Page 5 of 6 FirstFirst 123456 LastLast
Results 401 to 500 of 591
  1. #401
    Dec 2008
    Quote Originally Posted by J. Random Psycho View Post
    The two bearings closest to the sprag clutch do not touch the axle. They separate hub shell from the driver body.
    Really? Why use bearings then? I must be missing something...
    Sent from my Pixel XL using Tapatalk
  2. #402
    meow, meow.
    Reputation: J. Random Psycho's Avatar
    Quote Originally Posted by compengr View Post
    They provide for the rotation of hub shell and driver body around the same axis. They transfer rider weight from hub shell to axle bearings while keeping the clutch isolated from it.
  3. #403
    Dec 2008
    Had to watch the service videos on their site to see how it works . Because of the sprag, the drive shell extends deeper into the hub, much more than a typical ratchet design, leaving less (possible) support for the axle. I get it now.
  4. #404
    meow, meow.
    Why, the support for the axle is *better* when the two axle bearings are closer to its ends. See the formula for the deflection of a beam with supported ends (dropouts) and two loads (bearings). It benefits (results in smaller values) from multiplying the squared beam length by as small a dimension as possible, and that dimension is the distance between support and nearest load.
  5. #405
    Chris Bling
    Reputation: dustyduke22's Avatar
    When folks start talking formulas, all most people hear is " bla bla bla".
    Not saying you are not intelligent, just saying if you are trying to make a point it's probably going to be missed.
    Sent from my SPH-L720T using Tapatalk
    The obsession of wheels fused with the passion of cycling
    Affordable Custom Wheels
  6. #406
    Dec 2008
    What about the loads from the drive shell?
  7. #407
    meow, meow.
    The way the axle sees rider's weight, hub shell and drive shell are one part that applies two loads to the axle, in the same direction, and very close to its ends.
  8. #408
    Nat
    Nat is online now
    Reputation: Nat's Avatar
    Mmmmm, Subways...
  9. #409
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    I will eventually, will take a while to get back, remember, these are the fat versions.
    I'm in another state right now, so it'll take me some time to get back and get the full story. I was speaking to the prelim information I discussed, so no details, but this sounds similar to what we talked about.
  10. #410
    Onyx needs to get a BOOST 20 front hub out to market soon.
  11. #411
    Dec 2008
    Quote Originally Posted by PUNKY View Post
    What's wrong with their 20mm hubs?
  12. #412
    Jan 2015
    We have the 20mm BOOST setup completed in October, for both Centerlock and ISO 6-bolt! Both are available now.
  13. #413
    Dab-O-Matic
    Reputation: Simplemind's Avatar
    Quote Originally Posted by Jim Gerhardt View Post
    Jim, is the "low weight" version of the rear hub still on hold till next year?
    SB4.5 XX1/XTR
    Parlee Chebacco
    Cannondale Black Di2/disk (roadie)
    '07 575 XT
    SB95a*
    SB95c*
    ASRc*
    SB5c*
    * retired
  14. #414
    Dec 2008
    Jim, any updates on the new lightweight hubs?
  15. #415
    Jan 2015
    We are very confident that we will release these in the next few months. They have passed our mechanical testing and are currently in the field for some real-world abuse. So far they are performing flawlessly. We will make sure to do an announcement when we have a firm date. Thanks for the question!
  16. #416
    Dec 2008
    Looking forward to seeing more on these! Weight wasn't really an issue (for me), but I wont say no to a lighter component as long as the functionality and reliability don't take a hit
  17. #417
    Dec 2013
    The weight is a large issue for me. I've ridden Onyx hubs and frankly love the way they work, but I'm not willing to add weight to my bicycle when other components essentially do the same job for less weight. I hope they are successfully able to get the weight competitive. Only problem is I already bought some new Wheels and went with 321 hubs.
    Sent from my SAMSUNG-SM-G891A using Tapatalk
  18. #418
    Dab-O-Matic
    Quote Originally Posted by Suns_PSD View Post
    I'm curious what tires you will be running? Hopefully not Minions.
    SB4.5 XX1/XTR
    Parlee Chebacco
    '07 575 XT
    SB95a*
    SB95c*
    ASRc*
    SB5c*
    * retired
  19. #419
    Aug 2015
    321 hubs are nice. Pricey and no centerlock boost hub for their new G2 model.
