Page 20 of 20 FirstFirst ... 101617181920
Results 1,901 to 1,994 of 1994
  1. #1901
    Reputation: biketango's Avatar
    Did not find anything in search so forgive if this was asked.
    I'd heard that the new Roval Control SL Boost spacing hubs will not fit/work with the new Fox Stepcast fork. Something about the hub flange conflicting with the narrower Stepcast fork spacing.
    Can someone confirm this? It was heard second hand but I hope it isn't true.
    R U living to ride or riding to live?
  2. #1902
    chasing simplicity
    Reputation: MattMay's Avatar
    Dec 2013
    Best to call Fox and ask them. Doesn't make sense unless there's something very unique about the Roval hubs. Btw Fox will sell you the fork direct now, and the '18s are available, just got one (don't have Rovals tho).
    Never underestimate an old man with a mountain bike.
  3. #1903
    Reputation: silent713's Avatar
    Feb 2006
    Has anyone here mounted Maxxis 2.8" tires to the Roval 650 38mm wide wheels? I'm curious how well supported the tires are with this wheel set.
    A man who carries a cat by the tail learns something he can learn in no other way.
  4. #1904
    Jun 2017
    Running 2.8s on 31mm IW Rovals. Tire profile looks good, 13psi front 15psi rear, bike handles great and leans over hard no issues.
  5. #1905
    May 2017
    Roval Control 29
    HI!
    I got a great deal on a very lightly used wheelset of these. They are 142 but i runt 148 boost on my trek fuel ex 8. There is a boost conversion kit available from specialized so no issues there. But the site says they haveto be redished 3mm. Is this hard? Can my local bikerepair shop do this? Is this hard? Do you have to remove all the spokes?
  6. #1906
    Mar 2012
    Trying to figure out if I have tor correct endcaps (I'm thinking I don't) for the wheels I just picked up from my LBS. They are for my 2016 Stumpjumper 6fattie with the fox 34 front forks. I got the Traverse 29 110/148 wheelset and the endcaps in the front wheel are S165900017 and S165900016. Problem is when I clamp the axle down the front wheel binds and when I pull the endcap out of the wheel and hold it up to the fork, the flat surface on the endcap is quite a big larger diameter than the recessed surface in the bottom of the fork. I'm assuming there is a different endcap for the fox fork legs? Could anyone post the part# for me and a link where to buy them please? Thanks!!
  7. #1907
    Hello Joe
    What is the spoke length for a set of 2009 Control EL from a 2009 SWorks Stumpjumper. And does Spec sell just the rim. After many years of use I finally trashed the rear.
  8. #1908
    2015 stumpjumper carbon evo expert - roval traverse
    I have a 2015 carbon stumpy with 650b roval traverse hubs... the front wheel bearings need replacing could anyone point me in the direction of what bearings I need to replace these pref in UK e... thanks. Jon
  9. #1909
    Jul 2017
    Front boost conversion
    Hi Roval Joe,
    I'm hoping you can direct me correctly. I have an old Control Trail 29 wheelset, and I need to convert the front hub to 15x110. Having trouble finding the right end caps. LBS got me end caps for Control Trail SL -- too big. Please see attached photos for details. Thanks for anything you can do!
    -Dave K
  10. #1910
    Dec 2016
    Hi joe,
    Sorry again for another road question, but curious if any of the current 29er control series could be used on a 2018 (non SCS) Diverge? Does a 12 mm endcap exist for road front axles? Suspect you can't comment on future releases, but lack of a wide carbon control wheelset for the Diverge Launch is surprising. Hard to believe that a clx 33 with a 38 or even 48 mm tire in 650b is credible when the clx 32 description says it was optimized for a 26 mm tire.
  11. #1911
    BKO
    BKO is offline
    Feb 2015
    Sorry if this has been covered, but it there an easy way to convert the Shimano hub to SRAM XD driver for my Traverses?
  12. #1912
    Jul 2015
    Quote Originally Posted by Roval Joe View Post
    There is an expert carbon Fuse for MY17 that is spec'd with Roval wheels with the 360 hubs.
    Roval Joe - Can you verify that the Fuse Expert Carbon does in fact come with the 360 hubs?
    The description on Specialized's website just says: Specialized disc, alloy, sealed cartridge bearings, 12x148mm thru-axle, 28h
    It does specify the Roval Traverse 650b, hookless alloy, 38mm inner width, 24/28h, tubeless ready rims and DT Swiss SuperComp spokes, but does not specify the hubs.
