Results 1 to 5 of 5
    Rear wheel build recommendations?
    Looking to build up a near rear wheel. For my friend. 29er, running say 2.3 -2.5 tires. Thinking about 32 hole, dt swiss 240 for the hub. Weight important but not the deciding factor. He is maybe 175 lbs, rides tough trails, not brutal on equipment. Double butted spokes, brass nipples. Rim thoughts? Thinking 30 mm id width. Aluminum.
    mtbpete
    Reputation: changingleaf's Avatar
    You can't go wrong with the DT 240. My first choice for an Alloy rim close to 30mm is the Stan's Flow MK3.
    ^^^^ Thanks.
    Jan 2009
    I love the build I am riding now: Hadley hub, 32 db spokes, WTB Frequency Team i25 rim. If I had to rebuild, I would be fine with a Hope or Bitex hub to save on the cost. I like the DT hubs but you have to pay quite a bit extra for the higher POE bits and, riding singlespeed, I feel higher POE is important.
    Thorn in your Sidewall
    Vassago Jabberwocky
    A DT350 hub with 36 or 54t ratchet upgrade, Sapim Laser spokes and Polyax nipples from Dans Comp.
    I would choose a 35mm inner width rim and run Bontrager XR Team tires in 2.35 or 2.4. They have a more rounded profile to work better on wider rims at lower pressures. A XR4 2.5 or 6 is coming soon.
    https://www.danscomp.com/Sapim/bmx/
    WTB Asym i35 rim
    https://www.wtb.com/products/asym
    Asym gives you more equal spoke tension side to side.
  1. Wheel build recommendations
    By fiatjeepdriver in forum 27.5
    Last Post: 11-24-2014, 10:48 PM
  2. Rear Wheel Recommendations -- 29er SS XC
    By bank5 in forum Wheels and Tires
    Last Post: 07-28-2013, 10:33 AM
  3. 29er wheel build recommendations - which rims, spokes, hubs?
    By FreeGrazing in forum 29er Components
    Last Post: 09-15-2012, 04:45 PM
  4. New rear wheel help/recommendations
    By meSSican in forum Downhill - Freeride
    Last Post: 08-22-2011, 07:22 PM
  5. Replies: 15
    Last Post: 06-19-2011, 01:15 PM
Members who have read this thread: 31