    Sent from my SM-G930V using Tapatalk
  20. #420
    Dec 2013
    Quote Originally Posted by Simplemind View Post
    You are welcome to your opinion.
    I've tried SO many tires, for me, Minions just offer the best compromise between traction. weight, rolling resistance, cost, and wear. They actually make me go faster. IMO, and I've searched, any other tires have me riding slower.
    Hubs, I like the silence, engagement, heck I even really like the sprag wind up that is obvious in an Onyx hub, to me it's like traction control, etc. But faster they will not make me, nor will I clear anything that I couldn't clear before.
    So the Onyx, while very cool, has obvious equivalents that offer great engagement and low rolling resistance, but much lower weight. That's why I currently have 321s.
    If the weight was about the same, I'd prefer the Onyx however.
  21. #421
    Aug 2015
    Have you tried dt swiss with the 54poe upgrade and made a comparison? Ive always wondered if the extra poe offered better performance on techy climbs. The dt 350 is such bang for the buck in terms of price and weight. The 322, torch, onyx are sp bling, its tough to resist. Makes my dt swiss very mundane.
  22. #422
    Hey Jim, any "projected" target rear hub weight in ISO and CL?
    My inner weight weenie wants to know!
  23. #423
    Jan 2015
    Quote Originally Posted by verrocchio100 View Post
    I do have some photos I took a while back, these are the Boost versions. We are still trimming here and there, but these weights will probably be pretty close. The updated front hubs will approximately 160g for the ISO 6-bolt boost version.
    Onyx Racing Hubs - Sprag Clutch vs other types of Engagement-img_0870.jpgOnyx Racing Hubs - Sprag Clutch vs other types of Engagement-img_4537.jpgOnyx Racing Hubs - Sprag Clutch vs other types of Engagement-img_7657.jpgOnyx Racing Hubs - Sprag Clutch vs other types of Engagement-img_8797.jpg
    Attached Thumbnails Attached Thumbnails Onyx Racing Hubs - Sprag Clutch vs other types of Engagement-img_6127.jpg
  24. #424
    Aug 2015
    I like the silver color!
  25. #425
    Dec 2008
    Careful, you may start "as machined" trend...
  26. #426
    OMG!
    Jim, those look delicious!!
    Any idea if these will roll out (pun intended) before or after SOC?
    And will there be a lighter weight front hub for SuperMax Lefty?
    Thx!
  27. #427
    Jan 2015
    We are close, but probably won't happen. The clutch mechanism requires certain design criteria that other hubs don't need. It is a trade off for the benefits it provides. However, we did get the front down to about 160g, so that's a bit lighter than some of our competition and will bring the total set weight a little closer. I don't ever expect to be the lightest, not in the cards, just trying to get it as best as possible while still keeping the reliability up.
  28. #428
    Jan 2015
    We just shipped out some pre-production test wheels this week to our best riders. We'll see what they come back with. Trying to get all the little details wrapped up before we start making them in our production runs. Nothing worse then building a bunch and then having to change something later because you got ahead of yourself. We want and need to produce the best we are capable of, lots of great competition out there ya know!
    Nothing has changed on the Lefty hubs, there is not a lot of demand for them and we have to keep to a certain design due to the fork mount, so this really limits the options to reduce weight without looking like a replica.
  29. #429
    Awesome Jim, thanks to you and your team for pushing the limits!
  30. #430
    Mar 2012
    I have an engineer friend testing various fat hubs in the cold, including onyx. While they have a great drive mech, according to him, there is little support for the axle by the bearings, other more traditional designs like hope and DT do a much better job here, not sure if this applies outside of the fat hubs, but it was interesting and could be a source of this cracking problem. He was indicating the heavier/more aggressive the rider, the worse this would be.
    I cannot disagree more. To speak about Hope, that I was using on my fatbikes, that was exactly the issue, to much load on the axle, and free wheel hub. Hope has to small bearings and have not enough strenght to hold my my weight (265). After replacing all bearings in the Hope hub, the bearings was more or less grinding after 3-4 rides. The bearings in the free wheel hub get so much load that it after a while blows up. The balls are grinding all metal and then tears it apart. Especially the one bearing closest to hub shell.