    Thank you.
    Santa Cruz Tallboy 2
    Cannondale CAAD12
    Niner RLT9
    Salsa Fargo 29+
    Niner SIR9 27.5+
    Surly Krampus
  13. #1913
    Mar 2013
    @Whippet- SBC PN 30017-1100 is what you need to convert these wheels. 135 and 142 hubshell is exactly the same, so no worries there.
    @Tarekith- you are looking for a FHB compatible with DT 360 hubs (the three pawl version).
    @erict- the wheels will come with standard and torque cap end caps.
    @biketango- the new Control SL 29 wheels (25mm inner rim width) will work with the stepcast forks.
    @geronimodkj- your local shop can do this- no new spokes are necessary.
    @crfnick56- you have the RS torque caps in our wheel. The PN you need is: S125900006
    @JonAlderson- QTY 1 bearing 6804 (20x32x7) QTY 1 bearing 6805 (25x37x7)
    @kawczynski- apologies, that hub is an OE Spec hub and is not convertible.
    @fryeguy- apologies, I need to check with the road PM. I am completely focused on mountain bikes and wheels and steer clear of all things drop bar! Hold tight.
    @BKO- what model (alloy or carbon) and year? I can help with a PN after that.
    @AVLthumper- that bike model uses a Roval rim, but laced to SBC hubs. Those hubs are not with DT SWISS internals.
    @jdgang- 2009 is beyond what I have info available for. It is very doubtful there are still rims available in service to support this. I’d recommend calling SBC customer service to double check, but chances are slim.
  14. #1914
    Apr 2005
    Joe,
    I just purchased some new Traverse SL's from my LBS for XC use and was wondering if it's possible to get the hubs upgraded thru Roval to the Control SL hubs? I have to use a boost adapter for my stepcast fork and would prefer a proper boost hub.
  15. #1915
    I'm with stupid
    Reputation: hitechredneck's Avatar
    Hey, why no 650b alloy rear rim replacements? I trashed a rim and cannot get buy a replacement hoop though big S. What gives?
  16. #1916
    Jul 2017
    Joe, I am planning on building up a new wheelset using the Roval Control 29 142+ stock rims on there and I was wondering if anyone had the flange measurements so I can order the right spokes before unlacing the hoops?
  17. #1917
    Hey.
    I have a set of specialized roval traverse 29 wheels off a 2015 specialized enduro elite 29.
    They have a XD driver.
    Would like to know what hubs they are so I can get a standard freehub to run shimano 11 speed cassette.
    BKO
    BKO is offline
    Feb 2015
    Hi Joe,
    Roval Traverse SL Fattie 650b Carbon. I believe from 2016. Can you let me the know the 2015 and 2016 PN, just in case? Thanks.
  19. #1919
    Silence! I kill you!
    Reputation: Jorgemonkey's Avatar
    Hey!
    The rear hub on 2014 Specialized Stumpy comp 29er has some play in it. I can't quite figure out how to tighten the hub to get rid of it. Is there a tech manual out there somewhere?
  20. #1920
    the 2011 Control SL will NOT fit a 2017 Fox SC
  21. #1921
    Shore slayer
    2016 Stumpjumper Elite 29er, Roval Traverse with 3-pawl XD driver (freehub).
    Cassette spins in forward direction (clockwise) with very little resistance without the wheel turning. I.e. If I pedal forward, the bike doesn't move. Pawls also sound normal when pedaling in reverse.
    I was able to pull the cassette and driver off together and couldn't see anything glaringly wrong. Pawls spring out easily, hub body appears undamaged. I re-installed cassette & driver, then struggled to remove just the cassette. It finally gave way with a loud bang. The cassette does not appear damaged. Neither do the treads on the driver body.
    I assume something has failed inside the driver, but don't know how the internals mesh together to be certain. Does this sound like a correct diagnosis? I would rather not buy a new cassette AND driver if it's only one of them that is a problem. Thoughts?
    EDIT: figured out it's the "ring nut" inside the hub that is spinning freely. I assume I need a new hub now? Can't find any online complaints of this happening.
  22. #1922
    Roval Joe
    Thanks for the update. I really wasn't planning on using the same rims over again. I would love to be able to re lace the back hub to a new rim, but like its been ask before I do not have the flange measurements for the correct spoke length.
