Results 1 to 9 of 9
    Nov 2015
    Ratchet ring won't budge! Pleas Help.
    I'm in the process of upgrading my freehub body on my Sun Ringle Charger Pro wheels. The upgraded freehub also requires a different ratchet ring. I cannot get the stock ratchet ring to budge! I have the proper ratchet ring tool and have used a breaking bar and a bench vise to no avail. Right now I'm soaking the rub with penetrating oil and will try again tomorrow after it soaks over night.
    Wondering if anyone has any advice for ratchet ring removal.
    Thank you.
    Reputation: Mr Pig's Avatar
    Never done it but bear in mind that the hub body is aluminium. Be VERY careful over how much force you put into the body or you'll feckupakate it.
    I tried a couple of time, without result. I had to send the wheels back to the manufacturer.
    mtbpete
    Reputation: changingleaf's Avatar
    Put the tool in a vice and rotate the wheel counter clockwise.
    I had a Profile hub with a chipped drive ring which Profile would replace under warranty. Profile wanted the complete wheel not just the hub. When I received the wheel back the hubs ano. was discolored. Apparently they had to heat up the hub shell to get the drive ring to loosen. I ended up w/ a new hub after complaining about the discolored hub shell. I have a a few ring drive failure experiences and most manufactures consider it an in house repair.
    Quote Originally Posted by changingleaf View Post
    I've done that. removing a stuck free-wheel, and bent the hub.
    mbtr member
    Reputation: scottzg's Avatar
    Quote Originally Posted by keen View Post
    Dang, Torquenstein.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
    Reputation: ScottW's Avatar
    When I replaced my ratchet ring on my P321 hub I used the proper tool and hit it with an impact gun. Spun right off.
    Quote Originally Posted by ScottW View Post
    Impact wrench is a good idea. Best idea posted so far.
  1. Fork won't budge.
    By WillT in forum Beginner's Corner
    Last Post: 01-09-2012, 09:56 AM
  2. Chainring bolts won't budge!!
    By onepivot in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-04-2012, 08:19 AM
  3. Replies: 3
    Last Post: 08-15-2011, 08:44 PM
  4. Complete beginners Bike on a budget. Pleas advise :)
    By neiljwd in forum Beginner's Corner
    Last Post: 05-11-2011, 08:34 AM
  5. Rock Shox Tora 302 owners help pleas
    By irish1883 in forum General Discussion
    Last Post: 04-28-2011, 05:07 PM
