Results 1 to 5 of 5
    Jul 2014
    Roval Control SL -- Crank rotate when the free wheel is engaged
    hi everone,
    I notice something recently.
    https://www.youtube.com/watch?v=9RTr...ature=youtu.be
    when I let my rear wheel turn at high speed with my free wheel engaged, my crank begin to spin also.
    I have a roval control sl with DT hub system.
    I clean and I try to grease the ratchet with the red DT grease but nothing change.
    I'd like to know if someone has the same problem.
    Maybe I grease too much the ratchet?
    Also I use recently a new grease for my bearings, the finish line fluoro.
    My bottom bracket is much better with this grease. maybe it's a reason?
    thanks for your help.
    mtbpete
    Reputation: changingleaf's Avatar
    A lot of grease can certainly add friction inside the freehub, but when you stop the crank the chain does not bunch up so I wouldn't worry about it.
    Jul 2015
    Yeah I wouldn't worry about it, no major issues going on
    Sent from my XT1585 using Tapatalk
    Jul 2014
    hi,
    I try to have a look and I struggle a lot to remove the spacer inside the hub.
    http://www.dirtworksb2b.com.au/asset...L/DTS-1077.jpg
    maybe the spacer has a problem and the ratchets don't do their work correctly.
    That spacer comes out on me every time I pull the cassette to service. I do notice that to much grease will cause the pedals to turn when freewheeling in the bike stand.
  1. Replies: 1
    Last Post: 07-24-2017, 01:52 PM
  2. Replies: 2
    Last Post: 08-01-2016, 03:58 PM
  3. Roval Control SL vs Roval Control SL 142+ 29
    By jscot111 in forum Specialized
    Last Post: 12-13-2012, 07:53 AM
  4. Roval Control Trail 29 versus Roval 29
    By protobiont in forum Specialized
    Last Post: 11-29-2011, 03:22 PM
  5. Accidentally engaged hydraulics disk brakes without wheel
    By naterwhite in forum General Discussion
    Last Post: 06-01-2011, 01:01 AM