    With the Onyx, I have experienced a few years with trouble free riding. Almost without servicing these hubs either. I think it has to do with the exactly that the axle is having big and solid bearings, and three in total, one at each side and one in the middle. The axle is from steel, and the the sprag cluthing are also taking up the energy like it should, locking around the axle. Not like a pawl/rachet system placed on one side of the hub getting twisted on a small surface on the axle.
    The issue with the cracked hub shells comes from aluminum design that have had some issues, I suppose. I have not heard about any fawlt on the steel versions?
  31. #431
    Jan 2015
    We have had a few of these axles crack. He is referring to the drive side end of the axle where the drive side nut is tightened on the end of the axle. We haven't had many and we have linked that problem to the nut being or becoming loose. A drop of blue Loctite on the threads has fixes this problem. When that nut wiggles loose or isn't tighten properly, it rocks ever so slightly back and forth, fatiguing the metal and eventually will crack it. Now remember the through bolt is still there supporting and this really doesn't cause anything noticeable unless you take off the wheel, then you see theres a loose piece. We use a 6902 bearing on all our drivers, 28mm od and 15mm id. Others use either a 28mm od x 17mm id or a 6802 which is 24mm x 15mm, or some sort of variant of this. What does this mean? From our testing the load on the bearings is significantly higher with these smaller bearings, causing them to either fail sooner and/or roll less efficiently. The larger balls in the 6902 seem to solve this, however there is a trade-off, they are a little heavier and we have to thread the portion just on the outside (15mm od portion of axle) in order to get our drive cap nut on. Our new lighter hubs address this differently by using press-on end caps like others while still using the 6902 bearing, so no threads in this area, but this too comes with a trade-off, the new hubs will not have the bearing side-load adjustability.
  32. #432
    I, for one, have little to no issues with my hubs that do not have preload adjustment (i9).
    Agreed, more support with larger bearings is a sound trade off for a little increase in unsprung weight.
    With regards to the weight pix, what are the hub profiles to the according weight?
    Are the flange spacings, flange diameter and flange thickness the same as the current production hubs?
    Or are the flanges beefed up in thickness for spoke support then the edges scalloped for weight reduction?
    Are the spoke holes angled and champfered to relieve spoke contact to flange. I do dislike having the flanges marred by the spokes when I get them rebuilt.
    Thx Jim!
  33. #433
    Jan 2015
    The preload adjustment is just a fine tuning feature to gain the smallest advantage out of your hubs.
    They are all boost spacing 148/12 hubs in the photos. Just the Centerlock/ISO/HG/XD combinations of each.
    Flanges are changed a bit to accommodate the weight reducing scalping. We do this for 1. weight and 2. reduction in flange height while still allowing the spokes to be installed easily.
    The flange angle did change a little on this design as well to help deal with the reduction in material, however the spoke hole diameters and such are all the same or very close to current models, so close I don't anticipate spoke length changes to/from same models. We do have hub-specific spoke calculators built into our website (which is about to be updated again). The flanges are angled to reduce spoke contact as well. Thanks for the questions.
  34. #434
    mtbr memeber
    Reputation: jpre's Avatar
    Will the current design continue to be sold alongside the new design, or will the current design eventually be phased out?
  35. #435
    Thanks Jim, interesting to see on the Centerlock hubs the non drive flange is smaller in diameter and weigh a bit less than the ISO models, why so?
    Thx!
  36. #436
    Jan 2015
    The current design will stay as is and still be offered with all the extras as standard. The new hub design will be a complete model line in itself. We are still deciding on a few things to reduce price on this new line as well. 1. Steel bearings 2. No upgrade program on this line 3. limit colors on end-caps etc. 4. no custom engraving
    These are things we'll have to iron out before production launch, but this hub line will be targeted more towards the mainstream with concerns over weight and cost.
  37. #437
    Jan 2015
    The flanges on the iso 6-bolt design need to be taller in order to get the spokes in. On the drive side we are limited to how small this height can be due to the clutch drive system. The disc side on the center lock design has a much smaller diameter so we can reduce the flange height quite a bit. This make all our center lock hubs lighter. In addition, the XD version are lighter then their HG counterparts due to the SRAM design vs the Shimano.
