Results 1 to 7 of 7
    Aug 2013
    Orange Seal valve stems
    I notice a lot of folks poke their valve stems through a scrap of inner tube to seal of the rim hole, so when I saw these - with rubber attached at the base - I thought, "hey, they did the work for me." Well, using the included o-rings, that piece of rubber is harmlessly poised a centimeter off of the surface of the rim. This seems like a gimmicky design, now. What gives?
    What removable core valve stems are the tried and true standard - anything other than Stans I should look at??
    Aug 2013
    I know of nothing other than Stans, and rimstrips. Unless you want to take a tube one size down from your wheel and spend some time with a razor? I avoid the hastle and use Stan's stems and Orange seal.
    Nov 2012
    I use stems from an old tube, cut away enough tube to not interfere with the bead, make it oval (ish) and ride on. FREE. I use stans yellow rim-tape and orange seal.
    My bike MCA kinda climbs like a billy-goat. WOO WOO!
    Aug 2013
    In hindsight, I should have just used old tubes. I'm going to be breaking the bead to check my sealant levels ANYWAY, so why even fuss about removable cores??
    For the time being those Orange Seal valves are working fine. Hope they continue to!
    Thanks for the input y'all...
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    Quote Originally Posted by cpinkhouse View Post
    Cut the valve out of a Q-Tube with a removable core (says it on the box), like this:
    It's not a fuss, and there are two primary reasons for me:
    1. super-fast inflation, which helps get beads set; often the make-or-break set-up change.
    2. ability to add sealant easily without breaking the bead. i don't break beads to check sealant levels very often at all. I generally know about when they are going to need it
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
    Nov 2012
    a good shake will tell you if you have sealant. if you hear sloshing, you have plenty
    Aug 2013
    I prefer the Stans injector to breaking the bead.
  1. Orange Seal Valve stems
    By frank daleview in forum Wheels and Tires
    Last Post: 05-07-2014, 07:07 PM
  2. Tubeless valve stems??
    By CuddlyToast in forum Weight Weenies
    Last Post: 03-19-2014, 06:43 AM
  3. low pressure ripping valve stems...help
    By bozofs in forum Fat bikes
    Last Post: 02-11-2014, 10:35 AM
  4. anyone use Orange Seal TL?
    By bitewerks in forum Wheels and Tires
    Last Post: 09-13-2012, 12:49 AM
  5. WTD Roval 2bliss Valve stems??
    By specbill in forum 29er Components
    Last Post: 05-07-2012, 09:01 AM