  23. #1923
    Jan 2005
    What set do I have?
    Hey Joe,
    A buddy gave me a Roval Wheelset and I'm guessing they wont fit my frame (135mm QR) so question is what do I have. Rim tape says 31MM, 28 spoke rear, 24 spoke front. 15x100 Front hub, and 12x??? rear. Rim decals is missing. I assume from reading other posts that this is a Hi-Lo non convertible rear hub. Is the rear 135 or 142? And are they Controls?
  24. #1924
    Freezer
    Reputation: mlloyd007's Avatar
    Dec 2009
    Boost hub question: I'm considering the Control SL 25mm inner wheelset for a Pivot 429SL build, which has Boost front and rear. Do the Roval Boost wheels actually have wider hubs with wider spoke spacing, or is the hub spacing the same as non-Boost, but with added spacers to make them fit in Boost spacing? Thanks!
  25. #1925
    They are true boost.
  26. #1926
    Freezer
    Dec 2009
    Awesome- thanks!
  27. #1927
    Nov 2014
    Roval questions?-roval.jpgDoes anyone know what hubs are on the 2010 roval? Is it still the lower end Hi Lo hubs, I heard some have dt swiss but not sure the year.Roval questions?-roval1.jpgRoval questions?-roval2.jpg
    Buying a used set for my gf's bike
  28. #1928
    Those are DT Swiss internals. The hi low hubs have actual flanges and Jbend spokes
  29. #1929
    Jun 2017
    Hi Roval Joe
    I just picked up the new 2018 Control SLs Boost (with XD driver). I am currently using 2016 Control SLs 142+ (with a Shimano freehub body). Can I do a straight swap of the Shimano freehub body and XD driver between these wheels? Thanks!
  30. #1930
    Jun 2017
    Quote Originally Posted by S-Works Boy View Post
    Hi Roval Joe
    I swapped the freehubs today so the answer is yes, it works fine. The new SL's are sweeeeeet.
  31. #1931
    Oct 2010
    I was going to answer on this, but I was hoping Joe would. Though it will "fit" there is a dimensional difference on the end cap for 142+. If you did 142 to 148, yes it would be a direct swap of the freehub/end cap. The hub shell makes up that 6mm difference between 148 and 142, but the 142+ shell is slightly wider and uses a special drive side end cap that's smaller for that shell in a 142 frame. I believe its only 2mm, and probably won't affect the integrity, but you might have a warranty issue, should that arise. You should look for a 142/148 shimano freehub end cap for it to be the proper dimension.
  32. #1932
    Oct 2011
    Hi Roval Joe,
    I have a pair of roval control carbon 29 that I got in 2013. I just got a crux with front 12mm TA. Are there 12mm endcaps that I can order so that I can use the control carbons on the crux? Thanks
  33. #1933
    Jun 2017
    Thanks bpd131. You are correct. Fortunately the new Rovals came with a 142/148 Shimano end cap so I used this.
  34. #1934
    Oct 2010
    Good job!
  35. #1935
    Reputation: tshred's Avatar
    Dec 2004
    Hubswap from "normal" 100/142+ to BOOST 110/148
    Hi Roval Joe,
    I just bought a 17 stumpjumper pro with 27.5" 6fattie wheels. The fork and rear are boost spacing. I replaced the original wheelset with a Roval Traversee Sl 38.
    I also want to run this bike with 29 inch wheels to try out the new 29 x 2.5 tires that are coming out.
    I have a 2015 set of Roval traversee sl 29 with 100/142 hubs that I want to swap out for boost hubs.
    My question is: when I do the hubswap will I need to get new spokes because the wider hub spacing will require a longer spoke or can I keep the originals as they seem to be in great shape?
    "Luck favors the Prepared"
  36. #1936
    Reputation: COMTBR's Avatar
    Jul 2016
    Hi Roval Joe,
    I've got one that has stumped multiple LBS and Specialized techs.
    I have a 2018 Epic HT Comp Carbon (Boost) w/the Torque Cap compatible Reba 110x15 fork.
    I bought a set of Roval Control SL (2017 25mm IW) 110x148 wheels.
    I'm trying to find the correct Torque Caps to go on the front hub.
