Results 1 to 31 of 31
    Aug 2010
    School me on Maxxis tires
    I need to buy some new tires pretty quickly but have been a Schwalbe guy for years.
    I know enough about Maxxis to be intrigued, but not enough to make a selection.
    Looking to be brought up to speed on Maxxis terminology (casing, compound, etc) so I can make an informed decision.
    I’d also like to know if/how I can get versions without the yellow logo on the sidewall.
    LDC is ded,deth by trollz
    Nov 2015
    Start with the maxxis website lol. They explain every terminology. White ones i think are oem only. You can use a marker and black out the yellow.
    End of thread.
    turtles make me hot
    Reputation: NYrr496's Avatar
    Which ones do you like? I had Ardents once and I don't think they had the giant yellow Maxxis on them. They were good tires.
    That's why they make black sharpies. Haha! Sup, man?
    I like turtles
    Aug 2010
    Quote Originally Posted by NYrr496 View Post
    Thinking Minion DHF front. Not sure about rear yet.
    Quote Originally Posted by racefit View Post
    Different compounds for different terrain and weather also. The 42a/ supertacky or 3c is good for grip but wears quickly. Great tire nevertheless.
    May 2017
    worldwide cyclery just did a video on this on youtube
    Reputation: Timothy G. Parrish's Avatar
    Apr 2014
    Quote Originally Posted by LaneDetroitCity View Post
    End of thread.
    This. Website covers it all. White is OEM only.
    Sent from my MotoG3 using Tapatalk
    Oct 2015
    Prepare for disappointment
    Aug 2010
    Quote Originally Posted by GRPABT1 View Post
    In what?
    2.5 DHF or shorty Front, EXO casing 3C Maxterra if you want a softer tire but it will increase drag
    2.4 DHR or 2.35/2.5 Aggressor, w/casing Double Down=Super Grav
    You can usually find great deals on DHF/DHR combos on ebay & pinkbike.
    Barely in control
    Reputation: Schulze's Avatar
    Feb 2007
    Usually undersized, wear out fast, cost a premium. But they have a huge amount of random tread patterns and a huge yellow logo so they must be good.
    turtles make me hot
    Ever taken a look at the Specialized Butcher Grid?
    I like turtles
    May 2010
    I was a schwable guy also until just recently. I loved how light Schwable were for the grip and i could always find them on discount. I have a closet full of Nobby Nics, Hans Dampf, and Rocket Ron's. I just recently moved to maxxis on my Devinci Troy 150/140mm to 3C Maxx Terra DHF 2.6 front and Rekon 2.6 rear.
    I notice they have a lot more traction but they are definitely heavier and have more rolling resistance. Where i ride there is a lot of sugar sand and no sharp rocks so longevity has never been an issue for me and the wider tire helps float over sand.
    It may not be a completely fair comparison since i moved from 2.35 to 2.6 but i really like the maxxis even though they have the yellow lettering.
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    Quote Originally Posted by Schulze View Post
    wear out fast, cost a premium. But they have a huge amount of random tread patterns.
    OP says he is used to Schwalbe......Maxxis will seem like a bargain.
    I resolve to constantly assert my honest opinion on anything and everything - whether it is requested or not.
    Bucky the Cat
    Sir Shreds-A-Lot
    Reputation: trekninja's Avatar
    Oct 2007
    this is funny. what tires do you use that are so otherwordly?
    1985 Trek 670
    2016 Kona Process 111
    2017 Ritchey P29er
    2018 Trek Domane SL6
    Sir Shreds-A-Lot
    Oct 2007
    wtb makes some nice tires with low key print on the sides
    1985 Trek 670
    2017 Ritchey P29er
    Nov 2015
    Quote Originally Posted by trekninja View Post
    Bontrager. Lighter faster bigger cheaper by 30 retail.
    Sir Shreds-A-Lot
    Oct 2007
    ive run plenty of bontager. good tires, they arent close to a dhf though. and for real, if you cant find a maxxis for under $50, youre not trying
    1985 Trek 670
    2017 Ritchey P29er
    Nov 2015
    Post a link of a new mxxis dhf under 50 shipped. Youre using gross generalizations, stating "they" arent as good as a dhf though. Comparing a whole tire line to a single offering. No, Bomtrager doesnt makena motorcycle tire for bikes you are correct, however they make plenty of good offerings. Hes coming from Schwalbe which also doesnt make a tire comprable to the DHF. So basically this thread is devolving into just another tire argument when the op actual auestions were answered in the first reply.
    I don't know if you're a window licker or if you've been living under rock for the last 10 years, but Schwalbe makes a tire called the Magic Mary that's a direct competitor to the DHF.
    Jan 2014
    I'd never really noticed that the OEM tires have white logos and the aftermarket ones yellow. If it's the same tire, why the difference ?
    Aug 2010
    Yes, wasn’t looking to start a which is better thread. Just some info on Maxxis acronyms with maybe a little general commentary added in.
    Sep 2014
    EXO=tougher casing, best if you don't want flats
    3C=triple compound; MaxxGrip=best grip, MaxxTerra=blend of grip and speed, MaxxSpeed=fastest
    DC=Dual Compound
    TR=Tubeless Ready
    DHF=DownHill Front (but can be used front or rear, most use as a front)
    DHR, DHRII=DownHill Rear (OG and newer one), see above
    You can't buy happiness. But you can buy a bike. And that's pretty close.
