Results 1 to 10 of 10
    Oct 2013
    New question here. Schwalbe Racing Ralph vs. Continental X-King?
    I'm about to replace my RaRa, but my no one in town carries Schwalbe. My LBS recommended Conti X-King. I love the low rolling resistance and speed from the RaRa's. I was wondering if the X-Kings will be as fast. Anyone have experience with both? Thanks.
    Dec 2009
    Very close and wear better.
    change is good
    Sep 2004
    Quote Originally Posted by gvs_nz View Post
    But pinch flat easily and not as supple.
    Oct 2013
    Re: Schwalbe Racing Ralph vs. Continental X-King?
    Quote Originally Posted by DrDon View Post
    Don: are you saying the Contis pinch flat easily and not as supple as the RaRa's?
    Reputation: jrastories's Avatar
    I would agree, when I was running tunes they would punch flat easier and I would have to run higher pressure. But then I went tubeless on stans rims and they are amazing, I gave been running rara's for the last year and I have decided to go back to conti's I find they stick better to the wet.
    Sent from my SGH-I747M using Tapatalk
    Rocky Element
    My Attempt at a Blog
    I would say X-King is more of a Rocket Ron rang, just much much worse (rolls slower then Rocket Ron and has A LOT less grip then Rocket Ron). Conti's "substitution" for Racing Ralph would be Race King, which actually rolls faster then Racing Ralph, but it has a bit less grip too. So there's not really exactly same tire in Conti line as Racing Ralph is.
    I was on Conti last year (before I was long time on Schwalbe with first Racing Ralph from/rear, then Racing Ralph rear, Rocket Ron front, and this year I'm back on Schwalbe with Rocket Ron/Thunder Burt combo), and Race King was great tire for rear (I changed it with Schwalbe's Thunder Burt this year), but I really hated X-King. It's relatively slow (much slower then Rocket Ron, and even more then Racing Ralph), and on gravel it has basically zero grip compared to Rocket Ron (it would probably be somewhere in range of Racing Ralph for gravel, but I has been too long since my last ride with RaRa on front to be objective).
    So my suggestion, get Schwalbe from some online store, as it's much better choice. Only good thing with Conti is, they seems to last longer then Schwalbe.
    PS: This what I wrote goes for Conti Race King and X-King Protection version, so it might be different with RaceSport version or non-black chilli tires.
    Primoz
    change is good
    Sep 2004
    Quote Originally Posted by BodegaBay View Post
    Yes, the Protection versions. MKII x 2, RK x 1, XK x 2. I like the tread designs although i think the RoRo does better in wet conditions although neither is stellar.
    change is good
    Sep 2004
    PS - most around here run Contis without issue, but others had issues with flatting and sealant oozing. I've read posts regarding case warping and losing knobs although the last issue seems to have been corrected.
    Jun 2014
    About the pinch flat issue: Schwalbe 2.25 is much larger than Speed King 2.2, so obviously the Schwalbe will pinch flat less (same pressure).
    But the Conti 2.4s are only a bit larger than Schwalbe 2.25 and don't pinch any easier.
    Light Conti tires are notoriously tricky to set up tubeless, so that is something to keep in mind.
    Around here, Schwalbe tires are known for ripping knobs and wearing fast. Less issues with Contis. However, both are using relatively soft tacky rubber which can disintegrate if pushed hard on sharp rocks.
    Reputation: engrmariano's Avatar
    i've been using RaRa 2.25 (evo front / perf rear) & x-king 2.4 (cheapest variant).
    rolling resistance & grip, i cant tell the difference when switching in between.
    RaRa's life is too short & i get occasional punctures (im not in tubeless). x-king, i havnt had a puncture & lasts longer.
    now my x-king is almost a year old & swapped front & rear to get a balanced thread, but it needs replacement. i'm going to use RaRa's & setup tubeless at the moment to get the remaining life out of it. but definitively will be still using x-king (may be 2.2) protection on my next set.
    PIVOT
  1. Schwalbe Racing Ralph 650
    By ride424 in forum 27.5
    Last Post: 10-28-2012, 01:39 PM
  2. Diference between Schwalbe Racing Ralph HS 425 and HS 391
    By MrSparklle in forum Wheels and Tires
    Last Post: 06-11-2012, 07:28 PM
  3. Schwalbe Rocket Ron vs. Racing Ralph
    By seppk in forum Weight Weenies
    Last Post: 06-05-2012, 08:21 AM
  4. Schwalbe Racing Ralph
    By JasonByers in forum Singlespeed
    Last Post: 06-28-2011, 05:29 PM
  5. Replies: 4
    Last Post: 06-14-2011, 05:42 PM
Members who have read this thread: 13