    On the center lock DS flange we reduce the height to save weight and can do so because the NDS flange is smaller yet. On the ISO flanges this is not the case. If we used the same DS flange height as the center lock design we'd have a case where the DS flange is smaller diameter than the NDS, this would amplify the spoke tension imbalance already on wheels, so we keep them the same height to minimize it.
  38. #438
    West Chester, PA
    Really enjoying the detailed answers you're giving everyone Jim. 👍
  39. #439
    Awesome info Jim, thanks!
  40. #440
    Good to hear. I emailed you guys late 2017 to get a BOOST 20 CL front hub to match my rear hub and was told they weren’t going to be making them anytime soon.
  41. #441
    meow, meow.
    This is great news! I've been worrying the WW, non-adjustable design was going to take over.
    26" rigid SS 4130 BB7 nylon-flats ESI latex-tubes non-lubricated-8spd
  42. #442
    Dab-O-Matic
    I just find it interesting that so many people focus on weight with little regard to where that weight is located. As you know rolling weight, especially weight with the largest moment arm, think centrifugal force, is by far the most critical. If you're swinging that 1000-1200 gm hunk of rubber at the end of that 350mm spoke, that's a whole lot more penalty than 200gms of weight that is essentially not rolling weight located at the center of rotation. The only place I see that extra 200gms of weight causing an issue is possibly with the suspension.
    I run an I9 Torch on another wheelset and I do not detect a difference in weight. What I do notice is the noise and the engagement, both in favor of the Onyx.
    SB4.5 XX1/XTR
    Parlee Chebacco
    '07 575 XT
    SB95a*
    SB95c*
    ASRc*
    SB5c*
    * retired
  43. #443
    Speaking for myself Jim, I pricing isn't the issue for me; I will gladly pay for the performance! Top end offerings are well within the current range that is offered, IMO.
    One vote from me, leave option for ceramic bearing upgrade available.
  44. #444
    Jan 2015
    "Good to hear. I emailed you guys late 2017 to get a BOOST 20 CL front hub to match my rear hub and was told they weren’t going to be making them anytime soon."
    Things change quickly around here!
  45. #445
    Jan 2015
    Thanks for the input!
  46. #446
    Nat
    Nat is online now
    Same here.
  47. #447
    Dec 2008
    Jim, thank you for the detailed answers and the insight into your new design! Sounds like you are trying to streamline the process and/or reduce inventory to come up with a more competitive price point for this new hub. I'm all for that! My personal interest is mostly in the silent drive mechanism (sprag clutch). Everything else is less of a priority. My thoughts on the four items you mentioned:
    1. As long as they are reliable, the material makes little difference to me. Having said that, I can see how this could be a desirable feature, especially if the upcharge is minimal.
    2. While I liked the idea at first, realistically, this will probably not be useful to me. Almost without exception, the only time I look for a wheelset is when I'm putting together a new bike...which means the old set of wheels is being sold with the old bike.
    3. By limited do you mean one color? Not really an issue for me if it's something like anodized black or clear.
    4. Wasn't aware this was an option. Kind of a cool way to do something special, but it would be low on the priority list for me.
  48. #448
    Sure, where the weight is located matters, but overall weight does too. Think about this for a while, it's not just your wheels that are accelerating forwards and backwards, you are turning, you are going up and down. Lifting your bike several thousand feet requires lots of upwards accelerations, in addition to forward accelerations, pretty much constantly. Every pedal stroke is an acceleration because you can't maintain constant output. Wrenching the bike left and right is acceleration. With all of these, the mass is important. In some conditions/trails, I can go ride a very lightweight bike and just keep clicking out the miles because the entire system of the bike is lightweight and doesn't affect me nearly as much as the alternative. When you start adding heavier parts, heavier carnks, hubs, rims, bars, add some more suspension or less efficiency, it starts to bog down and it takes a toll. When you are building a lightweight bike for racing purposes, you simply can not compromise or you are at least severely limited in your ability to do so, as far as component selection. If I want to run a dropper, it adds weight and I have to look for somewhere else to drop some off. I totally get that people may be willing to make these sacrifices in some areas, like people that go with CK or Onyx hubs, but think about the flipside too, if you are building a go-fast bike and trying to do so to improve results, you try to line up as many things in your favor as possible, from the bike weight and performance to your hydration to your clothing (and yes, reliability is one of those things too!). Again, you are extremely limited in the compromises you can make in this pursuit. Some of us consider it to be fun because we put in a lot of effort and time riding and we get to see these results and we make little tweaks here and there. A good product will sell, especially if it fills a niche like heavyweight/extreme torque applications, a significantly heavier hub won't be for everyone either though and it's also fun to ride a light bike in my experience.
