Results 1 to 6 of 6
    MTK
    MTK is offline
    Old Ringle Rear Abbah.
    Hey guy's,I sent a email off to Ringle about this and had no luck due the "age"
    of the Hub.
    :Qustion to Ringle was,do you have a conversion kit for bringing a 12/135
    down to a 10/135?
    Answer: No,we no longer make that hub in a 10/135. 10 years ago you could
    get a 10 or 12mm when ordering it.
    I have a full rebuild kit here with me,freehub and all. I want to put this set on my
    son's Arrow Hardtail bike. Without that 10mm, I'm ass out.
    I thought someone might have a old Ringle Hub in a 10/135mm Spacing?
    Peace.
    MTK
    Reputation: daisycutter's Avatar
    Reputation: 4slomo's Avatar
    You might be able to get a machinist to turn down the ends of your 12mm axle to 10mm and rethread.
    Quote Originally Posted by MTK
    of the Hub.
    down to a 10/135?
    Peace.
    MTK
    Hey everybody, ride my wheels! They ride good, real good.
    I'm a wheel builder. SRLPE Wheel Works. Send me a PM.
    MTK
    MTK is offline
    I think It might?
    My only concern is if there will be any play in the center of the Hub,as I will
    have to take the internal sleeve out to run that Axel. What's really cool is
    that I have a couple brand new Saint Rear Der.'s.
    Ringle just gave me a call. He said that the 10mm option that they had back
    then was a QR. Also he had no parts as to the age of it. He did say he had
    a guy grind the Axel and had no problems. Dont know how I would go about
    that? Anyone?
    I'll order up this Axel for now and see what happens. Peace.
    MTK
    Reputation: bvibert's Avatar
    Mar 2006
    Quote Originally Posted by daisycutter
    Azonic makes what appears to be the same thing for half the price:
    http://www.pricepoint.com/detail/180...mm-X-135mm.htm
    These will only work if the hub is a through axle type design. In other words the axle doesn't attach to the hub, it just slides through and is fastened by nuts on either end. If your hub has a threaded axle that stays attached when you remove the wheel then this won't work for you.
    MTK
    MTK is offline
    Quote Originally Posted by bvibert
    Here is a shot for you. My son is buying the Axel and has yet to do so yet. I think
    I think I like the first Axel better? Hope these shot's come out. Peace.
    MTK
