Results 1 to 36 of 36
    Rant: Converting ZTR Arch EX to tubeless
    Hi,
    I must apologise in advance for the rant, but I have to let my frustration out.
    A couple of years ago, I decided to treat myself to some nice wheels. I went for Chris King Hub with ZTR Arch EX hoops. The wheels are really nice. Somewhat light and stiff, nothing wrong with them, unless you actually want to mount a tire on them.
    I have been riding for 7 years on a variety of wheels and I have never seen wheels that are so hard to mount tires on. I have always been able to mount tires with plastic levers, but on the Arch EX, I have to use metal levers in order to get the tires over the rim. And I am not talking, one specific tire, I am talking a variety of tires, from Contiental, Schwalbe and Maxxis. Every single one of them has given me grief to mount. Once it is on, they need to be pumped to 55psi in order for them to properly sit.
    As you can imagine, using metal tire levers, I have pinched a number of tubes while trying to mount the tires, so last night I decided to convert them to tubeless using Stan's system.
    I have been running Stan's for over 4 years and only once have I had a tire that I couldn't seal. Considering that the rims are Stan's and that the system is Stan's as well, I thought I was on for an easy one... Boy was I wrong.... I wrestle with the rims strip to keep it in place as I was trying to mount the tires. Most times, it would move in the process and get pinched between the rim and the tire beads.
    Something that should have taken 30 minutes tops to do, turned into an almost 3 hours endeavour with plenty of cursing. I ended up getting it done, but it shouldn't have been this hard. I am seriously considering throwing them out and buying some new rims that are easier to mount tires on and to convert.
    End of rant.
    Am I the only one with this problem? I know they are super popular, so maybe it is something I am doing wrong.
    Thanks a lot,
    Bertrand.
    A climb is really just a flat piece of road that points up. A headwind is a climb that you can't see. So it's all flat road, really.
    West Chester, PA
    Easy - You don't use rim strips on stan's rims. Or tubes.
    West Chester, PA
    Movies - Yellow Tape Install
    It's amazing how much difference a few millimeters can make.
    If it was a shop employee that told you to use strips on those wheels please kick him in the nuts.
    Quote Originally Posted by 92gli View Post
    I have tried without the rim strip and I couldn't even inflate the tires, despite using a compressor.
    Did they come direct from Stan's? If so, put the original stems back in, leave the yellow tape alone, spray w soapy water, install tubeless tire. Pump up. Else install yellow tape, press on w tube.
    Arch rims are slightly larger to help thing seal. Mine were tough but sealed right off.
    If you can be blissfully ignorant to the notion that something is impossible, then you might surprise yourself. -- Andrea138
    Hi,
    no... I bought them custom made from Universal Cycles.
    Have you had any problem mounting tires on the rims? I have always had a ***** of a time to do it.
    Quote Originally Posted by desnaephoto View Post
    Reputation: Ronnie's Avatar
    I've got to ask about your technique when mounting tires on your rims. When mounting with tubes as long as the tire bead is on the rim it will inflate but this is not the case with tubeless. There is a proper way to mount a tire on your rims. I can get most tires on ZTR rims by hand. Sometimes I need a plastic lever for the last few inches.
    You need to start mounting opposite the valve making sure that the tire bead is in the middle of the drop channel all the way round. This allows more play to pop the tire on at the valve.
    Also when inflating ensure that the tire (both sides) is in the channel all the way round except at the valve. You should then be able to easily seat the beads with a floor pump and not much effort.
    The trouble with having an open mind is that people will insist on trying to put things in it.
    Now, this is a stupid question, but you're not trying to mount UST tires to a Stan's rim, are you? You're pretty hosed at that point, if you are, as the rims are not even close to being designed compatible with them.
    Quote Originally Posted by wschruba View Post
    Really? Not according to NoTubes. On their Recommended Tires page I quote the following:
    Compatible Tubeless Tires
    Most Tubeless tires are compatible:
    UST, LUST, UST-lite, 2Bliss, Tubeless Ready, TNT (tube no tube)
    I will only use a TLR or equivalent tubeless ready tire on my NoTubes ZTR rims. TLR tires have the same bead as a UST.
    Quote Originally Posted by Ronnie View Post
    Really?
    Yes, really. Of course stans isnt going to tell you that their rims dont work with all the most popular tires on the market.
