Results 1 to 3 of 3
    Rotor clearance after regreasing rear hub
    My bike has some inexpensive Shimano Deore hubs and I recently replaced all the bearings and the right side cone.
    After doing all that and putting it back on the bike I noticed that the rotor is rubbing inside the caliper on one side. It's pushed over soo much that there is zero adjustability in the caliper. Before reinstalling the caliper the hub spins flawlessly but when the caliper is reinstalled there is a lot of resistance due to the excess rubbing. I'm a little baffled, how do I "kick" the hub's center over in order to properly center the rotor in the caliper. I understand that it's a hub issue and obviously something I did wrong (first time, trying to learn the ins and outs of bike mechanics) but I fail to see my mistake.
    Any suggestions before I pull it back apart?
    Thanks,
    Josh
    RAKC
    Reputation: tigris99's Avatar
    Re: Rotor clearance after regreasing rear hub
    Check the spacing assures and if you replaced a cone make sure its the same size as the one that came off. My guess is you accidently put the spacer on the wrong side, happens to the best of us cause u just don't catch it till you put it back on the bike.
    Sent from my HTC Sensation Z710e using Tapatalk 2
    Yea I wondered about that, i'll probably take it back apart tonight so i'll check that out.
  1. 2013 trek remedy 7,8 rear rotor clearance
    By itstreky in forum All Mountain
    Last Post: 03-21-2013, 11:09 PM
  2. I9 classic hub/Fox 36 rotor clearance issue
    By whoda*huck in forum Brake Time
    Last Post: 03-24-2012, 02:58 PM
  3. V10 Carbon Rear Rotor Clearance Issue
    By gazza81au in forum Santa Cruz
    Last Post: 12-26-2011, 08:13 AM
  4. rotor to fork clearance
    By sjc115 in forum Brake Time
    Last Post: 07-08-2011, 11:08 PM
  5. Pad and Rotor Clearance
    By cycletard in forum Brake Time
    Last Post: 05-27-2011, 06:32 AM