  49. #449
    meow, meow.
    The "racing" part in Onyx Racing is meant for the gated start events, I think.
    FWIW, with more time dedicated to riding, I found myself increasing weight of some components (frame, fork, crankset, stem, rear hub, going back to steel bolts everywhere) and decreasing rotating weight (tubes, tires). This way I spend less time working on bike, and the onset of fatigue cracking in critical parts is delayed or even prevented.
  50. #450
    Jun 2010
    Any upgrade to the sealing on the newer (and old) hubs?"Freehub" labyrinth seal is VERY good but feel the end bearings could be sealed better. My Hope Pro II outer bearings are sealed very well and lasted 4+ years.
  51. #451
    Jan 2015
    Streamlining our production is a constant moving target, so we are always trying to improve on that. When I stated limited, it was referring to the end cap color choices (probably just do black as they are not seen that much anyway) and other value added services like free laser etching (will be hard to do on the new design), etc.
    I'm sure we will make ceramic bearings an upgrade charge.
  52. #452
    Jan 2015
    As you stated there are many factors to be considered when building a bike, weight is defiantly one of them. However based on test that have been done by reputable third parties, performance seems to be the most heavily weighted (no pun intended). So lighter doesn't mean more efficient or faster. See attached study provided by Duke University. https://www.dropbox.com/s/cs2g251nz9...ndown.pdf?dl=0
    Now if you're talking feel of a bike due to weight that is entirely user preference and I'd agree 100% with you.
    As a rider I too appreciate the many different options of products available to tweak my bikes. I personally can't tell the difference in the weight of the rear hub from another but other many notice the grams. It's all good input for us though and appreciate your comments!
  53. #453
    Jan 2015
    Sure thing, we modified the cinch nut on the non-drive side to have a flat o-ring seal, this can be easily adapted to your current hub. The drive side is a little more difficult to seal without adding a lot of resistance (heavy seal/grease on driver bearing). We are working on a better sealing bearing that will allow similar performance to the current mid-seal we use now.
    It is always an option to clean and repack the bearings with a thicker grease (not the clutches, just the bearings). This will provide a longer maintenance period, but will reduce the efficiency. See our youtube channel for details on how to perform this.
    https://www.youtube.com/channel/UCzn...tXT7ZGuGFujPnA
    Quote Originally Posted by Aaron1017 View Post
  54. #454
    Hey Jim, just a thought from an end user with no background in design how about o-ring seals sandwiched between mating surfaces to prevent water/debris intrusion?
    Since the hub surfaces are CNC or EDM, would there need to be a vast change in line code to make a channel for an o-ring seal like on the end caps and not on the edge?
    Or another avenue would be to allow better draining so when cleaing the bike, the water can carry the debris away rather than letting the crap accrue.
    I see a lot more sealing structures within fishing reels than ever before and even more areas to allow drainage, so thats where me comments come from.
    However, I could be talking just a bunch of nonsense.
  55. #455
    Jan 2015
    Thanks for the input, we'll have to turn up a test piece and see. I think we all agree the labyrinth seal is best when it can be used as it provides little to no friction and has excellent sealing properties. Your first idea is something we discussed before and is doable, just haven't tried it yet. It would require a custom o-ring. I'm not so sure on your second comment about easier draining, this seems like a design like this would also lend itself to easier debris access as well, since most of the time a bike hub is subject to small sand and other dirt particles as well as the liquids. We will take a look at some of those fishing reels! Thanks!
  56. #456
    The draining is a double edge sword Jim. Good to keep the water/debris out but still need to keep things clean. The best sealed reels I have worked on are made by Shimano/Daiwa/Okuma; as a tangent.
