Results 1 to 20 of 20
    Reputation: Thatshowiroll's Avatar
    Jan 2009
    Seeking Sun-Ringle Black Flag Expert Owners.
    I purchased a new wheelset. ďSun-Ringle Black Flag Expert. Stanís Ready.Ē
    Great wheels, but the tires Iím using are super-tight on the rims.
    Iím using tubeless Schwalbe Racing Ralph and Rocket Rons. These are so tight that I had to use steel tire-levers to mount them. This means if I have a catastrophic failure in the bush, Iím walking out. I couldnít just boot the cut, put a tube in, inflate and go.
    Iím hoping itís just the Schwalbes that just donít work with these rims. If you own these rims, have you had the same experience, and what tires are you using?
    ÖAlso, could it be because Iím using a tubeless tire on a non-tubeless rim?
    Reputation: Bike Whisperer's Avatar
    I had a set of the 29er version and ran Specialized Purgatory 2Bliss tires. They mounted fairly easy (though not as easy as my current WTB TCS rims). No metal tire levers needed.
    The Stans BST rims are tighter than standard rims to help convert standard bead tires to tubeless.
    I otherwise had few issues with the wheels. The freehub body bearings needed replacement after a year which was easy enough to do.
    I've ran the Black Flag pros (same rim different hub) with non tubeless Schwalbe Nobby Nics without any issue, in fact I could nearly mount them without levers. I found that UST Tioga Psycho genius and the 2Bliss Specialized S-Wrks Ground Control were quite a bit tougher to mount but not impossible.
    Why don't you carry a couple of extra levers on your ride? The yellow pedros ones weigh next to nothing and are nearly indestructable.
    Jan 2009
    Carrying levers is a good suggestion but it would probably still not be enough. Seeing as I broke 2 Park Tool levers and used a C-clamp to mount the Schwalbes.
    I suspect the larger tubeless bead might be the problem. As suggested, I might try the non-tubeless Schwalbes.
    I know this will sound obvious, but just make sure to use some sealant and the non-tubeless Shwalbes should work fine on those rims. I never had a tire blow off the rim.
    Crank Brothers Speedier Levers are great. It takes brute force and cursing.... my Arch EX + Specialized Renegade Control & The Captain Control have super tight beads.... and those levers I have found work best.
    I had the same experience on the black flag expert with Conti X-king protection tires. I've since switched to Specialized Purgatory grid. It was a lot easier to mount.
    Jan 2009
    Quote Originally Posted by jworx View Post
    Was the Specialized a UST or Tubeless ready?
    Quote Originally Posted by thatshowiroll View Post
    was the specialized a ust or tubeless ready?
    ust
    Reputation: NoVA_JB's Avatar
    I'm having the same issues brand new Black Flag 26" and have tried 3 tires but cannot get the last 3-4 inches seated. I've never had this problem with any other rims.
    Jan 2009
    I ended up with a set of Maxxis Ikons as suggested here. Slips on with a little bit of resistance like a tire should, but not excessively tight.
    Oct 2011
    Common problem with Stan's and sun-ringles using the Stan's design.
    Once your tire is on, the bead will stretch and be much easier to mount next time.
    Oct 2011
    And yes, UST or tubeless- ready tires can be particularly hard to mount. They tend to have a beefier bead. I always use regular tires with my Stan's wheelset.
    Jan 2009
    Quote Originally Posted by spillway View Post
    once your tire is on, the bead will stretch and be much easier to mount next time.
    Bead may stretch, but not enough.
    I've spent 2 nights and about ready to throw them in the trash. At this point is it possible to pull out the yellow strip and run with a tube?
    Jan 2009
    Yes, you can run a tube. I've got tubes in right now because I haven't had the time to set up tubeless.
    ...but, like we learned in this thread, consider switching tires.
    I'm really regretting buying these wheels, if I'm having this problem in my house what's going to happen if I get a flat in the woods? I wasn't expecting to be limited on tire choices and not feeling like dropping an extra $100 with the hopes the Maxxis fit.
    Jan 2009
    Quote Originally Posted by NoVA_JB View Post
    My new Ikons were easy to slip over the rim, and were easy to set up for tubeless. Thanks MTBR friends.
    I finally picked up some Schwalbe Hans Dampf tires that fit like a charm. One question are the freewheels supposed to have such a loud ticking when coasting? I'm assuming it's the pawl spring I've just never had one so loud before.
    Jan 2009
    [QUOTE=. One question are the freewheels supposed to have such a loud ticking when coasting?[/QUOTE]
    Yup! I love that sound. You don't have to yell, "on your left". :-D
  1. Sun ringle black flag expert hub bearing replacement
    By oldfatslow in forum Wheels and Tires
    Last Post: 11-23-2014, 07:10 AM
  2. Sun Ringle Black Flag Pro $350.00
    By BlackMamba2012 in forum Where are the Best Deals?
    Last Post: 11-27-2013, 10:32 AM
  3. Sun Ringle Black Flag Expert 29er Wheelset Review....
    By bing! in forum Wheels and Tires
    Last Post: 04-29-2013, 05:30 AM
  4. Replies: 10
    Last Post: 01-17-2013, 06:14 AM
  5. Sun Ringle Black Flag Expert 29" Wheelset
    By Bucktown in forum Wheels and Tires
    Last Post: 06-02-2011, 10:13 PM