    After multiple attempts of trying to get a straight answer out of Specialized, my LBS ordered in these caps:
    specialized s175900004 Left Torque Cap
    specialized s175900005 Right Torque Cap
    The left side looks to be perfect, and matches that side's cap width, the other appears to be 2mm too narrow and the wheel fits too loose in the fork.
    L > R - Stock LEFT, Torque LEFT, Stock RIGHT, Torque RIGHT
    Stock RIGHT, Torque RIGHT (TOO Narrow)
    The two left (brake side/non drive side) Caps are identical in width and the Torque cap fits/works perfectly.
    The two right side caps are different in width, with the Torque cap being exactly 2mm narrower. Not good.
    As you can see below in this random review photo of the new wheels, the right torque cap is 2mm wider than the one I was given.
    THIS is the part I need:
  37. #1937
    Jun 2017
    Did your wheels not come supplied with the spare torque caps? Mine did and they fit fine.
  38. #1938
    Jul 2016
    No, my LBS LOST the freakin bag of stuff that came with the wheelset.
    So the wheelset CAME with the correct Torque caps?!?!
    They told me it just came with the spoke hole caps and gave me a bag of those from a Traverse SL set or something.
    Argh.
    Then this should be easy. Why is it so difficult for specialized to come up with part numbers for these if they ship with the wheelset?
  39. #1939
    Jun 2017
    Here's a pic of the caps that came with my SLs. Sorry, I don't have the part number. And sorry your LBS lost the parts (it happens occasionally when the shop gumby throws out the box...!)Roval questions?-img_3839.jpg
  40. #1940
    Jul 2016
    ^^^ Thank you!!!!!
    Exactly what I needed. I can show them this.
  41. #1941
    Jul 2016
    Disaster avoided, sky hasn't fallen. My LBS found the original pack that came with the wheelset.
  42. #1942
    Jun 2016
    Hi Joe,
    I was wondering if the older Control SL (2016/2017 with 22mm internal width) is compatible with a DT Swiss 11-speed road freehub body. It seems like it should be, but I want to make sure the spacing will work before I order the wheels. Thanks!
  43. #1943
    Hi Joe, will a Traverse SL Fattie (30mm) 650b boost wheelset come with end caps that are compatible with a 2017 Santa Cruz 5010 and 2017 fox 34 (SC oem version)? Thanks!
  44. #1944
    Control SL29 internal 22mm for CX Cyclocross
    I've researched that putting the new Shimano Ultegra 11-32 cassette on an MTB Shimano splined hub will work (from my understanding). I'd be using a Control SL29 with 12x142 on CX bike with same.
    Would I need the wheel re-dished?
    Second, is there a preferred bead type that works best with the hookless rim?
    Finally, any suggestions on how low of pressure it might be possible to run with 33mm tire in CX conditions?
  45. #1945
    Aug 2017
    Hi Joe and everyone,
    I was wondering if you would have any pointers for replacing the bearings on a Control Carbon 29er wheelset. I am having particular issues with the front hub (the LFM07), where the thing is eating through bearings every 200-300km. I've been using it on my Epic first with a Magura TS8 and then an RS Reba fork, for general XC and some light trail riding, where it's not seen anywhere near the abuse people here say they put them through. I've also excluded the option of over-tightening the axle by using a torque wrench set to the fork-specified minimum force when mounting the wheel.
    Jun 2016
    Quote Originally Posted by biketango View Post
    The 11-32 cassette requires a standard 11s road freehub. However, the new HG-800 11-34 is designed to fit on any 10speed shimano freehub. The wheel shouldn't need to be redished, as long as your frame isn't designed asymmetrically (like the new cannondale superX, among others).
  47. #1947
    Jan 2015
    Roval Control SL SCS wheels on a regular (non-SCS) road bike?
    I don't understand "SCS".
    Can I use SCS wheels (eg., Roval Control SL SCS wheels) on a regular. non-SCS, road bike (eg., 2018 Diverge carbon frame)?
    Sep 2017
    Roval questions?
    Hi Joe,
    I have Specialized Stumpjumper Comp Carbon 6fattie and one question for you
    On my last ride i had some accident and chan dropped behind cassette. As that was during going uphill tension was high and chain damaged two spokes. I need to know length of spokes so i can buy and replase that damaged ones. (rear wheel, drive side)
    Thanks in advance!
