Results 1 to 2 of 2
    ARCHQUEST
    Reputation: fjyang's Avatar
    Rolf Dolomite Disc Wheel Shim / Spacer?
    HI,
    I got a set of Rolf Dolomite Disc wheelset and the issue is that for some reason it required a shim or spacer (see pic) to position the rotor to the correct spacing with calipers. If I don't have the shim /spacer on the 6 bolt hub side then I need to add shim on caliper mount to move in toward the hub side but then it interfere with the spokes.
    My Dolotmite does not come with the spacers and when I called Trek, they told me its no longer available. Do you guys know anybody that make shims that about 3/8" thick? If anybody have a spare set for the Dolomite, I would be interested.
    Any info. is appreciated, thanks
    Reputation: KINGFISHER1's Avatar
    i also need one of these spacers...
    I am a mechanic at a Bike Shop.
    See pics of my Bikes
