Results 1 to 8 of 8
    Reputation: Hoban's Avatar
    Oct 2012
    Presta valve hole drilled out...
    Got a used bike a few months ago that I'm stripping down for my new frame. The wheels are Sunringle MTX33s and the previous owner drilled the rear valve hole out to take a normal schrader valve tube.
    I don't want to carry two tubes. Is there a fix you can recommend? I suppose I could have someone tig a washer or something on the inside, but not sure these wheels are worth the hassle.
    Would installing a small washer over the valve with a presta tube work?
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    Unless you use very high pressures, you can just put a presta valve stem through the enlarged hole. Tubes have a large reinforcement around the valve so it'll be fine. Just make sure the hole is chamfered so it won't make cuts to the rubber.
    Reputation: Bike Whisperer's Avatar
    Presta tubes will run fine in it
    Reputation: Fix the Spade's Avatar
    It'll be fine.
    But Mavic do little plastic adapters if it continues to bug you.
    http://www.sjscycles.co.uk/mavic-rim...esta-prod3335/
    Oct 2012
    Quote Originally Posted by Saul Lumikko View Post
    Awesome. I have noticed there was a reinforced ring. I'll give it a try. thanks.
    www.derbyrims.com
    Reputation: derby's Avatar
    There is a spacer, Schrader to Presta, some bike shops carry.
    Like others say, it's OK without the spacer at the low pressures used off road.
    Mavic used to ship their schrader valve rims with a "bushing" just in case the costumer want to run presta tubes, now this is a long time ago but maybe you get lucky at your LBS..
    ups and downs
