Results 1 to 5 of 5
    Rubber Queen 2.2 ghetto tubeless problem
    Anyone else having this problem?
    Just bought a pair of Ruber Queen 2.2 folding with Protection, but non ust, tyres. I've fitted them to Mavic 819 rims, have put a couple of scoops of Stans tyre sealant into each and have inflated them with co2 canisters. Problem i've got is that the sidewalls are leaking air like a sieve!! Not through the bead, but through the actual sidewall.
    I've previously run Maxxis Minion folding tyres in this way and they have been fine.
    Any ideas?
    Reputation: shapirus's Avatar
    Assuming they aren't in any way special, you can just follow all the advices for sealing up the tires that are tough to get sealed. There's been quite a number of posts about this, do some searching.
    That said, I've had great success with my RQs after I wiped off the release agent from the inside of the tires using some alcohol. Try this if other tricks do not seem to work.
    Reputation: 2clue's Avatar
    The CO2 may have froze/clunk up the stans causing them to not seal up the porous side walls.
    Oh yeah, I missed the words about CO2. Yes, stan's isn't recommended to be used with CO2 canisters. It could as well be the reason why it wouldn't seal.
    Reputation: alex_k's Avatar
    I painted sidewalls with latex primer.
