Results 1 to 30 of 30
    Dec 2008
    Recommendations for lightweight tubeless trail tire?
    I'm looking to lighten the revolving weight of my MTB, which is currently running UST versions of the Continental Mountain King and X-King tires on UST rims. According to Google, both of them weigh somewhere over 800 grams. I'm a recreational rider who does a lot of rooty singletrack, so I'm looking for something considerably lighter, that would be good for that sort of use. It doesn't have to be a UST tire, but tubeless-ready would be good, as I DO use sealant.
    Rolling resistance is drastically more important than weight.
    If you like the mountain kings, you can get the regular version and shave some weight. The true UST tires tend to be drastically heavier. Most comparable tubeless ready tires are going to be around ~700-800g as well.
    Dec 2005
    What about Nobby Nic tubless ready tires? Pretty light for what they are with good grip.
    Dec 2008
    Thanks for the suggestions. I know that I could run conventional clinchers tubeless on my UST rims, but am I right in understanding that they'd be much more likely to burp?
    Lots of tires in the lw trail category, many of which are tubeless ready. Examples:
    Mk II protection
    Nobby nic
    Spec. Ground control (my newest favorite)
    Maxxis ardent (not tubeless ready, but a coverts well)
    Wtb Bronson or mutano
    Reputation: dirtyjack's Avatar
    Quote Originally Posted by Zothecula View Post
    I wouldn't assume that this would cause the tire to burp. It's more a function of rim width vs tire width. There's a great explanation on Pinkbike
    SantaCruz Tallboy C
    SantaCruz Solo C
    Specialized Fatboy
    Trek Madone 8
    Kestrel RT 700
    Lemond Zurich
    I live in the SoCal Desert and I run the WTB Mutano Race 2.4 ghetto tubeless on the trail. They usually weigh in at 600g and roll pretty well compared to a big blocky lugged tire. I'm 155lbs and ride aggressively. I haven't had any problems cutting the sidewalls or burping. Mine are mounted on Mavic Crossmax SL Disc wheels (these are great at sealing most tires). The Bronson Race 2.3 is also great as a rear tire if you want a little more traction than the Mutano, but you gain 50 grams. The side lugs of the Mutano grip very well in the southwest and should also hold well on roots. I gave up on non-UST contis, nevegals, and fire pros because they all burped and cut. Most UST tires weigh too much for me.
    I have now a combo Maxxis Ardent EXO 2.4" in front and Conti Rubber Queen 2.2" UST back. I've really liked the combo so far, the "not-so-tall" tread pattern and big air volume(both are about the same size on air volume) helps with the rolling resistance, both weight about the same ~800grams. So, those weight about the same as your current setup, but the air volume is bigger.
    The RQ works nicely on UST rim(I have Crossmax ST's) and you can run those with quite low pressures, I have usually 1.1-1.3 bar on rear, grip is really good on all kinds of surfaces. I don't like this up front, the side knobs are too small. Also the tire sidewalls are wider than the side knobs, this causes the sidewalls to scratch easily if you have to ride between big rocks...
    The Ardent works also nicely on UST rim, but according to my experiences, running with less than 1.5bar will cause burping(since not actual UST/TL-ready tire), but 1.5..1.8bar gives nice grip and no burping. This works also very well as rear tire, due to the ramped center knobs.
    WTB Bronson race 2.3" would be an interesting contender, I'll probably try that next, when the spring comes here some day...
    Ach, and could you tell which kind of terrain you ride...?
    BMF
    Oct 2007
    Quote Originally Posted by smithrider View Post
    +1 on on Nic for front tire, Ralph for the rear in the tubeless ready format with sealant. I've been pretty happy with the grip in all sorts of conditions.
    ban
    ban is offline
    does the Nobby Nics 2,25 in trailstar compund exist or it`s only in the 2,4 size?? I think in the 2,25 version it's the pacestar compound which I think it's a little too hard as front tire
    BMF
    Oct 2007
    Quote Originally Posted by ban View Post
    I find the 2.35" Snakeskin TL plenty grippy with the pacestar compound when I run it around 27 psi. I haven't tried the other compound, as the 29er version is only available in pacestar where I shop. Maybe I'll try the 26" version in the trailstar compound in a couple months when I have a 26" bike again.
    You might try the Specailized Ground Control. Rolls good, good grip, solid side walls, and all around nice tire.
    Ride the dream
    Reputation: EnglishT's Avatar
    It all depends on exactly what your conditions are (description somewhat vague).
