Results 1 to 38 of 38
    ~Reformed Mechanic~
    Reputation: Ace5high's Avatar
    Jan 2011
    Racing Ralph the best light trail tire ever?
    I really like the racing ralph for a light trail tire on the rear. The ONLY reason I don't keep running them is the fast wear and high cost, so Ive been looking for a cheaper alternative thats as good, or.... dare I say... even better!?
    The problem is that I simply cant find a tire that equals the same high volume, as light as, rolls fast, and grips like a Racing Ralph. With others its always a compromise. Most that grip as well are heavier or slow rollers...
    Is it possible that the Racing Ralph is simply the best high volume, light, fast grippy rear tire being made currently?
    I do all my own stunts, but never intentionally...
    Reputation: thickfog's Avatar
    Oct 2010
    Re: Racing Ralph the best light trail tire ever?
    I love them. Your findings are what I have noticed too.
    CRAMBA Chairman
    g3h6o3
    Reputation: PissedOffCil's Avatar
    Oct 2007
    I agree as well!
    Check out my SportTracks plugins for some training aid software.
    Reputation: Idshooter's Avatar
    I really love the Racing Ralph in the rear and Rocket Ron in the front combo and have been running that combo for the last 2 seasons on my hardtail. I have found them to be very fast, supple and very predictable. Yesterday I received a pair of MICHELIN Wild Race'R Ultimate 26x2.25. Got the pair for just under 100 shipped. Mounted and aired up tubeless easy on a set of DT 5.1 rims. They seem very thin and light but are supposed to be very puncture resistant. The look and feel lead me to think "fast" but the true test will be in the ride. Will report back tomorrow afternoon after their maden voyage.
    Up front, I really like the Ra-Ra 2.4 when dry, on my local (loose over hard) trails.
    On the rear, I shredded the side knobs within 300 miles (2.25), and have since gone back to a Saguaro
    for a fast durable & cheap solution.
    Wonder what other high volume tire(s) people like on the rear that are both durable & fast?
    Reputation: madsedan's Avatar
    Aug 2010
    So far I have ben very happy with mine as well, I loved Fast Trak FA's that came out about a year ago for grip, rolling resistance, and weight but was forced to go to something else when I converted to 650b. The tires just feel more voluminous and its weird to me how it can be so grippy yet have such a low rolling resistance, great tire.
    Hardrock 29er, Niner EMD9, Cannondale F29, Camber Expert, 650b Nickel all gone.
    2014 Giant Anthem 27.5 here.
    Reputation: YeahWhatever's Avatar
    I use the Maxxis Ikon for my rear tire and a Nobby Nic for the front. The combination works very well.
    Dec 2009
    Quote Originally Posted by Ace5high View Post
    I presume your only talking 29er tires?
    Have you tried the new Ro Ro? Very fast.
    Alternative rear tires I use In 29er:
    I'd rate the 2.2 xking[ only in racesport version] as fast and a better light trail tire. May be a bit smaller volume but it's smooth for it's size and better grip. I've always rated the Geax tires for speed and smooth ride. Bit heavy but looks like they may have revised their casings for next year. Michellin std folding are very smooth and fast, but heavy. The advanced are smaller and lighter and should still be as smooth.Ikon doesn't have the same grip but is as smooth and also pretty fast . All four wear much better than the Ra Ra.
    Best front 29er light trail tire by a long long way is the Pre 2013 Ro Ro 2.25 followed by Xking 2.2 racesport. Hopefully they will get a 2.4 29er racesport this year?????. It would then be my 29er light trail front tire of choice.
    The old Ro Ro is so smooth, light, grippy with good speed. It blows everything away. Pity they ruined it for light trail with the new 2013 version.
    ~Reformed Mechanic~
    Jan 2011
    Quote Originally Posted by gvs_nz View Post
    I like the X-king but they are rather heavy, do they make a racesport version in 29" because that is something id be interested in.
    I am thinking of trying the new RoRo on the front after my NoNi wears out... What did they mess-up with the 2013 RoRo version? Weight? I thought it looked pretty cool
    Dec 2009
    They've been doing the 2.2 racesport for about a year now.
    On the 2013 Ro Ro they've lowered the edge and shoulder tread so it doesn't hang in there as well as pre 2013. A bit more predictable on hard pack and quicker. Better race tire now, pity they've ruined it as a trail tire.
    Isn't the nobby nic in place as the more trail oriented tire? My 2.35 NoNi gives unbelievable front end grip. I run it on my XC machine so I can hit the corners almost as fast as I want!
    ~Reformed Mechanic~
    Jan 2011
    ^ Yes its more "trail" then RoRo or RaRa, great grip, but not quite as fast.