    Edit: One more thing, if you can explain me how to remove end caps from these hubs? (Roval traverse hi-lo)
  49. #1949
    Shore slayer
    Maybe Joe is gone? He hasn't responded to this thread in over two months.
  50. #1950
    Sep 2017
    It's a pity if it's a true.
  51. #1951
    Sajlonac,
    Pull one of the spokes and measure it.
  52. #1952
    Sep 2017
    Sure, I will do that at least but I was hoping to get info on easy way.
    Thank you.
  53. #1953
    I hear ya. Just seems as though Specialized has left the building.
  54. #1954
    Joe,
    I posted here about a year ago when my Roval Traverse Fatty SL rim failed while riding well within the limits of what should be expected from an Enduro Rim. The shop offered crash replacement. You were very helpful and told me to have the shop send it to the SLC center. They did and I was sent a warranty replacement right away.
    I'm in the same boat again. I think the 3 year warranty is very misleading. I was told it wasn't a warranty because it was caused by an impact. It's an enduro rim I'd assume it can handle an impact? I'd be happy for a crash replacement if It failed catastrophically due to a cased landing. I've seen what carbon rims look like under these circumstances. But mine failed on an XC level rock garden with heavy casing tires and proper PSI.
    I hope you're still around and can offer me assistance again?
  55. #1955
    Shore slayer
    In case anyone's listening, a friend of mind had the same thing happen about a month ago. He also had to replace the hub. This does not sound like an isolated problem, not happy at all with these wheels.
    Quote Originally Posted by ChunkyMonkey View Post
  56. #1956
    Sep 2015
    Guys, just picked up a used '17 enduro comp 650b. Need to replace rear hub bearings. I have remover and press, do I need other special tools? Looks like I may need to remove the hub splines to remove the drive side bearing. First Spec I have owned. thanks.
  57. #1957
    Hi,
    I recently bought a 2018 S-Works Epic HT. It came equipped with a Rockshox Sid Brain fork and Roval Control SL 29 Boost wheels.
    I want to switch to a Fox SC fork- The Roval Control SL 29 Boost wheels come with end caps that are approximately 31mm OD with a flat face to fit the inside of the Rockshox.
    I need end caps that fit the SC fork.
    My local Specialized dealer says this part is not available until February 2018-
    But the parts DO come with retail Roval Control SL 29 Boost wheels.
    Does anyone have an extra set of the proper 19mm end caps or know where I could get a set?
  58. #1958
    Dec 2017
    Howdy Joe. Thanks for being you.
    I've just bought a Roval Control SL SCS wheelset that was taken off of a 2015 Crux (Although the graphics make me think it was a 2016 Crux, MORE BLACK) - and I'd like to run the wheels on my 2015 Specialized Diverge Comp Carbon.
    Both F/R wheels are currently set up QR.
    I have the 12MM end caps to make the rear end TA, and I don't think I'll have any issues with fit/SCS and all that since the rear hub is 135/SCS already.
    My question is about the front hub of the Roval Control SL SCS.
    I've scoured the interwebs and it seems like I'll be able to convert the front hub from QR to 15mm TA, but..
    Q: What is the 15MM endcap part number? And where might I find some?
    Or did I just make an Ebay blunder and buy wheels that I can't use or upgrade??
    Gracias Sensei.
  59. #1959
    Reputation: biked2school's Avatar
    Aug 2017
    Stem lenght?
    What length valve stem should I get for the Roval aluminum fatties? I figure a 35mm should work?
  60. #1960
    The Fastest of Bananas
    Reputation: FastBanana's Avatar
    Aug 2013
    Quote Originally Posted by biked2school View Post
    Should reach, but not much left. I prefer closer to 50mm
    Sent from my SM-G955U using Tapatalk
  61. #1961
    Dec 2017
    Hi Joe
    I have a set of Roval Control SL 29. 15mm front/135mm QR rear. Ordered and purchased in 2015 from a dealer. Great wheels but unfortunately, they are sitting on a mountain bike I just don't ride.
    I want to run the wheels on a gravel bike that is 12mm front/142mm thru rear.
    Can I convert these wheels and what are the part numbers involved?
    Second, I have noticed, both on the mountain bike and when I slipped the front wheel into the fork of the gravel bike, that the spokes pass very close to the caliper. In the case of the gravel bike, one spoke actually "ticks" the caliper. do I have a dish issue?
    thanks and happy new year
  62. #1962
    Aug 2010
    Same question as hottie...