    SS Pusher Man
    Sep 2001
    Maxxis Minion DHF 29 x 2.5 EXO Tubeless Ready Tire in Tree Fort Bikes 29'' Tires
    Maxxis Minion DHR II 29 x 2.3 EXO Tubeless Ready Tire in Tree Fort Bikes 29'' Tires
    https://www.trekbikes.com/us/en_US/e...olorCode=black
    My biggest issue with Maxxis vs. Bontrager is availablility. I can go into just about any LBS and find a Maxxis tire....whereas I went to several different Trek dealers for a couple different Bonty tires....every shop only had a couple tires total. Let alone the ones I was looking for. Yeah, I could have ordered them online, paid full retail of $75 + overpriced shipping.
    I used to work for a Trek dealer....not impressed with their tires.
    Bucky the Cat
    Ride Fast Take Chances :)
    Reputation: alexbn921's Avatar
    Quote Originally Posted by BmanInTheD View Post
    DC=Dual Compound
    TR=Tubeless Ready
    https://singletrackworld.com/2017/07...rail-3c-tyres/
    "Traditionally, DHF = Front, and DHR = Rear. Well actually, the ‘F’ originally stood for ‘Freeride’, and the ‘R’ stood for ‘Race’."
    Most including myself use it as front and rear thought.
    Making shit harder than it needs to be isn't awesome, it's just...harder.
    Sep 2014
    Quote Originally Posted by alexbn921 View Post
    "Actually, there are two primary problems with the original DHR: when buying a 2.5 Minion DHF and a 2.5 Minion DHR, the DHR is bigger, which is absurd. And yes, the “F” and “R” designations do stand for Front and Rear. Don’t let some clueless choad on an internet forum tell you differently. Anyone who knows how tires work can obviously see that these were designed as a front and rear, respectively."
    Straight from an article by Blistergearreview, one of the best online sources for mountain activities:
    Maxxis Minion DHR2 | Blister Gear Review - Skis, Snowboards, Mountain Bikes, Climbing, Kayaking
    Reputation: beer_coffee_water's Avatar
    Mar 2011
    I just bought a set of Maxxis, 2.5 DHF DC and 2.5 Aggressor DC both in EXO sidewalls, from Amazon for $104 shipped. DC Maxxis are in the low $50 range while the 3C tires are mid $60 range. Maxxis tires are less costly and more durable than Schwalbes from what I have seen.
    I went with dual compound because they work better in the loose conditions I get to ride. If I had more rock on my trail I would have opted for a 3C MaxxTerra DHF. I'll run either Double Down (2-ply sidewall) or a DH casing when I head to the parks this year. I tried Michelin Rock'r and Grip'r combo but they just aren't as good in the grip department leading to vague feelings in the corners and much heavier.
    I am impressed with the Aggressor out back where I normally run a DHR II. It doesn't brake as well or dig as deep on the climbs but it still does those jobs well and rolls faster. I am out of shape so far but was able to get get a few super steep lengthy climbs while out on the Aggressor the first time. I am definitely happy to be back on DHF. It is my go to front tire. It is the king of grip for me and that is all I want from a front tire. This tire combo is on the heavy side. Mine weighed 933g for the DHF and 946g for the Aggressor but about a 300g lighter than the Miche's.
    Nov 2015
    Quote Originally Posted by mtnbikej View Post
    52 plus shipping is not under 50 shipped. Bontrager tires team issue are 55. Your story makes no sense. Youll walk into a shop and pay retail 70 for a maxxis but not order a 55 dollar bontrager, oh wait you order 52 dollar maxxis online lol. Youre definitely a trip man. Hopefully you enjoy the tires you ride and have a nice day.
    Reputation: Streetglider08's Avatar
    Jun 2012
    I’m new to maxxis tires but am very pleased. Coming from continentals on my old bike and tried a couple other brands. On my newest bike (29er) it came with a 2.4 ardent on the front and a 2.35 forekaster on the back. I will say that I have never felt the need for anything else. Getting the bike in the fall and riding through a northeast winter and now a sloppier then ever spring, these tires have been amazing. I won’t even look at other tires when it’s time to replace these. Just thought I’d share my experience with them.
    SS Pusher Man
    Sep 2001
    Simple....you are limited to where you can purchase Bonty tires. Often times the Trek website says "out of stock, check with your local dealer".
    I don't pay retail.....my point is, if I was on a bike trip and had to get a new tire, I'd have a much easier time finding a DHR locally. But thanks for trying to read between the lines.
    Otherwise Jenson will pricematch that $52 and ship for free.
    Bucky the Cat
    Nov 2015
    175 hours, 1900 miles, 110,000 feet climbed since Jan 1. You? Go ride your bike and stop having frivolous arguments. Have a nice day.
  1. Old School VPP and New School shocks.
    By DeeZee in forum Santa Cruz
    Last Post: 08-17-2016, 05:33 PM
  2. Best place to buy Maxxis High Roller II and Maxxis Ardent tires
    By amaizenblue402 in forum Where are the Best Deals?
    Last Post: 02-06-2016, 02:49 PM
  3. "Old school" or new school parts for build
    By JayboFett in forum Singlespeed
    Last Post: 05-14-2014, 06:34 AM
  4. Old School La Cruz, New School Twist
    By 88 rex in forum Salsa
    Last Post: 06-19-2012, 01:09 AM
  5. Old school VS new school
    By Kona0197 in forum General Discussion
    Last Post: 07-22-2011, 06:59 AM
Members who have read this thread: 259
