Results 1 to 16 of 16
    May 2018
    Roval Control SL 29 and Fox step cast 32 incompatible ?
    Roval Control SL 29 and Fox step cast 32 incompatible ?-20180504_171657_hdr.jpg
    Has anyone encountered such a situation?
    I have DT Roval wheels (front axle 100x15), I bought a fork FOX 32 SC (2019, axis 100x15) and when I screw the wheel is the collar of the hub rests on the fork - the wheel does not spin
    The other side of the hub (from the brake disc) - here is no problem. Is it possible to solve it somehow?
    On the photo you can see that the wheel is not yet tightened and the hub touches the fork.
    Attached Thumbnails Attached Thumbnails Roval Control SL 29 and Fox step cast 32 incompatible ?-20180504_171657_hdr.jpg
    Apr 2005
    On the older roval wheels you need to buy a boost sc fork. Then use the boost adapters on your wheel.
    Barely in control
    Reputation: Schulze's Avatar
    Feb 2007
    oh man that sucks. I would do what peabody said.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by Schulze View Post
    Buy an entirely new fork? Holy ****!
    May 2018
    The problem is that the fork already bought, cut - I never thought that there would be a problem with the hub ...
    Barely in control
    Feb 2007
    Then you have to get a new hub and spokes and rebuild the wheel. Fortunately, 15x110 hubs are cheap.
    Or you can get the dremel out and make that fork clear your hub. But then it's definitely your fork.
    Bicycles aren't motorized
    Reputation: life behind bars's Avatar
    May 2014
    Quote Originally Posted by alientm View Post
    Sell, eat the loss, get new compatible fork, be happy.
    You meet the craziest people riding e-bikes!
    Make
    America
    Gravel
    Again
    Jul 2015
    Can you possibly add a mm or 2 spacer? Give it a try...you could possibly lean out the end cap on the other side and still be within lateral movement tolerances of the brake caliper on the rotor
    Sent from my XT1585 using Tapatalk
    May 2018
    I am just testing 2 different solutions with a 2mm washer, it's good but not perfect, but with such a home solution it will probably be the cheapest and the fastest solution.
    Later I will make a photo of what it looks like.
    Land of the 230+
    Reputation: GuitsBoy's Avatar
    Sep 2013
    It looks like its really close to clearing. If it were me, Id grind it, no question about it.
    mbtr member
    Reputation: scottzg's Avatar
    Quote Originally Posted by GuitsBoy View Post
    I would too. I'd grind down the cover cap on the hub.
    I don't like the idea of pushing washers in there because the hub bearings and fork seals will be side loaded- a recipe for eventual failure. Might make the fork sticky too.
    Actually, i'd pitch the proprietary wheels. Not enough spokes, no certainty of being able to get replacement parts in a couple years. Not fitting is just the icing on the cake.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
    May 2018
    I made 2 spacers, both should be OK.
    This 2.5mm is from an old bearing from this hub, this 2mm fits on a 15mm axle. The wheel spins lightly, the fork seems to be working properly.
    I do not know which spacers can be better, if none of them I think about replacing the hub.
    Roval Control SL 29 and Fox step cast 32 incompatible ?-20180507_211308_hdr.jpg
    Roval Control SL 29 and Fox step cast 32 incompatible ?-20180507_211044_hdr.jpg
    Roval Control SL 29 and Fox step cast 32 incompatible ?-20180507_210629_hdr.jpg
    Roval Control SL 29 and Fox step cast 32 incompatible ?-20180507_211444_hdr.jpg
    Feb 2015
    Have you noticed any problems with this modification?
    May 2018
    Quote Originally Posted by dingz
    I still use this 2mm washer on the axle, in total now has about 1.5mm. I do not notice any problems, I use the bicycle on amateur races - the solution satisfies me.
    Feb 2015
    Thats great. Will apply this on mine...
    Can you send me pictures on your final solution if that okay.
    Thanks in advance.
    May 2018
    Quote Originally Posted by dingz View Post
    Thanks in advance.
    The solution is not perfect, more dust and dirt gets under the cap, probably the bearing will wear out faster. Well, but it is the cheapest solution that I could apply.
  1. Reviewish: Fox 32 Step Cast
    By teamdicky in forum 29er Components
    Last Post: 02-22-2017, 09:24 PM
  2. New Fox 32 Step Cast fork!
    By NH Mtbiker in forum Shocks and Suspension
    Last Post: 09-10-2016, 04:38 PM
  3. Replies: 2
    Last Post: 08-01-2016, 03:58 PM
  4. New Fox Step Cast Racing Fork
    By fat-but-slow in forum Shocks and Suspension
    Last Post: 06-20-2016, 07:11 PM
  5. Roval Control SL vs Roval Control SL 142+ 29
    By jscot111 in forum Specialized
    Last Post: 12-13-2012, 07:53 AM
Members who have read this thread: 79
