I currently have a rear 2.2 Kenda Cortez on my BLT trail bike. I have been running this tire for a couple of seasons but found out they no longer make the 2.2. I need a replacement - fast roller, large volume. I will continue to run the 2.4 Cortez up front. Thanx
I have a 2.2 Karma and a 2.2 Cortez. The knob height looks identical to me. The only difference that I can notice is a little more rubber on the sidewall on the Cortez.
Hmm... Well I just went off what the Kenda tech. told me. They must be mighty similar then . Kenda recomended I run a Small Block V8 or BG. I already have BG's and they are slow. Maybe a V8 ?
Surely its bigger.. I like the Karma 2.2 better since it has much more volumn and weighs less at 580gms(I have one 2.2 that weighs 563gms). And the knobs are indeed twice the height as the std more racy 2.0 Karma(pic below shows an almost new 2.0 Karma being the above tire, and a new 2.2 below it). The pictures I've seen of the Cortez(this very subject has come up just recently here) look identical to the "new" Karma 2.2 regarding knob height, pattern, etc.
Side view compared to a 2.0 Karma on rear..which has decent volumn itself(more closer to the Python in volumn). The 2.2 up front has obviously taller casing and knobs. If you read the reviews of the Cortez, to me it rings true for this tire regarding roll speed, traction, etc. About $29 on the net. I use the 2.2 front setup for trail duty and such. Race day I swap out to an Olympic front with Stans alum rotor/2.25 RRalph setup.
Sorry, I just posted these pics recently for the same reasons.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
