Results 1 to 18 of 18
    Reputation: marpilli's Avatar
    Remove a Stan's presta valve core with a cheap spoke wrench
    While adding sealant to my tires today, I came up with an easy way to remove the cores from my Stan's presta valves. I tried several different searches and couldn't find the same solution documented anywhere. Hopefully I'm not the last one to the party.
    Although the official presta valve core removal tool doesn't cost much, I always forget to add one to my order. When it comes time to add sealant I don't have it and I end up removing the cores using a small adjustable wrench. C'est la vie.
    I was gathering up a few tools and noticed the cheap-o spoke wrench in the back of the drawer.
Size:  83.5 KB Name:  IMG_9906.JPG
    It looked about the right size so I gave it a try.
    The "11" slot fit almost perfectly. I spun the cores out, refilled the sealant and spun them right back into place. Oh, so much better than the small adjustable wrench.
    I've seen these spoke wrenches at just about every LBS for only a couple of bucks. If you're lacking the proper tool this might just help you out in a time of need.
    Cool. Thanks.
    I'd rep you, but it's telling me I need to spread the love
    Save Jesus
    Reputation: beanbag's Avatar
    Unfortunately, my valve core didn't fit my spoke wrench, so I had to make my own "tool".
    Quote Originally Posted by beanbag View Post
    Here I am with a bunch of stock aluminum and this never occurred to me.
    Nice job! Now I'll probably make something similar just to have in my pack.
    Reputation: wrongway's Avatar
    I use a spoke wrench for that too.
    Gumnut Peddler
    Reputation: Grinderz's Avatar
    marpilli - this just blew my mind. I am going to give this a go for when I do my ghetto conversion this weekend. Last time I tried, I ended up with Stans everywhere. I have now forgotten how much of a PITA it was, and am going to try again, this time armed with even more research.
    This thread is the cherry on top of my arsenal of MTBR how-to's
    Burning fat, not oil.
    More Torque
    Reputation: Diesel~'s Avatar
    Funny; I've always thrown those "universal" spoke wrenches away, since they suck so much for spoke nipples. Great find.
    -D
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    Quote Originally Posted by wschruba View Post
    i did.
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
    Dec 2012
    This worked great for me. In addition, the "9" slot worked well for installing the valve extenders on my tubulars. The 11 slot is a little loose for the valve core but it works okay anyway.
    Quote Originally Posted by gcarey3 View Post
    It's interesting that the 11 slot fit well on the valve cores I have. I somehow doubt those cheap spoke wrenches are made to exacting measurements.
    Dumb question on my part, what are the numbers supposed to indicate? Is there some "standard" numbering for spoke nipples?
    Dec 2012
    Quote Originally Posted by marpilli View Post
    I'll take a guess that it has to do with the gauge of the spoke itself, being made to fit the standard nipple size. Might not be accurate for all spokes.
    I'm just messing with you
    Reputation: wv_bob's Avatar
    I use a teeny tiny ignition wrench. Don't remember the size but IIRC it is the 2nd from the smallest in a Craftsman fractional set.
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
    Nov 2012
    Quote Originally Posted by Diesel~ View Post
    -D
    agreed! Glad i may have a use for mine now!
    Nov 2012
    that is correct, it's the gauge of the spoke
    Quote Originally Posted by cpfitness View Post
    I've learned something new today. Thank you, both.
    Quote Originally Posted by wv_bob View Post
    Another great idea. I have a set of those wrenches in standard and metric. Never occurred to use them for this.
    Apr 2015
    I have a M19 Crank Brothers multi-tools. Loosen the chain breaker (or take it off). The end - in line with the shaft, opposite the threaded end - fits a Presta valve perfectly.
    Not sure if it is just this chain breaker or all of them.
    great idea! Interesting that stans hasn't created a cheap tool to make a few bucks.
Members who have read this thread: 25
