moment I am riding my hardtail which uses the conventional 9mm QR axle system. My question is for anyone who knows DMR hubs, specifically the Revolver, will the QR adapters fit on this hub?
    Link to the adapters:
    Universal Cycles -- DMR Revolver Hub Adapters
    Hopefully I will have time tomorrow to take the hub apart and measure the axle on the Sette. If needed I can also take pics of the hub with both ends removed so you can compare them with the DMR hub.
    Any help is gladly appreciated, I would hate to need to relace my wheels just to change out a still good hub.
    Can't a guy get bombed and call his ex at 3 in the morning without it meaning something?!
    UPDATE:
    The internal axle is 25mm OD with 8mm of overhang past the bearing race inside the hub. Here are some pics of the hub with caps on and then removed.
    <a href="http://s42.photobucket.com/user/djr8505/media/Backbone%20Install/0625132026_zps51c606d3.jpg.html" target="_blank"><img src="http://i42.photobucket.com/albums/e302/djr8505/Backbone%20Install/0625132026_zps51c606d3.jpg" border="0" alt=" photo 0625132026_zps51c606d3.jpg"/></a>
    <a href="http://s42.photobucket.com/user/djr8505/media/Backbone%20Install/0625132026a_zps0138c2b0.jpg.html" target="_blank"><img src="http://i42.photobucket.com/albums/e302/djr8505/Backbone%20Install/0625132026a_zps0138c2b0.jpg" border="0" alt=" photo 0625132026a_zps0138c2b0.jpg"/></a>
    <a href="http://s42.photobucket.com/user/djr8505/media/Backbone%20Install/0625132028_zpse6ed2679.jpg.html" target="_blank"><img src="http://i42.photobucket.com/albums/e302/djr8505/Backbone%20Install/0625132028_zpse6ed2679.jpg" border="0" alt=" photo 0625132028_zpse6ed2679.jpg"/></a>
    <a href="http://s42.photobucket.com/user/djr8505/media/Backbone%20Install/0625132027_zps945d1fb5.jpg.html" target="_blank"><img src="http://i42.photobucket.com/albums/e302/djr8505/Backbone%20Install/0625132027_zps945d1fb5.jpg" border="0" alt=" photo 0625132027_zps945d1fb5.jpg"/></a>
    So again if anyone happens to have or has used the DMR hubs in the past, do these measurements seem to be in line with their setup?
  1. transporting 20mm axle bikes - dumb questions
    By dirkdaddy in forum All Mountain
    Last Post: 04-07-2013, 09:05 PM
  2. 20mm thru axle conversion to 9mm QR
    By solidfish in forum General Discussion
    Last Post: 11-21-2012, 02:04 PM
  3. 20mm thru axle to 9mm conversion
    By mikoby in forum Wheels and Tires
    Last Post: 09-26-2012, 12:55 AM
  4. Replies: 19
    Last Post: 04-15-2012, 05:34 PM
  5. Help me with 20mm thru axle conversion
    By bigflax925 in forum Wheels and Tires
    Last Post: 06-01-2011, 08:20 AM