    Bonty XR4 may be worth a look.
    I am waiting for my set of XR4's to arrive and I will be setting them up tubeless. Will post impressions after I've gotten some time on them.
    2011 Santa Cruz Blur LTc
    2005 KHS DJ200
    2005 Rocky Mountain ETSX-70 (stolen)
    Ride the dream
    Quote Originally Posted by nh4cl View Post
    I really like them - did you get the team-issue tubeless-ready ones?
    They do come up quite large, but thats OK by me.
    LightJunction.com
    Reputation: lightjunction's Avatar
    I'm a big fan of the Rocket Ron for saving weight. They track pretty well over a variety of terrain too. I run a non-UST tire with Stan's sealant in them.
    We sell quality bike headlights and flashlights.
    www.LightJunction.com
    SANCTUS
    Reputation: BUSTELO's Avatar
    Feb 2012
    Quote Originally Posted by One Pivot View Post
    you may want to do some research before you post next time
    Hutchinson Tire : PYTHON - Tubeless Light
    SANCTUS
    Feb 2012
    Hutchinson Tire : PIRANHA - Tubeless Light or a more aggressive UST tire at a resonable weight.
    SANCTUS
    Feb 2012
    Hutchinson Tire : COBRA - Tubeless Ready lots of UST or tubeless ready tires that are reasonably light, Bontrager has good stuff too.
    Nov 2008
    whats a good rear tire for new england trails , just ripped a maxis beaver and a specilized control in two weeks,thanks
    SANCTUS
    Feb 2012
    SANCTUS
    Feb 2012
    430 gm 29er race tire Bontrager: 29-0 (Model #08308)
    SANCTUS
    Feb 2012
    Quote Originally Posted by msmolly46 View Post
    here is a handy site this is a lightweight reasonably tough tire.Check out the graph reference in regards to different aspects of their tire.Seems to me the tougher a tire the heavier with very few exceptions.Hutch tires with hardskin are the most rugged in my opinion, had a Toro duraskin that lasted well over a year.Hutchinson Tire : TORO - Tubeless Ready
    Oaktown Honkey on Strava
    I Love Geax Mezcal 2.3 TNT (summer), Geax Gato 2.3 29er, and My Hutchinson TORO tubeless ready 29er 2.1 is a pleasant surprise. I run at 25 psi now. I wish TORO was 2.3. Python not so much for me as rocks tore it up each ride. I live in rocky area. Check out GEAX.com. Good website regardless of your choice of tire.
    SANCTUS
    Feb 2012
    Hutchinson Tire : PYTHON - Tubeless Ready or maybe this, a fast roller.
    Yeah BUSTELO, The TORO hardskin is really surprising me. Endless volcanic rock and it is doing well. 6" wide loamy singletrack is not forgiving either, and this tire grips well (basic knobby style is awesome). Not cheap. I love tubeless ready tires on UST rims.
    SANCTUS
    Feb 2012
    I run mine on Shimano tubeless wheels and Mavic UST.Hardskin is spendy but seems to last twice as long
    Dec 2008
    Thanks again for all your suggestions, everyone! In answer to the question about what sort of trails I typically ride on... I'm in Edmonton, Alberta, where we have a lot of clay in the soil, while our trails are fairly twisty, narrow, rooty singletrack. You're almost always guaranteed to encounter mud somewhere on your ride, regardless of how long it's been since it last rained.
    Ride the dream
    So in short... you want something that sheds VERY well (because clay sticks in like a *****), preferrably uses relatively soft rubber ("mud" implies it gets wet, so roots may be wet?) and maybe not too huge (say 2.1-2.25ish?) if the tracks are particularly narrow?
    My earlier recommendation (Bonty XR4) might be a decent choice in that case, but perhaps not quite ideal.
    The rubber isn't rock hard, they shed OK rather than brilliantly and they're quite big (for a 2.2)... but they do fulfil the need to be lightweight and tubeless ready.
    Condition specific obviously, but they're quite a bit lighter and roll better than the Toro's I had on the bike before - but don't shed as well and aren't quite as good in mud (though not terrible in it), though funny the 2.2 bonty is bigger than the 2.35 toro.
    The 2.1 barracuda (hutchy) is a nice tyre (worth mentioning here) too actually, if you can get one in MRC medium rubber (don't get the harder rubber version - it'll suck on wet roots).
    SANCTUS
    Feb 2012
    Barracuda works great for me, good price too, usually on sale.