    As for bearings, I know the much preferred Enduro Bearings; however, here's another option and my 2 cents worth:
    https://www.bocabearings.com/product...&ProductType=2
    Mod's strike the post if inappropriate to link to another site.
    BTW, the blue ano'd CL hub is svelte!
  57. #457
    meow, meow.
    Jim is right about hard particles being always introduced with water. These are a *much* bigger concern than water. Modern general purpose greases can absorb some water and still perform, but grit is the scourge.
  58. #458
    Magically Delicious
    Reputation: Cleared2land's Avatar
    As a trade-off between increased friction and a practical contaminant seal, I subscribe to a modest light grease on the seal and hub contact points. Slick Honey or freehub grease work well in my personal experience.
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
  59. #459
    Jim, will there be a Boost Single Speed specific version of the new lightened hub? Fingers crossed.
  60. #460
    Reputation: kopavi's Avatar
    Jan 2013
    Jim:
    A novice here. I saw the picture below of the prototype hub and my thought was would there be a benefit to build a hub with two 1/2 sprag half clutches?
    Onyx Racing Hubs - Sprag Clutch vs other types of Engagement-full_p1340477_764203.jpg
    You could have the original hub with 2 full sprag clutches for riders that need the maximum performance, the mid-range with 1 sprag and 1/2 sprag for the next tier rider, then have the 2 1/2 sprag clutches for your low tier riders (old, slow cross country riders).
    I'm not even sure how much of the weight is in the sprag clutch mechanism so this idea may be a bad one.
  61. #461
    Reputation: willysurf's Avatar
    Jim,
    Do you have any EA for when LB will have the new lighter hubs available? I am getting ready to pull the trigger on an LB wheelset but will wait for the lighter hubs if they are not more than 2 months out.
    Thanks,
    Willy
  62. #462
    Any plans for a 110 centerlock torque cap front hub?
  63. #463
    Jan 2015
    Quote Originally Posted by rwitte View Post
    Yes I'm quite sure we'll have that as well. The plan is to have pretty much everything available.
  64. #464
    Jan 2015
    We're very close. 2 months is probably on the soonest side.
    Quote Originally Posted by willysurf View Post
    Jim,
    Thanks,
    Willy
  65. #465
    Jan 2015
    Not possible currently. Torque cap and centerlock lockring sit in same spot.
    Quote Originally Posted by farfromovin View Post
  66. #466
    Jan 2015
    All the new lighter-weight hubs have the 1-1/2 sprag design like in the photo. The photo you posted is actually our current road hub, but will be similar design on new hubs, just with the exception to allow for a 12mm thru-axle, so driver and internal bearing changes a bit. Our current dual sprag is more than adequate for any weight/load rider. The sprag capacity is a small part of the calculation, other factors on internal components is what we are currently field testing. ;^)
    Quote Originally Posted by kopavi View Post
    Jim:
  67. #467
    I've been watching these hubs with interest for a while now. A silent hub for back country riding sounds great. As everyone is adding to the wish list, I thought I might try the same.
    I'd be happy to sacrifice some rolling speed for better sealing. Weather kills anything with moving parts really quickly here in the UK.
    I'd also like to see a MiniDriver freehub offered as use the Hope 10-48 11 speed cassette.
  68. #468
    Jan 2015
    Both excellent points! We are currently looking into the minidriver, it is an interesting concept and I like that it is open source!
    Quote Originally Posted by onzadog View Post
  69. #469
    meow, meow.
    Another vote for this.
  70. #470
    Jan 2015
    We are leaning towards offering two bearing options, one ceramic for the performance minded and one steel with heavier seals for those out for better sealing. These are being tested in the field now. We have also changed the seals on the end caps to help prevent anything from getting to the bearings as well.
  71. #471
    Robertson
    Reputation: rpearce1475's Avatar
    Jan 2015
    Will these new, lighter weight internals be swappable into current Onyx hubs?
  72. #472
    Consider my interest piqued. Is there a UK importer?
  73. #473
    Jan 2015
    Quote Originally Posted by rpearce1475 View Post
    No, these are a complete different model.