    Stans IS ghetto tubeless. The new stans rims are even more ghetto tubeless and work with even less tires.
    Using only tubeless tires on stans rims is about the worst setup you can pick. Its two blatantly opposite systems, and the worst choice.
    UST and tubeless ready is standard now, stans is outdated and we really need to accept that and move past it. Maybe stans will come around and start making a real tubeless ready rim.
    Quote Originally Posted by One Pivot View Post
    Thanks for telling me. I can't say much now I need to rush into the garage to immediately remove my TLR tires from my two sets of Stan's rims.
    West Chester, PA
    I just started a fire in my backyard and burned up my stan's rim equipped wheels and my specialized and schwalbe tlr tires. They all worked flawlessly over the last few years. But I couldn't go on knowing that there is something out there that works better than flawlessly.
    To the OP: just use yellow tape and regular old tires and you'll be fine. I too have a tight fit with tubes; but why bother? I also find they air up fine with a floor pump.
    Ignore the anti Stan's lobby, and yes, we all know Stan's are too big and otherwise just wrong and ghetto as all the "experts" around here will tell you. I'm willing to bet there are more Stan's being run tubeless than all the other companies combined. Maybe they'll be bankrupt in the future ... but today they work great.
    I'd love to see stats on market share - I bet Stan's owns it. Yes, I know they suck!
    Ninja Master Powers
    Reputation: DWill's Avatar
    Aug 2010
    The solution is simple. Dump the stans and get a det of Enve's.
    took me less than 30 minutes to set my Enve's up tubeless. Hans Dampf's went on and set with a floor pump. Took the valve stems out pit sealant in, re-inserted valve stems pumped em upů done.
    Quote Originally Posted by DWill View Post
    Always the same budget friendly solution ... took me less then that to tape and setup arches and I was tubeless noob.
    Sweet merciful crap!
    What a train wreck of a thread!
    Yup....$800 rims cure all.....
    Quote Originally Posted by the mayor View Post
    Lately all Stan's threads end this way. Now go smash your Stan's rims!
    Quote Originally Posted by SS Hack View Post
    Do I need a UST compatible hammer?
    Or does Enve make a $800
    hammer that would work?
    I wonder if any Chinese companies make a cheaper hammer that would work?
    Seriously...how the F do people F up mounting a tire?
    change is good
    Sep 2004
    Mounting a tire with a tube to a UST/BST rim can be a PITA. I use a smaller "cross" tube to get back to the trail head. If you like tubes, maybe relaceing with standard rims would be the easiest solution.
    Feb 2005
    When I picked up a set of Arch EX wheels, I also had a nightmare experience trying to run tubeless. For me, the solution was to ditch the "yellow tape" and retape with Orange Seal's tape. Once I switched over, I was able to get everything up and running (with a compressor). I'm giving the Orange Seal sealant a whirl as well. So far, I'm a happy camper (with no flats!).
    Good luck!
    gorilla tape?
    roccowt.
    rocnbikemeld
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    Have had no problems with most non-UST/TR tires.....an have tried a lot.
    WTB Vulpine 29x2.1 was the only one that had me cursing.
    I resolve to constantly assert my honest opinion on anything and everything - whether it is requested or not.
    Bucky the Cat
    Weird all the differing experiences with Stan's - some think it's easy, some not. Tires make a huge difference I guess.
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    Quote Originally Posted by dbblackdiamond View Post
    A rim strip is not the answer to that issue, but it is the cause of your difficulties mounting tires.
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
    Hi everybody,
    my trip is over, so now i can try to properly follow the directions given here. This afternoon, I pulled the rim strip off of the rim and installed the yellow tape in. I then lathered everything with soapy water and installed the tire. It went on a little easier than before. I had also installed a valve on the rim. I then tried to inflate the tire with a compressor and no luck. It was oozing sealant, but wasn't really inflating at all. The tire is a non tubeless tire. At least with the rim strip, I could inflate it and seal it. I'll bring it to a shop so they can do it, because I must be doing something wrong here.
    Reputation: BacDoc's Avatar
    I've had great experience with Stan's getting Schwalbe, Maxxis and Panaracer to mount and hold air without issues. Even got the Crossmarks to work with Stan's and could never get them to work ghetto on other rims.
