    May 2015
    Roval Traverse front hub bearings
    Did quite a few searches but have not come up with anything - yet.
    Have a Roval Traverse 29 front wheel need to replace the bearings.
    I'm guessing it's a 2013 from the stamp on it, 250813. There's another stamp, LFM07F, not sure what that is. The bearings are different sizes on each side. Anyone know what bearings this hub takes?
    Jul 2015
    I know the higher end traverse wheels are dt swiss 350's labeled as rovals if that helps, also you should be able to look on bearings
    Sent from my XT1585 using Tapatalk
    May 2015
    Tnx, but not found what I needed under the 350. They seem to have the same size bearings on both sides. I'll take a closer look at the bearings, and gotta get them out too.
    May 2015
    Got them out, one is 6805 - 25x37x7mm, other is 6804 - 20x32x7mm, if anyone needs to know
    Attached Thumbnails Attached Thumbnails Roval Traverse front hub bearings-roval-front-bearings.jpg
  1. Roval 29, Roval Traverse Fattie 29 and Hope Tech Enduro 29.
    By billywhiz040480 in forum 29er Components
    Last Post: 05-08-2016, 07:08 PM
  2. Replies: 5
    Last Post: 01-04-2015, 07:36 AM
  3. Roval Traverse al front hub
    By Ronstar in forum Specialized
    Last Post: 05-29-2012, 07:40 AM
  4. Hadley SDH rear hub on Roval Traverse EL wheelset?
    By Bradyab in forum Wheels and Tires
    Last Post: 01-27-2012, 05:57 AM
  5. Roval Traverse EL, opening free hub
    By Devastazione in forum Specialized
    Last Post: 11-04-2011, 01:28 PM
Members who have read this thread: 15
