Results 1 to 2 of 2
    Mar 2014
    Rear Wheel Keeps Moving Out Of Alignment?
    My rear wheel keeps moving out of alignment, enough that it slightly rubs against the frame. My wheels are Mavic 823's with Maxxis Highroller 2.5's with 7" rotors just in case you need to know. Is this spoke tension or the skewer or what? How do I fix?
    mtbpete
    Reputation: changingleaf's Avatar
    After every ride can you see that the wheel has shifted in the dropouts, and will it move back into place when you re-clamp the rear wheel? If so, there's a very good chance that the skewer doesn't clamp tight enough. Most skewers with external cams do not clamp tightly relative to the force required to close the lever. Try a Shimano XT or XTR skewer. They apply much more clamping force relative to the hand force required to close the lever. If your tire is just rubbing the frame then you probably don't have enough clearance for that size tire.
  1. Rear Wheel moving on hangers?
    By Van G in forum Wheels and Tires
    Last Post: 09-12-2013, 08:42 AM
  2. Rear wheel keeps moving in the frame
    By infanterene in forum 29er Bikes
    Last Post: 11-14-2011, 05:10 PM
  3. Blur LTc rear wheel alignment
    By marko_tarrant in forum Santa Cruz
    Last Post: 09-16-2011, 07:22 AM
  4. Possible Rear Wheel Problem? Cassette Moving.
    By jonshonda in forum Beginner's Corner
    Last Post: 04-28-2011, 11:40 AM
  5. front wheel alignment
    By wils07 in forum Specialized
    Last Post: 03-28-2011, 11:38 AM
