Results 1 to 2 of 2
    Recco thorn resistant tires
    I frequently get pinhole flats when riding my local trail. Sometimes the hole in my tube is so small I can't even find it with soapy water. I inspect the inside of my tires and find nothing substantial, but I find lots of broken off thorn tips in the base layer of the tread. I think the tiny tips of the thorns are poking through and putting a pinhole in my tube.
    I remember the inside surface of old tires I had being a rather hard plastic. My new tires are very soft and rubbery on the interior. Can you recommend some XC 2.10 tires with a tough inner lining?
    I looked at the plastic tire liners, but they seem kind of hokey. I'd rather not pump a bunch of heavy slime in there, either.
    Reputation: bholwell's Avatar
    Oct 2007
    If you don't want to try going tubeless w/ Stan's (which usually doesn't add any weight, btw), you could try tire liners made of Vectran (definitely not "hokey").
    http://www.bikepartsplace.com/products/tire-liner-duro/
    Tire Design & Development Engineer. The opinions expressed in this forum are solely my own.
