Results 1 to 30 of 30
Thread: Propane anyone?
    Propane anyone?
    I was set to order some 25-gram CO2 cartridges when I stumbled across the Big Air 40-gram propane cartridges. I'm going to get one canister of it to see for myself.
    Anyone using them, if so are you tubed or tubeless?
    I'm always looking for a better way to get a bigger "bang" out of my buck!
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Not a very good idea .
    aka bOb
    Reputation: bdundee's Avatar
    No idea what the aditives will do to the rubber, even torch hoses require special hose for it. It's not worth it!!
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    *edit*
    changing my tune after schooling myself. i never knew the Big Airs use propane. i've used them and plenty of cyclists i know do regularly.
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
    I Have Cookies
    Reputation: ae111black's Avatar
    Dec 2008
    Haha! BOOM or actually big flash!
    The most important thing is what God thinks about it. He will have the final say. Joshua Stinebrink
    ____
    Kimo
    meow meow
    Reputation: b-kul's Avatar
    probably not so smart. if you do do it at least dont bike through any camp fires!
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by SpartyBiker
    The Big Air canisters have always been propane (as are/were many car tire inflate and seal cans--or butane). Not fuel grade gas, but still flammable. Have not heard of any issues different than CO2 in bicycle use.
    mtbtires.com
    Reputation: bholwell's Avatar
    Oct 2007
    I use them for emergency inflation- haven't noticed any ill effects (or combustion ). I like that you can easily inflate 2 large mtb tires using one canister.
    I always deflate the tire afterwards and reinflate using the floor pump.
    Tire Design & Development Engineer. The opinions expressed in this forum are solely my own.
    Quote Originally Posted by AZ.MTNS
    Could you elaborate please, or is your response based on an opinion or experience?
    Quote Originally Posted by b-kul
    I like your sense of humor
    Quote Originally Posted by bholwell
    I like your idea. I have some older Bontrager Race Lite wheels that I'm not afraid of damaging through propane experimentation.
    There was a problem with instaflate cans for cars, where people would go get their tire fixed and the mechanic would be smoking, unaware that the tire was filled with flammable gas.
    Propane compatability with rubber is a good question. With instaflate, it is made for short term use. If propane has been used for a while for this application, then its probably ok.
    I could see a very slight chance of hitting a rock, causing a spark with the rim, and your tubeless tire to come off the rim at the same time.
    Or maybe even rubbing of spoke nipple with rim causing a spark. In these cases, a tube would be safer than tubeless.
    The spoke nipple thing wouldn't be a problem if the tire was filed with propane only. It needs oxygen to make a flammable mixture. But there probably would be some oxygen in the tire before you started inflating with propane.
    Other than that, awareness of the propane and taking precautions when doing maintenance (proper venting and purging before using tools, no smoking, etc), would be advised.
    Dec 1998
    What's to experiment with? The propane cans have been used by racers for many years.
    bholwell's recommendation is good whether you are using propane or CO2
    mtbtires.com
    As of today I have two 40-gram canisters coming in the mail. I don't smoke or have a lack of self preservation so I don't forsee a propane related incident in my future.
    I'm sure they're the same as using a CO2 when it comes to the amount of skill requirement for useage.
    AZ
    AZ is offline
    As a life long welder I am pretty well versed in the dangers of flammable gases , so I guess you could say that my answer is based on both .
    isn't shipping compressed flammable gasses by mail illegal?
    Quote Originally Posted by shiggy
    In what way is the propane not "fuel grade"
    Dec 1998
    Quote Originally Posted by jeffscott
    No idea of the details. Just what Innovations has said in the past. Less "pure"?
    mtbtires.com
    Reputation: boomn's Avatar
    apparently the processing to create propane can leave a lot of propylene in the mix, which can gum up engines. Higher, more expensive grades have less propylene and more propane. No idea how that really helps or doesn't help with tires or if it has any effect at all here besides price
    Quote Originally Posted by boomn
    Propane is fractionated from natural gas, in which case it does not contain propylene.
    Propane may come from refineries in which case it may contain proplyene.
    There is a HD5 spec that limits propylene to 5% to prevent gum formation.
    It would be difficult to buy propane commercially not conforming to the HD5 spec.
    It may be a mixture of butane and propane, to lower the vapour pressure, so that it may be stored in a lighter container. Probably the case.
    It may be a mixture of propane and CO2....although I wouldn't think so.
    LMN
    LMN is offline
    For past little while I have been using primarily nitrogen in my tires. There is some other stuff mixed in but 72% nitrogen works great.
    "The best pace is suicide pace, and today is a good day to die." Steve Prefontaine
    i'm sorry, my google-fu is very weak today.
    screamer
    Reputation: budgie's Avatar
    I think you might have to be Scandinavian in order to get this to work, but it's not just about the gas; the trick is in the lighter!
    <object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/t7FIvAw2wC4?fs=1&amp;hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/t7FIvAw2wC4?fs=1&amp;hl=en_US" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>
    On heavy rotation: White Lung: Deep Fantasy
    Reputation: killjoyken's Avatar
    Quote Originally Posted by LMN
    Now that's funny!
    Ibis Mojo HD3 - Santa Cruz 5010 V2
    ups and downs
    The big problem with propane is that it's 1.5 times heavier than air so you'll find the top of your tire is always flat because it all runs to the bottom of the tire. Luckily having the top of the tire flat isn't usually that noticeable so no one ever complains.
    Doesntplaywellwithmorons!
    Reputation: DeeEight's Avatar
    That trick with the tires isn't propane... its probably liquid wrench or ignition fluid. Either does the same job. Same goes with liquid graphite spray. Hairspray as well. In all cases you're using a gaseous air/fuel mix in an enclosed space. Add flame and you get an explosion. If its a potato in a PVC pipe, you have a potato gun. If its a tire mounted on a rim, its instant inflation.
    Its actually a VERY common trick among auto mechanics working in cold weather trying to quickly get a tire to pop onto the bead lock of the rim. When its -30C outside, the less time you spend replacing a flat onto a wheel the better.
    now THIS homeboy knows his hydrocarbons!
    since they strongly warn against use in motor vehicles of any kind, do you think it could possibly be lower spec gas? this site says HD10 is common in cali, which ain't too far from Tuscon, where GI is based.
    sorry... i hear the word "spec" & i get a little heavy... it's the engineer in me.
    Quote Originally Posted by meltingfeather
    No, you just have to label it appropriately so they don't try to load it on an airplane. It must be labeled ORM-D, "Other Regulated Materials-Domestic".
    Quote Originally Posted by ridelikeafatkid
    "MOMMY, I WANT TO RIDE LIKE THAT FAT KID!" true story.
    Quote Originally Posted by killjoyken
    Now that's funny!
    Especially if you didn't know he was talking about standard conditions air at mean sea level!
    The Big Air canisters arrived yesterday. Waiting for my next flat tire to use them....should be a blast!
    Quote Originally Posted by DeeEight
    Commonly the tire is sprayed with Ether or Starting Fluid, then a match is thrown at it. Poof....instantaneously inflated tire...minus the rabbit!
