Results 1 to 2 of 2
    Nukeproof Generator Hubs Front...how to change to QR
    Hi All,
    I just would like to ask if anyone of you have already disassembled a nukeproof generator hub the front one.
    I just bought a set of these and the one in the front is for an 20mm axle but it has an adapter in the box for QR, but I could not find any manual on how to remove it without damaging it.
    Any advice would help.
    Aug 2014
    Well I may be 2 years too late but here is the answer:
    The adapters are held on the bearing shaft with internal O rings, in theory they would just pull off with your fingers but they are very tight.
    I used vice grips with webbing wrapped around the anodized adapters so as not to mark them and wiggled them off easily.
    Hope this helps