    I bought a sleeve to step down the ID to 12mm but the OD is 21mm and my fork is 19mm.
    I need a solution
  63. #1963
    Jan 2018
    Roval Control SL Torque End Caps
    Here's a pic of the caps that came with my SLs. Sorry, I don't have the part number. And sorry your LBS lost the parts (it happens occasionally when the shop gumby throws out the box...!)Click image for larger version.
    Hi @S-Works Boy, would you by any chance sell the torque end caps? I can't find a part number so I can order them.... Or at least, the right one from another guy, had the wrong number so.... Could you please help in any way?
  64. #1964
    Feb 2018
    Hey All, I apologize if this has been asked multiple times, but I don't have time to go through the whole thread. I have a set of Roval Control SL 29s that I would like to convert from TA (142) to QR. Any idea what end caps I need? Part numbers? Thanks!
  65. #1965
    Dec 2004
    Did you ever get an answer?
    Quote Originally Posted by etaylorabel View Post
    Hi Roval Joe,
    Looking for the same answer.
  66. #1966
    Dec 2017
    I should let you all know that I was able to conver my Roval 29 Control Sl mountain bike wheels to 12mm thru axle front. I used part numbers:
    Left side- SBC PN S165900003 // Right side - SBC PN S165900010
    the spokes do clear the caliper (SRAM Force flat mount)
  67. #1967
    Mar 2014
    I have a 2017 S-Works Epic HT. I'm thinking of purchasing a 2015 Roval Control SL Wheelset 142. Included in the sale is a Roval 142+ Boost Conversion Kit. Will I be able to use the kit?
  68. #1968
    Dec 2015
    Hello Roval Joe,
    I have Roval Control SL 29 2012 (i am not 100% sure if this is correct) and have a problem with side caps for 15mm axle on the front wheel for Rock Shox Reba 29.
    According to Specialized manual I should use S125900010 15mm front adapters, but the left disc sided adapter does not fit.
    Any advise?
    Attached Thumbnails Attached Thumbnails Roval questions?-30594200_1793136127437199_3688059855542681600_o.jpg
  69. #1969
    Sep 2014
    @Roval Joe...this is a last ditch effort to try and save a little $$$. I have a S-Works Epic XTR w/ Roval Control 29 SL (with the LMF11 Hub) and have really never ridden them. I swapped out the fork and went with a 15mm...I am trying to find P/N 125900010 to convert the Rovals to 15mm from QR so I will have a spare set...I have a feeling that the part is no longer being made...Hopefully someone here will have a solution or a LBS that has the end caps I need. If not, I have a set of Roval Controls for sale...
  70. #1970
    Apr 2018
    Hi Roval Joe!
    I'm riding a 2016 specialized enduro expert with Roval Traverse wheels. Rad bike, and rad wheels. The rear wheel has started to develop a little bit of lateral play- if it were an old 10 speed, I'd pull out my cone wrenches. Is there a way to adjust this play out of the hub, or does it need some professional service?
  71. #1971
    Reputation: Chad_M's Avatar
    Jul 2013
    Seems like the Roval Wheel offer is shrinking and shrinking. Only 4 version shown on
    https://rovalcomponents.com/collections/mountain-wheels
    Ridley CX, Stumpjumper Carbon HT, Surly Wednesday
  72. #1972
    Jun 2017
    @Roval Joe. What is the weight of the Roval Traverse Carbon 29 wheels fitted to 2018 Camber Expert?
  73. #1973
    Quote Originally Posted by redbruce View Post
    1800 grams
    https://www.specialized.com/us/en/ro...=251123-155113
    Sent from my Pixel 2 using Tapatalk
  74. #1974
    Quote Originally Posted by Chad_M View Post
    Check these links out. They just made available aftermarket the lower end carbon wheels that have been OE on some non S-Works bikes. Same carbon rim from what I can tell, but heavier J Bend DT 350 hubs and spokes vs their own lighter straight pull hubs with 350 internals. Also 36T star ratchet vs 54T.
    https://rovalcomponents.com/collecti...raverse-carbon
    https://www.specialized.com/us/en/ro...=251122-155112
  75. #1975
    Control SL 29 Carbon Boost 2018 spoke length (rear DS)
    Roval Joe (or anyone else who can help)
    I broke a spoke on my 2018 S-Works Epic 29 (rear wheel, drive side). I have measured the length of the two pieces and the result is 295 mm. When I try to get this spoke from my local Specialized vendor he claims that the length should be 300 mm! I do not want to put on such a long spoke.