    Dec 2009
    Quote Originally Posted by moshjack View Post
    I haven't run No No 2.35 in 29er. I have in 650b and I used to run the 2.4 in 26". Quite frankly i wasn't impressed with the 2.35. The soft compound and angled edge tread meant it was vague and lacked the bite that the pre pacestar 2.4 used to have. I did back to back runs with a pre 2013 2.4 Ro Ro 26" and preferred the Ro Ro to the 650B 2.35 No Ni.The Ro Ro is way better as a trail tire than it should be.In 26", I jump straight up to a Hans Dampf when the Ro Ro gets out of its depth. Th No Ni would probably be better when conditions get that sloppy that the Ro Ro edge tread can't touch hard ground. The Ro Ro edge tread is widely spaced and doesn't like it when it's really sloppy. Bit like dragging your open fingers through mud rather than a closed hand. Hd is much better in those conditions. Pity they dopn't do a 2.25 HD in 29er. I'd be a starter.
    Vincit qui patitur
    Reputation: owtdorz's Avatar
    Michelin Wild Racer Advanced 29x2.0
    Light, fast and durable so far.
    Vincit qui patitur
    2014 KONA Process 153
    2016 KONA Operator
    2017 Salsa Powderkeg
    2018 Santa Cruz Tallboy 29 C R
    Quote Originally Posted by owtdorz View Post
    I got my first outing on a set of 26x2.25's today. They were very fast on the climb and hooked up well. Didn't have any scary moments on the downhill but do need to develope my confidence level for this new tread. Only time will tell on the durability but I don't see any wear or damage after the first ride.
    Reputation: jetboy23's Avatar
    I haven't been impressed with the RaRa. Sidewalls are too thin unless you get the snakeskin version which increases weight. Traction depends on finding the perfect tire pressure which will then increase its rolling resistance (despite what Schwalbe says, yes, it feels like it rolls slower to me). Cornering grip is just mediocre.
    I prefer Ikons, AKA's, or Crossmarks. But even they have downfalls. Ikon corners a bit worse than the RaRa. AKA's wear faster than the RaRa. Crossmarks weigh a bit more than the RaRa. I will take any of these con's over slicing a sidewall any day though. And price of RaRa's=$$$.
    Just my opinion though. Put your money on whatever tire gives you the most fun on the trails.
    ~Reformed Mechanic~
    Jan 2011
    Quote Originally Posted by jetboy23 View Post
    I agree with your assessments on these other tires. For me, I have been surprised that I haven't sliced a RaRa sidewall in two seasons... I was sure they were toast last summer bombing mountains/rock gardens in the Pisgah ranger district... They held up! I guess I can hold a good line!
    Dirt Abuser
    Reputation: Bail_Monkey's Avatar
    In the May MBA mag, they ran a tire shootout and the Specialized Ground Control is #1. 2.3" and 19.6oz or 556 gm. Feedback is really grippy over most terrain. Never used them, but want to give it a try on the front for XC riding. (We have all kinds of conditions in N.Cal) Currently running a 2.1 Bronson on the front which is OK...
    "Don't ride faster than your guardian angel can fly"
    Come on, dare me!
    Reputation: Jerome's Avatar
    Quote Originally Posted by Bail_Monkey View Post
    Don't believe all what MBA says (in fact, I'd say, don't believe most of what they say) since they work hand in hand with their advertisers, Specialized being one of the most prominent... That said, I love Specialized and have been riding lots of Specialized bikes and tires, but as far as I'm concerned , the GC is not their best - probably good on hardpack or loose soil, but my experience with the 2.1 Control version (not S-Works) has been far from stellar - many punctures (tubeless setup), noisy and pretty slow, and the grip was not impressive. I far prefer the new Schwalbe tires, especially the NN which came at 550 g (same weight as the 2.1) for more volume, better grip and better rolling resistance (IMO). The 2.25 RaRa, even in Snake Skin version, is still "only" 580 g, which is pretty good for a big(ger) trail tire - remember that the GC comes small for a 2.3.
    Reputation: fondoo's Avatar
    Sep 2012
    ive been very happy with my racing ralph 2.25 with snakeskin in the rear. the stock wtb moto 2.3 were a bit of a overkill on the GA trails.
    2013 Cannonale Jekyll 3 M
    Trail Ninja
    Reputation: Varaxis's Avatar
    Personal considerations > hype. If the hype here doesn't take your terrain and riding style in consideration, you can figure out a whole lot to argue against it, but what's the point? For me, both the rubber compound in the RaRa and Spec compounds seem to not work as well as the Maxxis 3c compound for SoCal dirt. I think they work better in the slightly moist. The RaRa slips out in the loose over hard (kitty litter over concrete-like hardpack) areas, especially where people skid. Ran the Spec tires a long while and they seemed mediocre, never coming alive until after it rained a little, which then became my favorite tires for such conditions. In the dry, I've had the Captain front washout in turns suddenly, which was never cool.
    Reputation: Vespasianus's Avatar
    Quote Originally Posted by Jerome View Post
    Yes, that MBA review is a joke. They compare a Schwalbe Hans Dampf to a Michelin Wild Race'R in trail bike tire shootout. They are two completely different tires and are designed for different things. MBA runs its comparisons like the old WWF (mismatched competition).
    On MTBR, the reputation is infamous.