    I was able to get most on without levers and don't consider myself having anything but normal hand strength. My experience is with several sets of Arch and Arch EX rims.
    Reputation: KevinGT's Avatar
    Dec 2012
    My first tubeless application was a set of Stan's Crest rims and Schwalbe Nobby Nics with Snakeskin. I watched a video, applied the tape, popped the tires on, and pumped them up. Sealed first shot and haven't lost a single PSI in 3 weeks. The whole process, including watching the video, took about 20 minutes.
    Easy as can be. Easier than tubes, honestly.
    But now that it's been declared to be an obsolete system, I guess I'll have to scrap it and go with something harder, less effective, and heavier.
    or not...lol@somepeople
    Dec 2011
    It definitely does. I've ran four different tubeless tires on my Scott Spark with OEM Alex wheels and some were harder than others. I mounted a UST Crossmark with a bike pump while a 2bliss Ground Control was difficult with an air compressor and even then it took a few weeks of riding before it would stop going flat overnight.
    I've got some Stan's Flows coming in the mail so it will be interesting to see how easy they mount.
    Ok im a little confused. I read this entire thread and the majority of you are calling Stans crap and obsolete. What do you all suggest otherwise? Is there a better solution for going tubeless? Ive seen the so called "ghetto tubeless" where they use electrical tape and cut 20" tubes on standard 26" rims with Stans sealant which seems to work. Are you all insinuating that Stans rims are basically $500 versions of this? Not trying to start a battle or anything just want some clarification cuz im seriously considering going tubeless and would like to do it right.
    SS Pusher Man
    Sep 2001
    There are newer systems that seen to work very well. Stan's has always been a version of ghetto tubeless.....basically converting non-tubeless tires to tubeless.
    The new WTB rims/wheels seem to be getting a lot good reviews for running tubeless with tubeless tires.
    Personally, I have 3 sets of Stan's wheels, a set of Crank Bros. wheels and a set of Velocty Blunts all converted to tubeless.
    Bucky the Cat
    Quote Originally Posted by BacDoc View Post
    This ^^^ has been my experience too. I do typically use a compressor for most tires, but only because it's there and lets me skip the soapy water.
    FWIW, if anyone thinks any bicycle tire is a PITA to mount. Go mount a rear tire on a motorcross bike with a set of spoons and you'll NEVER complain about bicycle tires again.
    There's only one bigger sheep than manufacturer's - consumers! - AndrewTO
    Dec 2011
    Quote Originally Posted by mtnbikej View Post
    Stan's works well too. Air doesn't care how it's sealed in. If you can run the tire you want, on the wheel you want, at the pressure you want, and not have it go flat, then what is there to complain about?
    SS Pusher Man
    Sep 2001
    Quote Originally Posted by JonMX5 View Post
    I agree......a lot of the anti-Tubeless supporters are complaining about tubeless set ups from years back. Older rims vs newer rims is a slightly easier task of setting up tubeless.
    Like I said, I haven't had any trouble setting up both sets of Stan's wheels that I have.
    Bucky the Cat
    Reputation: ghettocruiser's Avatar
    I agree that setting up regular tires tubeless with sealant is more hassle than airing up a dedicated tubeless tire, but non-tubeless tires are also lighter and cheaper, so this should surprise no one.
    Tires aside, I haven't noticed a tangible difference in set-up difficulty between a Stans rim with yellow tape and a UST rim. Unless you count the 5 minutes it took me to put the tape on 2 years ago. Performance has also been pretty similar.
    The above statements have not been evaluated by the Food and Drug Administration
  1. Stan's Arch + Tubeless Ardent 2.4 & 2.25
    By Photogorama in forum 29er Components
    Last Post: 02-12-2014, 12:34 AM
  2. Converting to Tubeless.
    By Eyetattoo in forum General Discussion
    Last Post: 10-28-2012, 09:49 PM
  3. Help converting Rovals to tubeless
    By stom_m3 in forum Specialized
    Last Post: 06-07-2012, 01:23 PM
  4. Converting to Tubeless
    By givati in forum Wheels and Tires
    Last Post: 02-18-2012, 08:50 PM
  5. Stans Arch going tubeless?
    By dirtT in forum Wheels and Tires
    Last Post: 04-13-2011, 07:12 AM