    As temporary solution I put on a 297 mm DT Completion spoke that I had in the drawer so the wheel at least got straight again. I do not think this is good for the rim in the long run, so I want to put on a DT Revolution spoke that has the same flexibility as the other spokes in the rim. What length should it be?
    Where is this information available on the Specialized web site?
  76. #1976
    Quote Originally Posted by ErikGBL View Post
    It isn't on the website, this is all secret stuff as far as specialised is concerned, you're a captive customer now and feel lucky someone will help you in time. You're screwed with proprietary wheels and dealers who generally have no god damned idea or stock of wheels or whee parts.
    Pull another spoke out and measure it. Make sure you are measuring correctly.
  77. #1977
    Jun 2017
    Quote Originally Posted by link1896 View Post
    2018 s works is straight pull, measurement principle is same. Base of the spoke head (from the point where it transitions from the head to the round section) to end of thread. Basically everything except the head.
    As for the first statement, yep, yep, yep.
  78. #1978
    Doh, I own rovals and forgot the SP fiasco. What a circus it is.
  79. #1979
    Reputation: sosburn's Avatar
    Sep 2017
    Hi Joe (or anyone else who has the answer to this)
    I have a set of the Royal Traverse carbon wheels (NOT SL), with the low end hubs. Rear hub has developed play. What is the bearing size that i need to order for these? if they're annoying to find then i'll just start looking for a replacement hub to lace to the rim.
  80. #1980
    Quote Originally Posted by sosburn View Post
    Should just be whatever the DT 350 takes?
  81. #1981
    Risingson
    @~Jb- PM'd
    @gui_gui - the Control 29 alloy has always used the DT 360 internals with the 3 pawl mechanism- that is an error on the French website. The US version shows the spec as 360, which matches my specs.
    I bought a 2017 Stumpy Pro last year, went to install a 54t star ratchet and was surprised to see the 3 pawl system. On a $9k bike why would this be the case? The website said "DT Swiss internals" nothing about 360. The 2018 Pro model comes with a 350 hub and states on the website "DT Swiss 350 star ratchet" The 2017 website is misleading. You'd think Spesh would give you a decent hub after spending 9k. Guess I'll have to rebuild winter time
  82. #1982
    Sep 2017
    Quote Originally Posted by mmckechnie View Post
    thats what i was thinking, but the hub looks very similar to a Sram MTH 746 that i have on another bike. Maybe i'll do a little bearing swap.
  83. #1983
    Quote Originally Posted by skywalkertrancex View Post
    If you look at the big three that used DT Swiss internals Giant, Spec and Trek . The lower end models used to come with 240/350 internals now only the highest end wheels come with 240/350 or in the case of Trek their own design. I have a pair of Control EL 29ers from 2009 240 internals. I have a pair of 2013/14? Giant P-TRX1 29er 240 internals. Now both wheelsets I believe are 360 (prawls) its all about cost.
  84. #1984
    Sep 2017
    Ok trying this again. I have the carbon wheel set off of the 2018 Enduro coil 29. The website lists the hubs as "specialized" generic hubs with sealed cartridge bearings, any idea on the size so i can order new ones? rear hub is starting to go bad.
  85. #1985
    Risingson
    Quote Originally Posted by jdgang View Post
    I emailed Specialized and they said to ship them the wheel with the 54t ratchet and they'd switch the internals to 240/350 internals. I'm happy with that
  86. #1986
    Oct 2016
    Roval Joe doesn't seem to be on here anymore, but maybe someone else knows.
    Max pressure is listed at 45psi on the carbon rims I have, is this dependent on tire size? They are 29er wheels, can they be used at higher pressure with cross/gravel tires? The whole pounds per square inch thing messes with my head, does 45psi in a 2.4" tire put less stress on the rim than 45psi in a 32c tire?
    Eat Clean and Pedal More
    www.eatcleanpedalmore.com
  87. #1987
    Aug 2018
    Hi everybody, I have a set of roval control sl 29, year 2013 or 2014, 32 holes, the rear rim is broken and need to know the erd to find a replacement. Anyone can help?
    does anybody knows whether it is the same of the aluminium wheel?