    Dirt Abuser
    I picked up a free copy of MBA at Sea Otter last week and just thumbed though it. As with all mags, they are supported by advertisers so you have to take any product test with a grain of salt.
    With tires, there are quite a bit of variables like setup, conditions, terrain, skill level, etc. so someone that states something is good or bad may be entirely wrong when you/I try it out. (Kind of hard to do with mtb tires)
    No good in rock gardens..
    Reputation: Sideknob's Avatar
    Racing Ralphs are "high volume"? They always looked kind of average to me.
    Less isn't MOAR
    Oct 2010
    Quote Originally Posted by Sideknob View Post
    Yeah true. But the 2.4 are as large as my ardent 2.4. Both nice large tires.
    CRAMBA Chairman
    ~Reformed Mechanic~
    Jan 2011
    Hey do you happen to know the weight on the 2.2 racesport? Since Continental STILL does not even list this as a current product I cant seem to find any inforamtion on the 29" racesport...
    Helmetless Crasher
    Reputation: Stumpjumpy's Avatar
    I'd rate the rocket Ron as a better light trail tire. It's lighter, has more volume, is more supple, and has much better grip on everything except the hardest hardpack. It also rolls extremely well (especially w/ the rear run in the same direction as the front).
    Best thing since perforated toilet paper.
    '95 M2 StumpJumper FS
    '11 Cannondale RZ 120-two
    Dec 2009
    Mine came well under spec at 529g.
    Continental Cycle Tyres UK
    ~Reformed Mechanic~
    Jan 2011
    Great post BTW! I didn't know they were making the 29" racesport and Ive been dying to try an X-King!
    Mine came in today based on your post and indeed my weighs in at an awesome light 540 grams! I love the way it looks already, seems to have a nice balance of aggressive tread but small enough for speed. 180 TPI feels real nice and bead looks strong and best part is I found one for $50. Cant wait to try this out on the rear!
    Dec 2009
    The new Ro Ro is now pretty similar tread pattern, but the better front race tire. Bigger,smoother and faster. Treads no where near as durable though . That's the x king advantage as a rear trail tire.
    I'm waiting for the 2.4 racesport version to finally become available to try as a front tire. Not enough grunt in 26" but should be about right in 29er.
    Last 2 years I ran Ralphs. Loved 'em. This year switched to the new 2013 Rons...
    And I think I may love them more. (Ride/race xc)
    Reputation: husonfirst's Avatar
    I agree with Varaxis. The trails I ride tend to have loose stuff on top of hardpack. I have the Racing Ralph on the rear and it doesn't grip too well.
    Was hoping to get some better info from this thread, but it looks like everyone have same opinion as me Before I was running Racing Ralph EVO front and back, but when Rocket Ron came out, I switch front RR for Rocket Ron, and was happy ever since.
    This year I started to look for some other tire, simply because it feels stupid to pay almost same amount for bike tire, as I pay for car tire. But it looks like I'm staying with Schwalbe.
    Primoz
    ~Reformed Mechanic~
    Jan 2011
    Quote Originally Posted by primoz View Post
    Ya I feel ya... If the high volume of your Schwalbe's are lower on the priority list than I would highly recommend the X-King in Racesport... Closest thing ive found to perform like a Schwalbe at half the cost...
    Ace5high I went to check both Conti tires, X-King and Race King, and as soon as you hit Racesport (or other tubeless ready models), you are in 1-2eur difference from Schwalbe Rocket Ron or Racing Ralph. At least here in Europe, where all these tires are somewhere around 45-50eur. But it's true, that normal wire versions are really half price. But so are also Schwalbe's Performance line, which I don't really like all that much as Evo line.
    Primoz
    I just got some Ra Ra's in this weekend. I haven't mounted them yet, but I am looking forward to it. I am currently running Hutchinson Cobra's.
    bike-discount has Evo Snakeskin Pacestar RaRa for <30eur.
    Fsrxc I found out this in between, but thanks for this anyway Before I was checking just some local stores and CRC, and everywhere it was around 50eur/tire. Bike-Discount.de and Bike-Components.de have them pretty cheap (around 30eur/tire).
    Primoz
  1. faster tire than racing ralph?
    By Dan GSR in forum 29er Components
    Last Post: 10-22-2012, 07:53 PM
  2. Weighed: 650b Racing Ralph tire 2.25
    By westin in forum Weight Weenies
    Last Post: 05-29-2012, 04:29 PM
  3. Opinion/thought: F vs R tire. AKA and Racing Ralph
    By 29or6to4 in forum 29er Components
    Last Post: 03-21-2012, 03:58 PM
  4. Racing Ralph is my Fav rear tire,
    By Turveyd in forum Wheels and Tires
    Last Post: 08-29-2011, 06:35 PM
  5. Tire Pressure Q - 29er Racing Ralph Snakeskins
    By Scalp1000 in forum Wheels and Tires
    Last Post: 07-01-2011, 09:28 AM
Members who have read this thread: 4
