Results 1 to 3 of 3
    S-Works Renegade 1.95/Renegade Control 1.95....or straight to Ikon?
    A new bike is shod with a front S-Works Renegade 1.95 and the rear a Renegade Control 1.95. It's a light carbon HT 29er and I'll mainly use it on long climbs and loose-over-hardpack trails. NO hucking or rocks or roots. Running tubeless, rider weight 170 geared up.
    Normally I run larger fronts and a narrower back but I have been told these are high volume. Never the less, how is the durability. Are these vaporware raceday type tires?
    Or should I just take the slight weight penalty for a lot more confidence up front and get the Ikon EXO so many are liking for the aforementioned conditions.
    Dec 2009
    I love the Renegade Control as a rear tyre. Try a Fast Trak or IKON as a front. The IKON will have slightly better grip but the Fast Trak rolls faster.
    I have Renegades front and back and find they work well in the conditions you describe.
  1. S-Works Renegade vs. Small Block 8 (29's)
    By steelgtr in forum 29er Bikes
    Last Post: 08-02-2011, 11:04 PM
  2. S-works Renegade tire..sidewall problem or bad luck?
    By BreakPoint in forum Specialized
    Last Post: 05-12-2011, 08:33 AM
  3. Specialized S-Works Renegade 29
    By cjmmtb in forum 29er Bikes
    Last Post: 02-21-2011, 08:46 AM
  4. Thanks Renegade
    By bear in forum Shocks and Suspension
    Last Post: 02-07-2010, 04:05 PM
  5. Renegade S-WORKS
    By Mr Pink57 in forum XC Racing and Training
    Last Post: 10-06-2009, 07:05 PM