  88. #1988
    Brentster
    I just bought a 2019 Stumpjumper Comp carbon. Will the newest $1,900, 1,320 gram Roval Control SL 29's fit on it? Or will it only take Traverse or other wider trail wheels?
  89. #1989
    Quote Originally Posted by Brentster View Post
    You'll need the boost version (148) which is only 10 g heavier. The Controls will fit fine but a 2.6 wide tyre isn't ideal for the internal width of 25 mm (instead of 29 mm your bike came with) but will still be OK. You could also use a 2.3 wide tyre instead.
  90. #1990
    Brentster
    Quote Originally Posted by paulcd View Post
    AWESOME! Thank you very much
  91. #1991
    Reputation: Renzo7's Avatar
    Mar 2015
    Hello, Roval Team
    I hope you're well.
    I have a set of Roval Traverse 29 Aluminum wheels that have taken too many hits. The front rim is now unrecoverable by truing and the rear is quite wobbly despite careful work by a LBS. I want to replace them, but I'm getting terrible customer service locally.
    I asked for the replacement rims and, after much waiting and pressuring, they ended up giving me a quote for a carbon Traverse 29 wheelset. That's not what I want and it's considerably more expensive than what I'm asking for.
    What are the part numbers for those rims? As you know, Front is 24H, Rear is 28H. How can I find an alternative for purchasing them? I've been on their case about this for months and the distributor doesn't care about solving their customer's problems. I need a shop/retailer/site in the USA that's capable of ordering these parts and shipping them to me.
    Could you give me a hand, please?
    Cheers!
    Sent from my SM-J710MN using Tapatalk
  92. #1992
    Sep 2018
    Hello All,
    Carlos here writting from Barcelona Spain.
    I've been searching in the forum but I'm not able to find what I'm looking for.
    Please could somebody tell whart are the bearings size and codes for the Roval Control SL 29 (2018) .
    The wheels are in my new bike Sworks epic 2018.
    I want to replace by ceramic bearing but Nearly impossible to find on internet the bearing codes.
    thanks so much in advance
  93. #1993
    MK_
    MK_ is offline
    carpe mañana
    Reputation: MK_'s Avatar
    Can you suggest where I can find 15mm end caps for the LFM07 hub? It has 20mm end caps on it now marked S12590003.
    I found a set of 15mm caps at Art's:
    https://www.artscyclery.com/Speciali...-SPRVECPP.html
    but those may be for the LFM06 hub?
    Thanks.
    _MK
    Before you diagnose yourself with depression or low self-esteem, first make sure that you are not just surrounded by a*holes
  94. #1994
    Oct 2016
    Can anybody please help me with these questions.
    1. What is the weight of just a single rim, of a Roval Traverse Fattie 650b alloy wheel?
    2. Is the Roval alloy rim that is on the wheels that come on the low end Specialized bikes (with Hi Lo hubs), the same rim that is on the Roval Traverse Fattie 650b alloy wheelsets?
    3. Have any of you had rim failure / denting / bending of the Roval Traverse Fattie 650b alloy wheel? I am trying to understand how much it is capable of handling aggressive Enduro riding, specifically steep descending rock gardens with drops in between.
    I currently ride a 2015 Specialized Enduro Comp with an after market Roval Traverse Fattie 650b alloy wheelset. It has handled up to 6ft drops, big jumps etc, without any issues. This season I got into more technical descending, including steep rock gardens (for reference - Predator trail at Tiger Mountain in Seattle area). The rear wheel has felt odd (no damages of any kind). Also, the front wheel with 24 spokes is a concern. So, any advice / experiences shared, will help.
  1. Replies: 5
    Last Post: 01-04-2015, 07:36 AM
  2. Questions regarding Roval carbon 29er wheels
    By having fun in forum Specialized
    Last Post: 04-17-2012, 01:43 AM
  3. Roval Control Trail 29 versus Roval 29
    By protobiont in forum Specialized
    Last Post: 11-29-2011, 03:22 PM
  4. Broke Roval E5, replace with roval or stans Crest?
    By crimecrusher in forum Wheels and Tires
    Last Post: 06-27-2011, 05:59 PM
  5. Replies: 12
    Last Post: 03-11-2011, 05:35 PM
Members who have read this thread: 247
