    JmZ
    JmZ is offline
    Reformed Lurker
    Reputation: JmZ's Avatar
    Rebuilding a Hub - Nuke Proof
    I'm looking for any advice or instructions about a Nuke Proof Superfly rear hub.
    I've got about four years on the hub, and the freehub body now is as tipsy as a freshman's first binge. The whole cassette body wobbles. The axle is straight, and I know they (Nuke) used a modified Shimano freehub. Only noticed it because my hardtail needed some TLC and the wobbling cassette made shifting worse.
    So anyone have any experience in replacing a freehub body on a NP hub?
    Local shop hasn't played with Nuke Proof Stuff in years and said they can't get parts. So nothing lost if I try to fix it myself. (Trashed rear hub vs what, a trashed rear hub?) I've replaced freehub bodies before so I'm not too worried about that.
    <b>Any</b> help is appreciated! Thanks!
    JmZ
    JmZ
    From one flat land to another.
    Advocate as if your ride depends on it...
    JmZ
    JmZ is offline
    Reformed Lurker
    Found It! See attached Pic
    Quote Originally Posted by JmZ
    JmZ
    Found it in the depths of Google, or was it Dogpile... anyways...
    It is attached for anyone that cares.
    JmZ
    the drive side bearing fits into the aluminum cup that
    fits into the freehub. It is pretty hard to get that cup out in one piece. I used an XT freehub on my nukeproof bombshell hubs and it works fine. If you destroy that aluminum cup let me know because I had a friendly machine shop make up a bunch and I can give you one if you need it.
    Aug 2015
    Quote Originally Posted by ol-crank® View Post
    Resurrect an old thread here but @ol-crank you don't happen to have any of those aluminum bearing cups still do you?
  1. Nuke Proof or Fetish Frames?
    By ISUPsyclones in forum Bike and Frame discussion
    Last Post: 02-13-2005, 04:45 PM
  2. Are Nuke Proof and Syncros still going?
    By KleinAttitude in forum Ritchey Design
    Last Post: 08-03-2004, 10:11 PM
  3. Deraileur Hanger for Nuke Proof Frame??
    By Mud in forum General Discussion
    Last Post: 03-19-2004, 12:55 PM
  4. Derailleur Hanger for Nuke Proof Frame?? (General X-post)
    By Mud in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-18-2004, 11:17 AM
  5. 24h rim with 32h hub? Leave every 4th hole out?
    By Duckman in forum Wheels and Tires
    Last Post: 03-10-2004, 09:53 PM
