Results 1 to 22 of 22
    Riding free's the mind
    Recommendations on a rear QR skewer
    I've been running Salsa QR's for years, no issues and might get another for my new bike. Anything recommendations out their for a "rear" QR, full suspension bike?
    How's are the Crank Bros split skewers?
    Question to a custom frame builder..."So what makes your bikes climb better?"....his answer, "Uh, your legs?"
    shimano
    What hubs are you running?
    It is possible they have a bolt on option, chris king does for example.
    Chris King ISO rear hub.
    Quote Originally Posted by HTail
    Here is a link to CK Fun Bolts, the image is of a single speed, but they work just the same on a geared hub, better picture on the SS page.
    http://chrisking.com/hubs/hbs_sspeed_disc
    Depending on your axle, new or old version,
    the old version used the two 5mm allen wrench's to adjust the bearing pre load.
    The new version is a one piece axle with a locking collar to adj pre load.
    If you have to buy the newer axle to use the fun bolts it could get a little expensive.
    Interesting option, so a less convenient to install and remove, but more secure? So it requires a different hub axle to accommodate those bolts? I believe mine ISO rear is setup for the typical QR skewer.
    Yes either axle will work with skewers, but the newer axle will convert to Fun Bolts.
    Also it is a little more time to install, remove but more solid rear end, if you ride alot of rocks and roots give the fun bolts some concideration.
    Reputation: boomn's Avatar
    I second the Shimano for an easy and cheap upgrade over the Salsa skewers. They really do clamp harder that those external cam designs
    Dec 2004
    Dt Swiss RWS are cool!
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Shimano , XT or XTR .
    SSolo, on your left!
    Quote Originally Posted by AZ.MTNS
    Shimano XT. Just bought a rear (135mm) from a guy on fleabay for $11.95 and free shipping.
    Get off the couch and ride!
    Ultimated Outsider
    Reputation: sundowner's Avatar
    Any Shimano or Campy.
    If I disagree with you, it's because you are wrong.
    Quote Originally Posted by Natedogz
    Recieved it and it is NOT Shimano XT and it is floppy loose on the lever/cam end....DO NOT BUY these if you see them!
    EDIT: Guy has not answered my email requesting to return the skewer!
    Reputation: chuckie33's Avatar
    Anybody use the Hope QRs? Been thinking of picking up a pair to match my Hope Pro IIs. Like the bling factor.
    If you ever see a turtle on a telephone pole, remember he had help getting there. Is there anything beer can't do?
    Reputation: d365's Avatar
    Are all skewers not created equal? I'm in the market for some too.
    The Specialized one I have, is failing on the front....could've lost some teeth on my last ride. Glad I stopped to check it out, even though it was closed.
    Quote Originally Posted by d365
    Correct, they are not all equal. Skewers with an internal cam are much better than the external cam style. See this page that explains the difference. Shimano skewers have an internal cam and are pretty cheap too
    Thank you.
    COMBO - President
    Reputation: FASTK's Avatar
    Quote Originally Posted by mgsuarez
    second that x2, thinking my new Niner will be running one. Have had one on the front for 6 months and and it's great.
    West Chester, PA
    Another vote for the dt rws. I have them front and rear.
    Pro - On the rear you can get it as tight as a bolt-on but still be able to get the wheel off on the trail without using a tool. On my specialized the arm swings 360 degrees without hitting the frame.
    Con - On the front, it can be a bit of a hassle because the arm is blocked by the end of the fork, so you have to keep pulling it out and placing it back around the clock to keep tightening. (if you haven't tried one this may not make sense)
    QR advantages
    The one factor I didn't consider are the rare times that I flat and have to fix the rear tire. I carry around a 3,4,5mm wrench so I guess it's not a huge issue to use bolts?
    CK uses an 8mm hex. Personally I don't miss having a skewer (front or rear) on my bike. If you get a flat you are getting tools out any way, so it is not a big deal.
    tg
    tg is offline
    Reputation: tg's Avatar
    Feb 2006
    This one
    Hadley 10mm yum,yum
    Attached Thumbnails Attached Thumbnails Recommendations on a rear QR skewer-cimg0741.jpg