  74. #474
    Jan 2015
    pm sent
  75. #475
    Aug 2014
    Jim,
    It sounds like you're trying to make a price point on these newer hub designs. Are you reducing the cost of the hubs to be under the current 2 full sprag hub?
    So basically less weight and lower cost?
    It takes half a joule more to accelerate Brass Nipples over Alloy Nipples on a 29er to 30kph.
  76. #476
    Reputation: azjonboy's Avatar
    Love the fact that Jim is so present on this forum.
    I've run King and I9 hubs for years. Also have some Hadleys. After talking with James at Black Sheep, he recommended I give the Onyx hub a shot.
    Built a set of wheels up for the 29+ and went with Onyx. Super glad I did! rolling super quiet through the desert at night or the pines up north when alone in back country is really cool 😎
    Having instant engagement when climbing the tech stuff is also nice.
    I have two wheel builds coming up, one SS and the other mid fat. Both will roll on Onyx!
    If you're lucky enough to be in the mountains,
    you're lucky enough.
  77. #477
    Feb 2014
    Oh geeze, just under 500 posts to catch up on these hubs!
    Likely worth it though since I swear my I9's have given me tinnitus.
  78. #478
    Jul 2015
    Has anyone had success with alternate greases on the sprags?
    I have dozens of greases and really don't want to spend $40 on a tube of grease (cheapest I found was $35 shipped for 45g) I'll only ever use on this one hub.
  79. #479
    Reputation: blacksheep5150's Avatar
    Oct 2014
    Quote Originally Posted by Bhaalgorn View Post
    Spendy it is and i made a mistake and got there high speed spindle version . So i figured if it last on a lathe or end mill i would never break it down . So i use it on all bearings , pedales , wheels, cranks etc , seems to be fine and its alot thinner viscosity ..and of course use it on rear hub mechanism
  80. #480
    Magically Delicious
    Quote Originally Posted by blacksheep5150 View Post
    What is it? Define what you're using.
  81. #481
    No issues in extreme cold weather. We recommend the use of Kluber LDS 18 Spec A greaase, very light coating. Less is more in this application. The grease limits are
    • Upper Heat Range 120 deg Celsius
    • Lower Heat Range -50 deg Celsius
    I assume this is what is being referred to.
  82. #482
    Dec 2008
    I'm guessing that the Kluber grease is likely called out by the sprag manufacturer. Probably for a specific film thickness.
  83. #483
    Jul 2015
    I'm determined to find an acceptable alternative, so we'll see.
    Can anyone with the Kluber grease provide some comparisons to describe its viscosity? I'm thinking Rock n Roll Super Web might be a good starting point.
  84. #484
    Magically Delicious
    With Kluber LDS 18 Spec A grease pricing at about $1 per gram, I would be seeking out another "dynamically light long-term grease".
  85. #485
    Jul 2015
    Quote Originally Posted by Cleared2land View Post
    Exactly
  86. #486
    Magically Delicious
    Prolly something closer to a freehub styled grease. Lubiplate #105 maybe?
    Rock n Roll Super Web grease is a high PTFE thick waterproof grease that is more applicable to traditional bearing grease.
  87. #487
    Jul 2015
    I don't think that's waterproof. I like super web because it's pretty thin water proof and it does a good job of staying put.
  88. #488
    Magically Delicious
    If you're referring to Lubiplate not being waterproof, I will prolly agree. My reference to the Lubiplate was the viscosity similarity.
  89. #489
    Dec 2008
    Given the role this grease plays in the function of the hub, I would be very hesitant to experiment. I would wait for Jim to chime in or give them a call before using anything other than what's recommend.
  90. #490
    meow, meow.
    I'm afraid any alternatives are just as exotic and expensive.
  91. #491
    Magically Delicious
    You might be correct. However, we might already have an acceptable lubricant immediately available. The specified Kluber LDS 18 Spec A grease is based on mineral oil, ester oil and a lithium soap. This is a very common base or foundation for many readily available lubricants. I seriously doubt that this specified Kluber grease contains any proprietary ingredients that these Sprag clutches can not live without.
  92. #492
    meow, meow.
    The "long-term", "resistant to ageing, oxidation" part might be the trick?
