Results 1 to 9 of 9
    Lets RIDE!
    Reputation: Jim Z in VT's Avatar
    Rampage SC 2.35, XC717, stans kit?
    Panaracer Rampage SC 2.35 tires
    Mavic XC717 rims
    Stan's tubeless kit (probably with one of the stans/slime/latex homebrew sealant recipes)
    What do you think....is this combo OK? I was wondering if the rim was too narrow for the 2.35, but I've read in other threads that the Rampage runs a little small.
    Thanks.
    It's not about speed, it's about lack of control.
    Unfit Norwegian
    Reputation: Dazed's Avatar
    The rims will work just fine with the tires. Yes, the Rampage SC's are pretty small for their claimed size.
    they're not that small.. bigger than a nevegal 2.1, bigger than an ignitor 2.35. its just a little under its rated size.
    i run them on a 28mm rim, probably 21mm inner diameter and its perfect. i ran the older rampage 2.35's on 30mm rims and it rode very well too. tire feel on a rim is subjective, and on paper that tire might be fine on that rim, but its going to ride sloppy.
    id definitely not do it.. fwiw, i sold my xm719 for wider rims to run rampages.
    i am however, just thrilled with the new rampage 2.35 SC its my new favorite front tire. if you like how nevegals ride, you'll love rampages. its basically a nev that actually rolls well.
    Unfit Norwegian
    Quote Originally Posted by One Pivot
    Yeah, they actually are. I should think a 2.35" tire ought to be bigger than a 2.1", btw.
    Why is that, exactly? Sure. Wider rims hold big tires more steady, but it will work fine with 717 discs as well.
    I have run a 2.35 Nev on a XC717 tubeless. Looking back on it now it was probably a horrible idea. The XC717 does not hold a strong bead without a tube in it and would be prone to burping. Do it at your own risk.
    Quote Originally Posted by Dazed
    it is bigger. a lot of 2.35's are smaller than nev 2.1's, its an easy reference. the rampage is bigger than a lot of 2.35's out there. shiggy measured out the rampage tread width at 2.39 anyway. its really not that small of a tire.
    running 45psi in any mountain tire will work fine too.. thats kind of what im saying.. its beyond not ideal. its not like it'll make you crash or anything. a smaller tire might even hold a line better since its not squirreling all over the place. you'd have to run pressures pretty high to keep the tire from folding over.
    The Bubble Wrap Hysteria
    Reputation: mtnbiker4life's Avatar
    The Rampage is my favorite tire......they just work for the trails I ride. I started running them on XM 819, Stans ARCH and now Blunts. I have a set of 717s that I fitted with Rampages for my HT. They worked fine but look a little bulbus. I think if you were to run to low air pressure they might roll off the bead. I'm now running a 2.1 tire on the 717 wheel set. But I would give it a try to see how it works for you.
    Unfit Norwegian
    Well, compared to the tires i wanted to replace with them, Schwalbe Big Betty 2.4 (real 2.4"), they're puny.
    On 23mm (internal width) Flows, I measured the Rampage SC thread to 57mm ( 2.24") and the casing to 52mm (2.05"). I don't remember how tall the tire was, but not very. That's a pretty low volume for a 2.35" sticky trail tire in 2010.
    Lets RIDE!
    Burp flatting is what I was worried about with the narrow rim. But if I can't run them at low pressures, why bother....I mean, that's half the point of going tubeless right? I have no experience yet with tubeless. I've been running 2.25 Mibros (with tubes) at 35psi, but I guess they're generally considered to be undersized. Maybe I'll just throw on the new pair of Fire XC 2.1s I have lying around here somewhere and try them with the stans kit before I consider upsizing. lacing on new rims is definitely not in the budget for this season.
