Rocket Ron 2.1 vs 2.25?
I'm currently running Rocket Rons 2.1 on the front and rear of my Scott Spark. I'm very happy with this combo but thought I would benefit from the wider 2.25 up front. I purchased the 2.25 and mounted it but it appears (naked eye) to be the same width as the 2.1. Is this common with width sizes? Has anyone encountered this with Schwalbe tires in general?
Yea I'd run the wider size as the 2.1 is too slippery when wet.
yeah, unfortunately it's only slight difference. On the plus side it's a bit higher volume than 2.1. RoRo is still pretty light even at 2.4, and it's considerably bigger than 2.1.
- You may not post replies
- You may not edit your posts
Forum Rules