    Here are versions of MSDS and TDS that list more data on this grease than some others I found (perhaps there are still more complete ones):
    https://www.makino.com/pdfs/msds/isoflex.pdf
    http://yairerez.co.il/wp-content/upl...-special-A.pdf
  93. #493
    Magically Delicious
    I think most quality lubricants will meet those requirements.
  94. #494
    Although the fat bike snow season is not completely over, it's close so I'll to out on a limb and say that I have completed my first ever season w/o major hub issues. I have gone through Hope (couldn't keep a the bearings in good shape to save my life) /I9 (cracked the DS hub flange) / 907 (just garbage hubs) / Onyx (cracked NDS hub flange).
    Hoping this Onyx and I will have years of riding bliss together. I am surprised I was not contacted by Onyx for testing of their new lightweight hubs.
    The only two hubs I trust are Chris King and Onyx. That might not mean a lot to some people, but it means a lot to me!!
  95. #495
    meow, meow.
    Quote Originally Posted by jonshonda View Post
    True Precision were nice as well. I can swear by my S2 Poacher. But alas, they went out of business when Onyx came along.
  96. #496
    As far as I know, they’re still in business. I use their S4 hubs and an Onyx. Both solid hubs!
    Only thing I know is that Box Components purchased TP. But their site is still up
  97. #497
    al you that hunt other grease, buy a really expensive hubs, and hunts dollars when it comes to things needed for serve the hub, a thing you do many once a year or even that?
  98. #498
    meow, meow.
    It's not the price as much as the combination of exotic, disposable, and limited shelf life in a thing that's necessary to keep the bike running.
  99. #499
    Jan 2015
    Regarding the Special grease we require in our clutches. It is not so much as to what's in the grease, it's really whats NOT in the grease. PTFE/Graphite/etc. The clutch operates on friction, any change to that minimal amount of friction, too much or too little, will make the clutch actuate differently or not at all. The Kluber grease is a synthetic long term grease without slippery additives. This allows the clutch to operate properly. Too thick of a grease will prevent the individual sprags from moving, so they won't engage/disengage properly. Less is more in this application, the grease is very lightweight, won't break down quickly and prevents corrosion. CNC specialy sore online has a tube for $28. This should last you many lifetimes! We do have this same grease spec'd in our bearings, but this is not mandatory. We use it throughout the hub just in case of cross-contamination, with that said, we haven't seen any issues where people have used different grease in the bearings. We have seen issues where non-spec grease has been used in the clutch. My advice is to use the correct grease. If you have trouble finding it give us a call/email. If you already have your hub apart and don't have the grease, it is best to put it back together dry then coat it with grease when you get it.
  100. #500
    meow, meow.
    Thank you Jim!
    Now that we know it shouldn't contain solid additives, and in accordance with DIN 51502, the Kluber Isoflex LDS 18 Special A grease designation would be KE 2 K-50, or KPE 2 K-50, and we could be looking for a similar grease by designation without letter F in between the first K and the consistency grade digit, NLGI grade of 1 to 2, and just as low or lower service temperature bound.
    Substitute greases could then be the likes of:
    Mobil Unirex S2 (base oil viscosity might be too high)
    Fuchs Renolit S2
    Castrol Optitemp TT1 (base oil viscosity?)
    SKF LEGE 2
    Last edited by J. Random Psycho; 04-16-2018 at 03:34 AM. Reason: Added SKF LEGE 2; expressed doubts as to base oil viscosities of previous candidates
  1. King Hubs vs Oynx Racing Hubs
    By thatSAMazing in forum Wheels and Tires
    Last Post: 09-25-2017, 08:33 PM
  2. Hershey Racing hubs - need help please
    By mfh126 in forum Vintage, Retro, Classic
    Last Post: 02-21-2013, 06:37 AM
  3. Profile racing hubs
    By slowrider in forum Wheels and Tires
    Last Post: 11-02-2012, 10:49 AM
  4. Wheels and hubs for racing/riding
    By kimio in forum XC Racing and Training
    Last Post: 08-16-2011, 06:57 PM
  5. New elite MTB hubs from profile racing
    By mattybfat in forum Singlespeed
    Last Post: 03-15-2011, 04:07 AM
Members who have read this thread: 477
