Rear Disc Hub DMR or X9?
Printable View
  • 01-19-2011
    Waterat Pat
    Hi All,
    I have been searching on the net for a new rear disc hub that does not break the bank.
    I found a couple but cannot find any reviews or info on either. Anyone have experience with these 2 hubs?
    1. DMR Revolver 10mm thru-axle 135 spacing 32 hole 385g $65
    2. Sram X9 9mm QR 135 spacing 32 hole 385g $50
    The DMR looks trick with the aluminum thru-axle and I have actually broken a rear QR once.
  • 01-19-2011
    mtnbiker72
    Well the new SRAM hubs had the look of a great value hub. Cartridge bearings, steel FH body, 3 pawl design...I was ready to pick one up until I found out they have a 12 point engagement. That is horrid, even cheap Formula hubs have a 16 point engagement!
    I ended up buying a SLX rear hub with the 32 point engagement FH body. It comes centerlock, but you can buy adapters (or just use a centerlock rotor, which I am with my Avids).
    Here is my exact setup
    Shimano M665 SLX hub...$45
    Shimano 160mm RT-53 rotor...$16
  • 01-19-2011
    Fix the Spade
    Spend the extra, get the DMR.
    Revolvers have been around for years, it basically a good hub, the only mark against it is that it uses slightly odd sized bearings (larger than many other brands).
    Or grab a Shimano hub, safe bet.
  • 01-19-2011
    mtnbiker72
    Anybody know how many point engagement the DMR Revolver has? I'm guessing somewhere between 16-24 looking at the freehub body (internal 3 pawl).
  • 01-20-2011
    Waterat Pat
    I found a forum where a guy measured the engagement points on the 3-Pawl Revolver hub and he said it was 18. Isn't that what the older shimano hubs were?
  • 01-20-2011
    Bordershy
    TBC Revolution Hub
    Transition is closing out there Version 1 rear hub 135mm 10mm QR through axle 36H for $40 direct from there web store. Got mine this week & took it apart to see how it's constructed. WOW
    Basically a cheap Hadley::thumbsup:
    24 POE if it matters
    If your a weight weenie look elsewhere........
  • 01-20-2011
    mtnbiker72
    16-18 point depending on the model. I never worried about POE when I rode the wide open trails in the SW and California. But on the twisty narrow log and root strewn trails up here in the PNW when I'm in the granny a lot, I'm already noticing the difference on the SLX hub in a couple rides.
  • 01-20-2011
    Waterat Pat
    Went to the Transition website and those hubs look way nice. No weights listed so what does your weigh? Unfortunately all of my rims are 32 hole.
    I noticed the Version 3 is 32 hole at $99.
  • 01-20-2011
    Bordershy
    It's 568g W/steel through qr axle. Sorry you asked now?
    Can't really recommend it for anything other than what i bought it for= Bombproof FR/DH rear wheel.
  • 01-21-2011
    Waterat Pat
    [QUOTE=Bordershy]It's 568g W/steel through qr axle. Sorry you asked now?
    Never sorry. That's what these forums are all about. Definitely not for me as I live right next to XC heaven Henry Coe SP.
