Results 1 to 10 of 10
    Replacement for a 2.2 Kenda Cortez ?
    I currently have a rear 2.2 Kenda Cortez on my BLT trail bike. I have been running this tire for a couple of seasons but found out they no longer make the 2.2. I need a replacement - fast roller, large volume. I will continue to run the 2.4 Cortez up front. Thanx
    I love Pisgah
    Reputation: Duckman's Avatar
    They renamed it the Karma 2.2 DTC.
    "I've breathed the mtn air, man" Johnny Cash
    It's a long way to the top
    . . . if you wanna rock and roll (ac/dc)
    mini clyde
    Reputation: eedavis's Avatar
    Blue Sky might still have some Cortez' in stock:
    http://www.blueskycycling.com/view_product.php?pid=3580
    Quote Originally Posted by Duckman
    Actually not. I called Kenda and the Karma has a similar pattern but the knobs are not as tall.
    56-year-old teenager
    Quote Originally Posted by eedavis
    I doubt it. Even if they say they have something in stock, they probably don't. Been there done that.
    Quote Originally Posted by keen
    I have a 2.2 Karma and a 2.2 Cortez. The knob height looks identical to me. The only difference that I can notice is a little more rubber on the sidewall on the Cortez.
    Minnesota Off Road Cyclists www.morcmtb.org
    Quote Originally Posted by tedsti
    Hmm... Well I just went off what the Kenda tech. told me. They must be mighty similar then . Kenda recomended I run a Small Block V8 or BG. I already have BG's and they are slow. Maybe a V8 ?
    Chillin the Most
    I have a Cortez 2.2 and it looks very similiar to the Karma 2.2 (bottom tire in pic) in this pic (pic is comparing the Karma 2.0 & 2.2) ...
    Based off this pic, I'd say Karma would be a great replacement.
    Pic taken from this thread (thanks Duckman for pic)...xc tire help
    "El Whatever"
    Reputation: Warp's Avatar
    Would you guys compare the 2.2 Karma to the 2.1" Nevegal/BG???
    Is it bigger or smaller in real life??
    If anyone can confirm the real size that'd be great!
    TIA!
    Check my Site
    I love Pisgah
    Surely its bigger.. I like the Karma 2.2 better since it has much more volumn and weighs less at 580gms(I have one 2.2 that weighs 563gms). And the knobs are indeed twice the height as the std more racy 2.0 Karma(pic below shows an almost new 2.0 Karma being the above tire, and a new 2.2 below it). The pictures I've seen of the Cortez(this very subject has come up just recently here) look identical to the "new" Karma 2.2 regarding knob height, pattern, etc.
    Side view compared to a 2.0 Karma on rear..which has decent volumn itself(more closer to the Python in volumn). The 2.2 up front has obviously taller casing and knobs. If you read the reviews of the Cortez, to me it rings true for this tire regarding roll speed, traction, etc. About $29 on the net. I use the 2.2 front setup for trail duty and such. Race day I swap out to an Olympic front with Stans alum rotor/2.25 RRalph setup.
    Sorry, I just posted these pics recently for the same reasons.
